Go Back   MBWorld.org Forums > Mercedes-Benz Sedans > C-Class (W203)
Sign in using an external account
Register Forgot Password?
Register Photos FAQ Members Insurance Search Today's Posts Mark Forums Read CarsGarageVendors
Welcome to MBWorld.org Forums
Sponsored by : My Mercedes Parts
Click Here
LinkBack Thread Tools Search this Thread Rate Thread Display Modes
Old 10-22-2006, 06:14 PM   #1
Drives: '02 C230 Coupe, '87 EVO II Turbo
Help! Where's the antenna amp on a C230 Coupe?
Hi,
My radio just stopped receiving a signal after the dealer worked on the pano roof of my '02 C230 Coupe. I think they might have accidentally disconnected the antenna amplifier. Where is it located? I want to look at it quick and see if I can reconnect it before I make the dealer do it.
Thanks!
To remove this ad, register today or login if you already are registered!
evo2turbo is offline   Reply With Quote
Old 10-22-2006, 07:49 PM   #2
Drives: W203 slightly modified
Send a message via MSN to benzmodz Send a message via Skype™ to benzmodz
Quote:
Originally Posted by evo2turbo View Post
Hi,
Thanks!
Did you look in your fuse box ? Are you asking if they disconnected the AMP power feed ? Take it back to them.
__________________
Modify your car and enjoy the benefits !
benzmodz is offline   Reply With Quote
Old 10-22-2006, 08:22 PM   #3
There is an amplifier somewhere behind the headliner (i think??) that amplifies the antenna signal. I think they disconnected accidentally disconnected the wires to it.
I looked through the fuse list and didn't see it listed, but I haven't checked all of the fuses yet.
Just to clarify, the headunit works fine, I just can't receive any radio stations anymore..
Old 10-22-2006, 08:25 PM   #4
Does the long distance car lock / unlock still work ?
If it is just the antenna connections then you still won't be able to sort it yourself. The C-pillar is a real cow to pull out.
__________________
Tags
2002, 2003, 2006, amp, amplifier, antenna, benz, box, c230, calvol, class, coupe, fuse, location, mercedes, wheres
Search this Thread:
Advanced Search
Display Modes Rate This Thread
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
Similar Threads
Thread Thread Starter Forum Replies Last Post
Why is drag coefficient of C230 Sedan < Coupe < 330? calvol C-Class (W203) 6 03-25-2003 02:49 PM
Headlight shape between C240 and C230 COupe!! cooly15 C-Class (W203) 3 03-13-2003 02:55 AM
C230 Coupe WINS V-car show C230K C-Class (W203) 12 06-05-2002 04:48 AM
KLEEMANN C230 Coupe Pulley Dyno Brandon @ Kleemann C-Class (W203) 39 03-09-2002 03:43 PM
C230 Coupe CD Player vs. Changer H Factor C-Class (W203) 2 11-16-2001 04:48 PM
Copyright © 2001-2012 InternetBrands, Inc. / MBWorld.org. All Rights Reserved.
Everyone's Personal Details
SEO by vBSEO 3.5.2
