Go Back   MBWorld.org Forums > Mercedes-Benz Sedans > C-Class (W203)
Sign in using an external account
Register Forgot Password?
Register Photos FAQ Members Insurance Search Today's Posts Mark Forums Read CarsGarageVendors
Welcome to MBWorld.org Forums
Sponsored by : My Mercedes Parts
Click Here
LinkBack Thread Tools Search this Thread Rate Thread Display Modes
Old 03-19-2007, 09:56 PM   #1
Benzino's Avatar
Drives: 03 c230
Front camber?
I just wore out some Toyo tires rather quickly, and I need a new pair already! I have rear camber adjustable arms and now I desperatly need front? Is there anything I can do?
To remove this ad, register today or login if you already are registered!
__________________
If it doesnt rub, it doesnt fit!
Maya's 19 x8.5- 9.5& CL custom exhaust setup
Benzino is offline   Reply With Quote
Old 03-19-2007, 10:10 PM   #2
Drives: Kia Rio with C230 badge
so you wanna get new camber arm, new tires?? or new shocks??
you worn out your rear tire and you need new front camber arms??
C230k_617 is offline   Reply With Quote
Old 03-19-2007, 10:20 PM   #3
Benzino's Avatar
Drives: 03 c230
Ok what I need is of some way to fix my front camber if such a thing exist. My rear is fine.
__________________
Old 03-20-2007, 06:49 AM   #4
sdsilverm3's Avatar
Drives: 2005 Mercedes Benz C55 AMG, 1999 Acura Integra GS-R Sedan (Both in white)
Send a message via AIM to sdsilverm3
How far off is your camber? OEM crash bolts will give you about +0.5 degrees.
How fast is "rather quickly"? I'm at -2.0 degrees in the front and I'm right at about 10k miles with my Toyo T1R's with plenty of tread left (even on the inside of the tire). Are you sure it isn't your toe that's causing the excessive wear?
__________________
'05 Mercedes-Benz C55 AMG
Car: Alabaster White | Black Leather w/Birdseye Maple Trim | Lighting Package | NAV | Steel Carter Plate (Option 481)
Mods: KW V2 Coilovers | 19x8.5F/19x9.5R BBS LM | Toyo T1R Tires (235/35/19F 265/30/19R) | Euroteck Carbon Fiber Front Lip | Evosport Painted Sidemarkers | OEM Flat Hood Emblem | Fuel Content Mod | Netherlands Setting Mod
sdsilverm3 is offline   Reply With Quote
Old 03-20-2007, 01:49 PM   #5
Benzino's Avatar
Drives: 03 c230
I see your rockin coilovers, Im sporting cut spings 1/2 coil on H & R's
__________________
Old 03-20-2007, 02:03 PM   #6
Benzino's Avatar
Drives: 03 c230
The oem +0.5 degrees is really nothing. 10k miles is not much at all. My outter edges wore out excessively and somewhat the inner. How much is that OEM bolt you say?
__________________
Old 03-20-2007, 03:52 PM   #7
sdsilverm3's Avatar
In my alignment thread a while back someone said the bolts are about $20.
If the outer edge of the tire is worn out AND your car is lowered, it probably isn't camber causing it.
__________________
Old 03-20-2007, 04:01 PM   #8
Benzino's Avatar
Drives: 03 c230
Any ideas? Sears said, camber kit would resolve it.
__________________
Old 03-20-2007, 05:13 PM   #9
Drives: w203
Sear's doesn't know ****!!!
mbzhumper is offline   Reply With Quote
Old 03-20-2007, 07:08 PM   #10
sdsilverm3's Avatar
Go to a real alignment shop and get some real readings.
__________________
Old 03-21-2007, 12:44 PM   #11
Benzino's Avatar
Drives: 03 c230
And I thought Sears was legit. Sears had a fantsy machine that is able to read the measurements of your current alignment job while this other sport I went to did everything by hand.
__________________
Old 03-21-2007, 03:07 PM   #12
sdsilverm3's Avatar
Doing it by hand isn't all that bad. One of the best alignment shops here in SD still does it by hand.
__________________
Old 03-21-2007, 03:18 PM   #13
KIRA's Avatar
Drives: 2002 C230 coupe , NOt THE AVATAR!!
Send a message via AIM to KIRA
Sears, Pepboy, Kragen, only do American and Japanese car and only made them more ****ty....
__________________
KIRA is offline   Reply With Quote
Old 03-21-2007, 09:43 PM   #14
W0n6_3d4n's Avatar
Drives: C200K (w204)
If your outer edge tyre is worn out, check the tyre pressure.
__________________
Check out my leather work blog: www.pedsnro.blogspot.com
2007 C200K W204
2001 C180 19 inch LD1 -SOLD-
Carlsson Coilover, Flat hood emblem, Black Grille, smoke taillight, Bi Xenon (finally), Wald bodykit.
ICE:
Denon DCT-R1 (HU)
Nakamichi SP-5
Dynaudio MW160 (7 inch jobbies)
SoundSplinter RL-p 12
ValveAudio Reference by D.Lumanauw
Tru Technology Hammer H-1
W0n6_3d4n is offline   Reply With Quote
Old 03-21-2007, 11:50 PM   #15
Benzino's Avatar
Drives: 03 c230
Its def not the tire pressure. Today i bought some adjustable alignment bolts. 11 bucks from Doval. They sell them piece by piece? So it came out to 22 bucks.
__________________
Search this Thread:
Advanced Search
Display Modes Rate This Thread
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
Similar Threads
Thread Thread Starter Forum Replies Last Post
FS: Adj. rear camber arms, C32 front BBK, 5mm H&R spacers pshek Classifieds 16 01-26-2006 02:02 PM
Front Camber Bolts rbaker C32 AMG, C55 AMG (W203) 6 02-09-2005 07:56 AM
Where to get front bolts for W202 Camber Adj. jmel777 C-Class (W202) 2 02-04-2005 09:26 PM
need front camber kit topdeez E-Class (W210) 8 06-14-2004 06:08 PM
ride height determines camber so will camber determine ride height ksing44 E-Class (W124) 0 05-22-2002 09:27 AM
Copyright © 2001-2012 InternetBrands, Inc. / MBWorld.org. All Rights Reserved.
Everyone's Personal Details
SEO by vBSEO 3.5.2
