Bad Throttle Position Sensor?
Rating: Thread Rating: 2 votes, 5.00 average.
Old 08-22-2016, 09:44 PM
  #51
zuzu_pali's Avatar
2004 clk500
Originally Posted by Glyn M Ruck
I'm a retired oilco man - see my profile. I have hundreds of Benz diagrams on my computer - mainly from MBSA. Filing system sucks. PM C230SportCoup for reset. He has the same car. How do you know the reset did not work?
Do you have the vaccume line for the 2004 clk500 diagram once I turn the car on esp defective comes on and rap is high and I get throttle pedal position sensor
Old 03-24-2018, 03:10 PM
  #52
Justin-case's Avatar
2007 E350 Wagon 4matic
Originally Posted by DarthBudice
I had a very similar problem - stomp the throttle and absolutely nothing
for 3 - 5 seconds.
Mine was a simple vacuum leak I fixed with a 10 cent hose clamp.
I suspect it cleared up when the engine was restarted due to clearing
the short term fuel trims. All the un-metered air entering the intake
was causing the ME to constantly adjust fuel trims because the O2
sensors kept reporting lean condition (extra air with no extra fuel).
I have one of the OBD-II interfaces from o b d diagnostics . com -
I see after clamping that hose down my short term trims are always at 0 now...
FYI I haven't had to use the throttle reset in 4 months or so now...
which hose did yiu have the leak out of?
Old 11-25-2018, 06:21 AM
  #53
Mikchek's Avatar
2001 S500 (W220) / 2007 GL450 (X164)
Rev - remember to do the calibration procedure.
what is the calibration procedure? i was told it was just plug and play
Old 11-28-2019, 06:23 PM
  #54
Charly123's Avatar
Mercedes Benz C350 Sport 2007
Can please tell me how you resolve it, i got the same problem?, i all ready replace the accelerator an nothing.
You have already rated this thread Rating: Thread Rating: 2 votes, 5.00 average.
Quick Reply: Bad Throttle Position Sensor?
