M271 - rough idle - the $12 hose
Old 10-29-2007, 01:13 PM
mckay's Avatar
Mercedes
I finally replaced this hose this past weekend, what a PITA!
1. Removing the entire intake is now a 5 min job, easy.
2. Putting the intake back together is a 1hr job, stupid hose down the firewall doesn't line up very well and requires 2 people.
3. The $12 hose was split and cracked. Its made of a rubber that is not oil resistant. How stupid is that?
4. The hose attaches to the engine in the most awkward spot, hard to get tools in there to tighten the new clamp.
A job that should've taken 30 mins took 2hrs! German engineers do not engineer for maintenance!
Old 10-29-2007, 01:25 PM
mig888's Avatar
EVE
Ah now you know what I mean about the firewall hose =). Did you use a special clamp?
Old 10-29-2007, 05:16 PM
RES
RES's Avatar
2005 C55, 1988 260E, 2000 Chevrolet Silverado
Craftsman make the clamp pliers for the factory clamps. It has a plier part that controls through a cable a set of teeth that you put on the clamp use one hand to compress and lock the pliers and your done. If your going to work on your own car I would buy these. @ $39.00 at Sears. It will take you 30 seconds to remove and install that puppy after you get these.
Old 10-29-2007, 05:42 PM
mig888's Avatar
EVE
Originally Posted by Russell Stevens
Craftsman make the clamp pliers for the factory clamps. It has a plier part that controls through a cable a set of teeth that you put on the clamp use one hand to compress and look the pliers and your done. If your going to work on your own car I would buy these. @ $39.00 at Sears. It will take you 30 seconds to remove and install that puppy after you get these.
Thank you sir - I will take this suggestion seriously =).
Old 10-29-2007, 05:51 PM
patrick_y's Avatar
2006 E55 and 2002 E320
Can we get a picture of this $12 hose in the engine bay? Or is it already covered up by other parts of the intake?
Thanks in advance.
Old 10-30-2007, 11:05 AM
GermanCarShow's Avatar
2017 C43, 1980 450SL, 1966 230SL, 2006 Jeep Rubicon
Which is the M271 engine? In your "Vehicle I drive" entry, you are not specific.
Old 10-30-2007, 11:07 AM
mig888's Avatar
EVE
2003-2005 C230Kompressors (US)
Old 10-30-2007, 03:37 PM
mckay's Avatar
Mercedes
Thanks in advance.
Here's pics.
The hose would be where the red line is, behind the throttle body and under the air-filter housing.
Attached Thumbnails M271 - rough idle - the  hose-12-hose.jpg   M271 - rough idle - the  hose-hose.invoice.jpg
Old 10-30-2007, 04:09 PM
mig888's Avatar
EVE
yup, that's the culprit.
Old 10-30-2007, 10:05 PM
Super Moderator
splinter's Avatar
GMC - Miata - Trek - P-Car
MB is aware of another hose that is prone to failure. From a recent issue of StarTech:
https://www.mbwholesaleparts.com/Sta.../jsp/issue.jsp
The archives tab is worth a search...lots of good technical info.
Link to FSB:
https://www.mbwholesaleparts.com/Sta...SBSeptST07.pdf
Old 10-30-2007, 10:11 PM
Saprissa's Avatar
Location: San Diego, CA & San Jose, Costa Rica & Stuttgart, Germany
1959 220S / 1979 230 G / 2002 A210 AMG / 2003 C320 SC / 2004.5 C320 SS / 2005 ML350 SE / 2008 smart
of the 1.8L variety
the 2001-2002 C230K's were 2.3L / M111 engine
Old 10-30-2007, 10:25 PM
mig888's Avatar
EVE
LOL - I like step 1: remove the supercharger.
Old 10-31-2007, 02:22 AM
patrick_y's Avatar
Here's pics.
Thanks!
Old 10-31-2007, 07:42 AM
mckay's Avatar
Mercedes
Link to FSB:
Are you f***ing kidding me? Remove the supercharger!
So 4hr+ labour to replace yet another $12 hose that MB f***ed up.
I hate this car.
Old 03-13-2008, 08:36 PM
slammer111's Avatar
2003 C230K Coupe Orion Blue
For the record, the hose mentioned in Splinter's and Mckay's posts refers to the same thing. There is only ONE hose that is flawed, and this can easily be DIYed WITHOUT removing the supercharger. Just look for my thread
Old 03-30-2008, 10:57 AM
aolsen's Avatar
2013 S550, CLS500, ‘03 SL500, “92 190E Sportline
Unhappy
Ok so the dealer fixed this hose under the recall on 3/12/08. Yesterday my car starts doing the same thing it did when the hose went bad, rough idle, loss in power, and CEL light came on...oh man...i'm not liking this at all...
Quick Reply: M271 - rough idle - the $12 hose
