Go Back   MBWorld.org Forums > Mercedes-Benz Sedans > C-Class (W203)
Sign in using an external account
Register Forgot Password?
Register Photos FAQ Members Insurance Search Today's Posts Mark Forums Read CarsGarageVendors
Welcome to MBWorld.org Forums
Sponsored by : My Mercedes Parts
Click Here
LinkBack Thread Tools Search this Thread Rate Thread Display Modes
Old 07-23-2006, 10:49 PM   #1
Drives: BMW 6 series, B6 A4, C230 kompre
C320 service cost
hey guys...anyone knows how much does the 60xxx miles service cost on 02' C320? thanks
To remove this ad, register today or login if you already are registered!
B38AS is offline   Reply With Quote
Old 07-24-2006, 02:44 AM   #2
Drives: 2005 C230 Kompressor Sport Sedan and 2002 E320 Special Edition
I hope I'm not the bearer of bad news, but the 60k mile service is around $1500, enjoy. The 100k mile is $2000. These are the prices at Fletcher Jones Motorcars in Fremont. If you need a discount or a referral, PM me.
When you go to the dealership, check the car and everything, I'd be afraid if the dealer "forgot" to do some things on this very large check up. Check it before it goes in for service and check it when it comes out.
The things to check are things such as radiator fluid, record the level and then put a marker on the cap to make sure that they actually purged the fluid and refilled it properly. A convenient marker is a tiny strip of black tape placed on the cap and on the reservoir tank. This is difficult to see and if it's broken, you can at least tell that the dealership checked your fluid (they're supposed to drain it and refill it). Do this for all fluids you can see in the engine bay (such as brake fluid).
Also, remind them to change the transmission oil, although the brochure may say that the transmission oil is a "lifetime/100k mile filling" they're supposed to replace it at the 60k service.
I've heard of some independent shops conveniently forgetting some aspects to the 60k mile service.
Regarding the spark plugs, if you drive a lot of city or are idling a lot, then you might want to consider getting the spark plugs changed while you're at it. This will probably make this service cost $2000 ($400 more) but it will increase the performance of the car. Otherwise, the spark plugs are recommended to be changed at 78k miles for the M271 engines (according to my service booklet, the brochure says 100k miles). And the dealership will change them out at the $2000 100k mile service.
Good luck.
patrick_y is offline   Reply With Quote
Old 07-24-2006, 09:39 PM   #3
thanks for the help patrick...I'll call local dealer and topline tomorrow...thanks
Tags
100000, 100k, 2002, africa, c320, cars, change, cost, fletcher, forum, fremont, good, jones, mile, motor, plugs, service, south, spark
Search this Thread:
Advanced Search
Display Modes Rate This Thread
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
Copyright © 2001-2012 InternetBrands, Inc. / MBWorld.org. All Rights Reserved.
Everyone's Personal Details
SEO by vBSEO 3.5.2
