Aftermarket HID Conversion Kits & required setting XENON=PRESENT thread
Rating: Thread Rating: 64 votes, 5.00 average.
Old 05-05-2011, 09:05 AM
  #1826
Jp's_C230k_W203's Avatar
2005 c230 kompressor
Are there certain models that require all this stuff? I installed my HIDs on my low beams and foglights without anything and they have been working perfect for months without any flickering or anything. I just installed h7 low beams 9006 fogs and the 4 ballasts. I just wa t to know I my certain model is different then everyone elses.
Old 05-05-2011, 09:39 AM
  #1827
W203E35's Avatar
2006 C350 Sport 6MT
It's a hit or miss. Some cars give problems some don't. I've never had a problem but I set it on anyway.
Old 05-05-2011, 09:44 AM
  #1828
Silver C's Avatar
C240
Ya xenon present doesn't affect halogen function. And in my case all aftermarket xenon works without xenon present, however any OEM xenon needs the xenon being set to present.
Old 05-07-2011, 10:13 AM
  #1829
purplecones's Avatar
2007 C280 4Matic
I just went to the dealership in Astoria, Queens in NYC and they have no idea about this option. I should have printed this step by step guide on how to do it http://www.mymbonline.com/forum/187-...n-present.html
Everytime I go to the dealership I have a bad experience. Anyone live in NYC and have a good place for MB service?
Old 06-07-2011, 07:54 PM
  #1830
abnerhagelsieb's Avatar
2004 C 200 Kompressor
LOL let me help you out here guys im not an amateur or a fan just trying to play to car expert, im an actual engineer and i have worked for a mayor mayor car electronic manufacturer which makes Instrument clusters, air bag sensors and so on for Beemer, Merc, Caddy, Alfa Romeo ETC.
THERE IS NOT SUCH THING AS REAL OF FAKE XENON LOL LOL AND LOL!!!
The xenon bulbs or HID ar just a high voltage bulbs that get the power out from as ballast wich increase voltage (not amps) up to 25,000 volts and this way the light can be brighter, now why xenon filled?? ok xenon is a inert gas that will keep the bulb filament to burn at that super high voltage.
so you can get a HID kit at ebay for 35 bucks or so, and yes THEY ARE ALL REEEAL XENON LOL, all the fancy cars uses the same system a ballast wich are feed with 12 VCC outputting 25,000 VCC and i mean ALL OF THE XENON KITS.
so nex time jut check out the original bulb size and purchase a fitting kit, now have in mind that we merc owners have a SAM on our trunk wich controls the light and if the power being draw from the head lights is less than 48 watts the light will go off and almost every aftermarket xenon kit works with 35 watts, so you can either look for a 55 watt kit (also available everywhere) or purchase a "error cancelling kit for hid"
and that's it!! no need to discuss real xenon or fake xenon, the only fake xenon i could think of is the ones that does not come in with a ballast they are only super high watt bulbs which will draw a huge amount of juice of your batt, and will eventually fade your head light, believe it or not, xenon ballast kits draws 1/2 of the power than regular bulbs
Old 06-07-2011, 08:24 PM
  #1831
Norwichdelta06's Avatar
2007 c230
do me a favor go into your settings and with your headlights switch Constant to Manual and see if that helps. Thats what worked for me!
Old 06-08-2011, 06:12 AM
  #1832
W203E35's Avatar
2006 C350 Sport 6MT
I believe the fake xenon comment is aimed at or referred to the cheap xenon kits. The ones with poor quality. The ones where the bulbs overheat. Couple of the members here had issues with bulbs melting and ballasts going bad one even had the color drastically change (I am no expert and don't know why this would happen). Although I have been lucky in that category I agree with your post. The only fake xenon that I know of are the halogen bulbs or led bulbs advertised as xenon.
Old 06-08-2011, 06:14 AM
  #1833
W203E35's Avatar
2006 C350 Sport 6MT
The Xenon setting does work for these kits. I enabled the Xenon feature with STAR on couple of members' cars. One of them is Rollnnn and he can vouch that the flickering/error went away. If I recall correctly he is using the DDM kit.
Edit:
My car never gave me such errors but I enabled it anyway. Another w203 owner (2007 c230) who is not a member on this forum also was having similar issues and the Xenon feature took care of it. This is why I believe it's mostly the kit itself and call it "a hit or miss".
Old 06-16-2011, 03:57 PM
  #1834
NOCSUCOW's Avatar
C230
I never had a clear answer, but when are the error cancellors necessary?
I haven't had xenon=present set yet, but I'm on a 55watt DDM kit using the cancellors. Do I really need them or are they only necessary for the 35watt kit as the factory bulbs were 55watt.
Are the cancellors doing more harm in with the 55watt?
Old 06-23-2011, 01:33 AM
  #1835
I haven't had xenon=present set yet, but I'm on a 55watt DDM kit using the canceller. Do I really need them or are they only necessary for the 35watt kit as the factory bulbs were 55watt.
Are the canceller doing more harm in with the 55watt?
They are not haming any thing but you dont need them.. Merc SAM sences if your lights are draining les than 4.1 Amps (12 VCC from batery/ 50 Watts) or more than 6 Amps; they light will turn of since the car will think they are out, your error cancelers are not doing any thing wrong if any thing they are helping you to avoid flicking for low voltage since they are only a 36V 4700 Micro farad capacitors but any how NO YOU DO NOT NEED THEM!
Hope this helps
Regards
Old 09-01-2011, 11:43 PM
  #1836
ranavic's Avatar
2001 Benz C320
I HAVE THE SAME CAR LIKE YOURS, 01 C320. I AM ALSO TRYING TO GET HID LIGHTS 5000K H7, DO I NEED ERROR ELIMINATOR AND HARNESS? DO I ALSO NEED TO GET THE XENON-PRESENT SET BY THE DEALER?
Old 09-02-2011, 12:04 AM
  #1837
phister's Avatar
06 C230 SS 6spd
you can first try and set the xenon to present to see if it stops the flickering, if not you'll want to get an error eliminator. You can also make your own custom error eliminator, theres a thread around here that a W211 member did using some capacitors from radio shack.
Old 09-02-2011, 12:50 AM
  #1838
bensitto's Avatar
S550, R350, GL550, ML63 AMG
Yeah, it's usually one or the other, Get xenon set to present at the dealer or through SDS, or use the error eliminator. I would go for the first option.
Old 02-01-2012, 09:58 PM
  #1839
tatvo's Avatar
2005 Mecedes C230
SheryarYO - HID Solution
SheryarYO,
Most auto (day running lights-DRL) lights run at only 60% to 80% power. When you had the flickering problem solved, what happened was the dealer/shop put in capacitors to regulate an exact power output. These caps will only work with the max. (100%) power output of the light system. That is why the lights no longer work using the DRL, not enough power. You can fix the problem by installing the optional wire harness most HID kits offer, just live without the DRL.
Old 02-14-2012, 12:22 AM
  #1840
beemerkiller87's Avatar
2003 c320
2003 c320 headlights
hey guys i have a ? can i replace my 03 c320 factory headlights with factory headlights from an 06 or 07 c320
Old 03-31-2012, 02:12 PM
  #1841
Melanie Albergo's Avatar
Exclamation
just want to know where your ballasts are mounted because I have 8k xenons for my lights and fog and they used 2 way tape im bringing it back and having them mount it,,but i dont want them to mount it anywhere they shouldn't,, where did you mount yours?? what is the correct spot to mount the ballast what bulb did you use for your side markers...led? because I also have the clear covers do you know anything about a power module for the right hand side I was told I needed a new one because my right headlight, fog light, and both side marker lights are out and also my outside temperature reads -40 any advice???
Old 06-03-2012, 09:23 PM
  #1842
iftigt0's Avatar
mercedes c240
HID KIT help
Hi,
I recently purchased a VVME 8000K hid kit with error cancelers.The ballast is 35W. After installing the kit, I noticed that there was buzzing sounds as the light flickered on and off. The intensity of the light was much lower than the standard halogen bulb. When I use the error cancelers, the light is on for a shorter amount of time and it still flickers and buzzes. I read above that buzzing is normal for the light as it warms up. I turned my car on for about 20 minutes but the bulb never increased in intensity and the light continued to flicker. Can someone please help me fix my light issue? I would greatly appreciate it.
Thank you,
Iftikhar
Old 06-06-2012, 08:41 AM
  #1843
Super Moderator
Glyn M Ruck's Avatar
Do you have Xenon = Present set by Star? I don't know how well cancellers work.
Otherwise you have an ignitor issue.
Old 06-06-2012, 10:29 AM
  #1844
iftigt0's Avatar
mercedes c240
I don't have the xenon=present. How do I do that?
Old 06-07-2012, 07:57 AM
  #1845
Super Moderator
Get a dealer to set Xenon = present with a Star DAS.
Old 06-07-2012, 09:21 AM
  #1846
ncmudbug's Avatar
2005 C230K, 2016 Honda CR-V, '74 Lotus Europa
My stealer will not work with non-MB parts. I suspect they would not set Xenon = present if the lights were not OEM.
Old 06-08-2012, 09:12 AM
  #1847
Super Moderator
I don't understand these dealers. If you download the method from the forum & tell them I want you to do this which will take 10 minutes & I'll pay you. No further expectations ~ I don't see the issue.
Old 06-08-2012, 10:04 AM
  #1848
ncmudbug's Avatar
I agree with you, Glyn. I suppose it's worth a try. I certainly could be overreacting or I may have misunderstood, but I got the impression from my stealer that they didn't want to do anything related to non OEM equipment.
Old 06-08-2012, 11:16 AM
  #1849
LILBENZ230's Avatar
2019 G70 6MT & 2022 Ford Maverick XL
Jim you are probably correct. MBUSA dealers do not want to be any part of "aftermarket" parts that they think may somehow "harm" the car. However, they don't mind at all using the wrong oil type or not servicing the transmissions properly. Apparently those things aren't harming the cars at all.
Old 06-08-2012, 02:40 PM
  #1850
Super Moderator
I guess one should then seek out an Indy with a Star.
You have already rated this thread Rating: Thread Rating: 64 votes, 5.00 average.
Quick Reply: Aftermarket HID Conversion Kits & required setting XENON=PRESENT thread
