Go Back   MBWorld.org Forums > Mercedes-Benz Sedans > C-Class (W203)
Sign in using an external account
Register Forgot Password?
Register Photos FAQ Members Insurance Search Today's Posts Mark Forums Read CarsGarageVendors
Welcome to MBWorld.org Forums
Sponsored by : My Mercedes Parts
Click Here
LinkBack Thread Tools Search this Thread Rate Thread Display Modes
Old 09-10-2007, 03:09 PM   #1
tommy's Avatar
Drives: 2002 C230
Symptoms of bad rear diff? And prices, if possible?
So, there's been a weird sound coming from the rear of my car for a while, off and on (was better when the new tires went on two weeks ago), and now it's gotten worse. It increases with speed, but is not so noticeable at high speeds.
I took it to a local tire shop today, and we ruled out the brakes, tires and rims. His thinking was that either it's a wheel bearing or the diff.
If it is the diff, how much labor time is involved, and anyone know what the price is of one from the dealer? Potomac has one for $425 - has anyone had any bad experience with them? Seems like people are happy with their diffs.
And the stock on the 2002s with manny is 3.27, correct? Would be interesting to go with something higher, but not feeling like playing around with any more non-cosmetic mods now - have paid way too much in repairs this summer already.
Gracias in advance! (and wish me luck)
To remove this ad, register today or login if you already are registered!
__________________
2002 Ccoupe, smurfalicious: OE chipped, RennTech pullied & rear spoiler, Carlsson lip, 18" OZ ultraleggera rims, RogueEngineering stud conversion, Eibach Pro springs/Koni Sport struts, Eibach swaybars, Supersprint headers, Eisenmann race exhaust, Magnaflow cat, Classic Soft Trim interior w/driver's Recaro Sport seat, clear OEM projector headlights, Sparco Racing shiftknob, Lightning Autosports alcantara shiftboot w/ Simoni gated shift surround
tommy is offline   Reply With Quote
Old 09-10-2007, 03:14 PM   #2
dmatre's Avatar
Drives: '03 C230 Sport Sedan
Does the noise change in pitch or volume when you go around a corner? If yes, then it's more likely that the problem is a bad wheel bearing.
Rear end problems are usually a growl/roar from the rear, and are indicative of a broken/chipped tooth in the ring gear. Maybe your shop can put it on a lift and put it it gear. Then you could check the diff with a stethoscope.
I haven't priced them out, but $425 sounds almost too good to be true for a differential. I'm thinking that we went more than that for an '88 Astro van.
__________________
2003 C230 Sport Sedan
dmatre is offline   Reply With Quote
Old 09-10-2007, 03:40 PM   #3
jolenicz's Avatar
Drives: 2002 C230 Coupe
When my rear diff went, I thought I had a hole in my exhaust. At different speeds, the noise would be louder or quieter. Mostly a hum kind of noise, until the gears shattered.
The dealer offered to install a MB remanufactured diff. The part cost was $1440. At the advice of my aftermarket warranty, I found my own used diff. for $480 shipped. I forget the labor charge, but I should be able to find the sheet at home (the dealer installed the used diff).
If you do install a used one, mention to the installer that they should check out the diff before they install it. My dealer just assumed it was good and installed it, only to find some of the bolts were loose and the diff came apart. Fortunately, the dealer was sufficiently embarassed by this oversight to fix the problem quickly at no labor cost.
__________________
2002 C230K Orion Blue 6-Speed Coupe
AMG Style III 18" wheels (225-40-18 8.5" front, 255-35-18 9.5" rear)
H&R coilovers, StopTech Slotted Rotors
jolenicz is offline   Reply With Quote
Old 09-10-2007, 04:00 PM   #4
tommy's Avatar
Drives: 2002 C230
Sound doesn't change in corners.
That's good that the dealer installed the used diff - that's kind of surprising. If not, there's a local shop that will do it if necessary.
Thanks for the information. Hopefully it's a cheap(ish) fix. In any case, I'm off to Nova Scotia on Friday, and am dropping the car off at the dealer the day before. Which means that I won't be able to dwell on it over the weekend, as I will be drunk on Canadian beer, and embarrassing myself by making fun of their accents.
__________________
Old 09-10-2007, 07:33 PM   #5
Drives: 2002 C230K Coupe
does it sound like 'trrrrrrrrrrrr' between between 40 - 70 mph?
trisonics is offline   Reply With Quote
Old 09-11-2007, 09:44 AM   #6
tommy's Avatar
Drives: 2002 C230
Quote:
Not really. Just sounds like an odd ticking that blurs into a repeating whoomp sound with speed. Oh well - enjoying driving the crx in the finally cooler weather - no a/c sucks in summer. I'm dreading the bill on this repair, though.
__________________
Old 09-11-2007, 12:45 PM   #7
Drives: '11 E350
There's a TSB on the differential for the early C.....some are mounted too close to the frame and contact it causing a noise. Can't remember the fix but it should be easy enough to check.
mleskovar is offline   Reply With Quote
Old 09-11-2007, 09:18 PM   #8
pshek's Avatar
Drives: 2003 C-Class Sportcoupe
Tommy,
I may have my diff center section up for sale in a few weeks. I just had the diff oil changed for regular maintance using Synergen oil about 2 weeks ago. It's got 41,000 miles on it. 3.46 final drive. Your coupe has a 3.27 final drive ratio. If you want it, I'll give you a good deal on it.
__________________
http://www.mbworld.org/forums/image.php?type=sigpic&userid=16395&dateline=124369  9308
pshek is offline   Reply With Quote
Old 09-13-2007, 08:14 AM   #9
HeirKranz's Avatar
Drives: C230k coupe 500sec convertible
Ive gone through 3 so far-----good luck---seems the early 2002 cars were prone to spider gear failure---
i bought one from potomic off the 240 which has the lower gear ratio--for 425 shipped as well---but if you do that say goodbye to first gear!!!! you can start out in second and @ 60 your RPMs will be around 3000
fun around town but bad on the interstate--- stay away from 2002 all together if they are not sure the manufacture date of the car!!
I sold my other one to a buddy in NY you all might know for i think $500 shipped to NY from FL-- at that time i thing potomic didn't have much in inventory so their prices were more around 500+ shipping
__________________
"Jealous One's Envy" 2002 Coupe:Manual 6spd:Kleemann pulley:supersprint header:AMG C32 Brakes & sways:H&R cup kit:K&N filter:VDO Boost guage:Lorinser roof spoiler:BRABUS chrome pedals:Clear bumper lights:AMG grill:Real horns from w126
Off car currently :3:67 rear end:eisenmann race muffler:05 tails
Other cars:Euro AMG 500SEC + Euro 500sec convertible, US 500sec, 500sel, 300d
W126 & W203 Pictures
HeirKranz is offline   Reply With Quote
Old 09-19-2007, 09:10 AM   #10
tommy's Avatar
Drives: 2002 C230
Well, it ended up being the wheel bearing. So not totally inexpensive, but not as bad as a diff. Picked it up this morning, and sounds perfect. Well, loud, of course, but perfect to me.
Thanks for the help and suggestions.
__________________
Old 09-19-2007, 10:15 AM   #11
HeirKranz's Avatar
tommy, did it have any affect when you were downshifting??? if so I need to do the same job you just had to do---Im getting a little noise but thought it might be the center support bearing??? only when U downshift, no clicking
__________________
Old 09-19-2007, 11:25 AM   #12
tommy's Avatar
Drives: 2002 C230
Quote:
No, was only affected by increased speed. Sounds like you've got a different animal. Aren't Benzes fun? I'll be eyeing a Honda Fit in the Spring, I'm guessing. Though I'll get nothing on trade-in, and no one in the family wants to even take the coupey off my hands for free. Lemons are scary, even for free!
__________________
Old 09-20-2007, 10:42 PM   #13
Drives: 02 C230 Sportcoupe
After feeling my C230 had way too much rubber on the rear tires I have done everything I could to remove the rubber and now I have what sounds like a spin of the wheel on The Price is Right. I took car to a repair facility and they said I have a bad spider gear - only 19K miles on an 02 - The car accelerates great but just clickity clicks the faster you go the more it clicks, accelerating is quiteter that cruising out of gear. Any one have any input, I just bought the Speed Tuning USA ECU upgrade and want to get this urban assult vehicle back on the road. Does any one have one, is Potomac the place to go? Any special tricks for install?
kleemann C230 is offline   Reply With Quote
Old 09-21-2007, 01:19 PM   #14
HeirKranz's Avatar
have to pull down the sway bar in the rear (leave the tie rods atteched) to keep from dropping this in the driveway----pretty simple job if you are strong, not if you cannot pick up the diff with one hand (or at least curl it on the ground lol)
empty it for a little less weight.
-wear padded gloves (finger smashing good time if dropped)
-you are skating on thin ice, you will hear eventually a loud POP and then every rotation of the drive shaft will be a lurch ---lurch ---lurch before you gent sent to the side of the road and stranded
__________________
Old 09-22-2007, 06:34 PM   #15
I got lucky and found the rear diff for $400 by going on www.uneedapart.com and almost right away Randay at Stockton Auto 800-235-8733 emailed me back with a response - I have ordered it up, will see it late next week since they are in CA and I am in FL. I checked on getting an 06 rear but he said the Coupe did not list that year and would need more info to try to locate that one, is it true the 06 has a better diff, if so perhaps any input here would help out when someone else has this problem and they could locate the better rear end.
Old 09-25-2007, 02:04 AM   #16
Quoting my own post, I found out that the 'trrrrrr' noise my car is making is indeed bad differential or pinion bearing in the differential (whatever that means). Mechanic is quoting 1000 bucks for repair in worst case scenario
I will trade it for a civic
Old 09-25-2007, 01:01 PM   #17
HeirKranz's Avatar
No Need For An 06 Diff--just Not One From The Early 02
__________________
Old 09-25-2007, 05:02 PM   #18
Just got this email on Tuesday Sept 25, 07 - For an 02 C230 Rear Diff - I paid $475 delivered on Friday**********
Car Parts Direct 1-866-554-7278
I have a rear differential available in good condition with a 30 day warranty for $500.00 and that includes shipping.
Quote #: 66059
*** We will try to beat any other competitors price!***
Thanks,
Jamie Johnson
1-866-554-PART (7278)
jamie@carpartsdirectllc.com
www.carpartsdirectllc.com
MSN Messenger: jamie@carpartsdirectllc.com VISA, MasterCard, Check, PayPal
Old 10-03-2007, 08:33 PM   #19
Poorer by 1000 bucks now and the noise is still there. Got the bearings replaced, so will probably buy a new differential gear and see if it fixes the problem.
Old 10-03-2007, 09:48 PM   #20
Outland's Avatar
Drives: 2002 C230 Coupe(M111)
Quote:
When I blew the diff on mine, it had 23K on it. And the car was in stock configuration for a dealer visit a few weeks earlier, for 'rear end noise'. If youre hearing noise now, your a few weeks from a failure. Just wait, its a freaky sensation.
I half expect that the replacement will fail at some point.
__________________
1993 Grand Cherokee Limited(just passed 250,000miles)
1986 Corvette
2002 Mercedes-Benz C230 Kompressor Coupe- slightly modified.
2004 Chrysler Pacifica[ Gone, and missed]
2008 Honda Odyssey EX-L[LEMONED]
2009 Honda Odyseey EX-L
2007 Harley-Davidson Night Rod Special[gone]
2009 Harley-Davidson Road King Classic
This space for rent.
Outland is offline   Reply With Quote
Old 10-03-2007, 09:50 PM   #21
Outland's Avatar
Quote #: 66059
Thanks,
Jamie Johnson
Can we use the C320 part from a later year? My guess is the gears were too brittle or were over hardened in the 02's. Sooooo many people have had failures.
__________________
1986 Corvette
Old 10-04-2007, 06:37 AM   #22
HeirKranz's Avatar
its just the early 02s that have the problem.....you can use one from earlier or later i think till 05
__________________
Tags
bad, bearing, car, cherokee, chrysler, diff, differential, end, failure, gears, give, grand, pacifica, rear, symptoms, vehicle
Search this Thread:
Advanced Search
Display Modes Rate This Thread
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
Copyright © 2001-2012 InternetBrands, Inc. / MBWorld.org. All Rights Reserved.
Everyone's Personal Details
SEO by vBSEO 3.5.2
