Sign in using an external account
| C-Class (W203) 2001-2007, C160, C180, C200, C220, C230, C240, C270, C280, C300, C320, C230K, C350, Coupe
Sponsored by : My Mercedes Parts ![]() |
LinkBack | Thread Tools | Search this Thread |
Rating:
Display Modes |
#26 | |||
Super Moderator
Drives: 2007 C230SS
__________________
-- John Anderson ![]() Johnand's official thread Johnand's oil analysis thread Official Ethanol (E85) Thread |
#27 |
Super Moderator
Drives: GMC
#28 |
Drives: 2002 C230K
Works Much Better
I just wanted to say thanks for posting this. The automatic transmission on my 02 C230K was shifting pretty hard. Thanks for the instructions - my car shifts much better now!
One thing - I couldn't get the drain plug to open, so I sucked about 3L of fluid from the top fill tube with my MityVac... then when I dropped the pan, there wasn't hardly any mess. I'm thinking about changing out a few liters of fluid using the MityVac after each oil change since I didn't do a complete flush. Cheers! |
#29 |
Super Moderator
Drives: late 2009 CLK 350 Coupe Elegance, '65 Jaguar S Type wires
This is a very interesting thread & good learning for all. One question I have is - was this a truly representative oil sample & how was the sample taken?
The sample results suck - almost typical of a transmission in trouble. The results are so bad that I would suspect the sample came from the dregs in the oil pan - not what the transmission sees post filter. The Pentane insolubles show a level of oxidation. It's a pity that a TAN (Total Acid Number) was not performed to better show just how bad this was. Last edited by Glyn M Ruck; 10-26-2008 at 04:54 AM. |
#30 |
Drives: Here's Johnny!
All I know is that everything is great now. The sample came straight from the cooler hose.
__________________
2002 C230 Sport Coup ASP Pulley-Supersprint Header-Remus Muffler- TEIN SS Coilovers AMG; Wheels, 22mm AMG Front sway bar, HR 19mm rear bar, C32 Brakes Tinted Windows- 2005 Tails, Grill & Blinkers-Clear Sides Bi-Xenon Headlights! Clear Fogs w/Philips Crystal Vision bulbs Audio 10 Renntech style Spoiler Supercharger Muffler Deleted! "Aero Turbine" AR20 Rasp Eliminator (Resonator)
#31 | |
Super Moderator
Quote:
I'm spoilt - I'm used to having a good analysis & a ISO cleanliness level to have a look at which gives you a partical size distribution. Last edited by Glyn M Ruck; 10-27-2008 at 04:51 AM. |
#32 | |
Quote:
As in I had a dealer "flush" the tranny, but saw that in fact only 4 quarts got changed, if at all at 80 or 90K miles. I checked after they did it and it was green then, so likely not, and the test pretty well proves it, though if you only changed 1/2 your motor oil or less, you might see the same type of result. I plan to do it again at 60K miles as suggested in the maint. sheets. So since I couldn't seem to get any of those fools to do it right, I was forced to DIY, which is nothing new. My local guy is suggesting changing it every 30K miles! Which seems excessive but he feels that might result in some long and trouble free transmissions. It's a PIA without a lift.
__________________
#33 | |
Super Moderator
Quote:
Saw an interesting statistic yesterday - South Africa has the 4th largest offtake of AMG vehicles wordwide - the autos in those things must take a hammering. |
#34 |
Offtake? Thats not a word that gets much use in the US.
How do you mean? You mean 4th in terms of sales?
__________________
#35 |
Super Moderator
#36 |
Drives: 2002 C230 Coupe
I discovered that I had a Valeo radiator on my '02 c230k, so I replaced it with a Behr last week and did a tranny flush. Everything went ok, except I had trouble getting the hose clamp to hold the 1/2" flushing hose to the transmission cooler line. It ended up poping off a couple of times and spewing fluid everywhere.
Sent a fluid sample to Blackstone and it looks like if I had any coolant contamination, it was minimal. In fact, it indicated 0.0% water, so I think I'm ok. Here's a copy of my report. D66132.pdf Also replaced a leaking transmisson electrical plug shown in this link: http://www.installuniversity.com/mb/...ans_oring.html C230 Sport Coup and Splinter, thanks for the DIY's...they were definately a big help. |
#37 | |
Quote:
Can you guys remind me Why you didn't pop off the right side undertray, unscrew the banjo bolt and flush the fluid directly from the tranny? I'm planning on flushing my tranny this weekend and am wondering if there is any time or hassle savings in draining from the radiator. thanks! |
#38 | |
Well, unless you have access to a lift, doing the banjo bolt thing is, well,
you'll see when you remove just the pan, and replace the filter. Minimal space, and I don't enjoy tranny fluid showers while laying on my back, though I knew this one kinky chic...but thats another story. ![]() It's just a personal choice. The banjo bolt thing makes more sense on a lift, but then someone has to start and stop the car. So, that means, they'd have to be in the car... on the lift???? Hmmmmm.... just go with the rad function. It's a little bit of a pain wrastling it out of it's plastic clippy thingy's on the rad, but not that bad. Be sure to replace the o ring! See pn I posted for C230 if you have 2002, not the one on the C32 that Splinter uses. As you saw in my pics, it's pretty easy to drain at the rad, and directly into a container for curbside recycle. Sweet. As far as the other guy who said the hose came off, well, be sure to use a hose clamp, just avoids that issue. Good job on replacing the rad and checking the fluid. Whew! Another Beeee U ty Full 2002 coupe saved from destruction. Post pics please! Not all Valeo rads are supposedly bad, but who wants to find out? Not me, I woulda done the same thing. Quote:
__________________
#39 | |
Super Moderator
Quote:
__________________
![]() Llandudno, Cape Town, South Africa |
#40 |
I think the problem with my hose coming off is that the 1/2" hose is just a little too large of a diameter. I did use a hose clamp, but there was still a bit of play with it tightened down. Is that fitting metal or plastic? I possibly could have tightened it more, but was afraid of over-tightening the clamp and breaking the fitting if it were plastic. You mentioned that you used a 3/8" hose and that was too small. Sounds like a 7/8" hose would be ideal, but probably tough to find (hoses available at my local Lowes went from 3/8" to 1/2"). Maybe a thick layer of teflon tape around the connecter would have helped.
#41 |
Drives: 2001 C320
I owe a HUGE thanks to Splinter and C230 Sport Coup for their threads regarding the radiator swap (From a Valeo to a Behr) and for this Transmission Flush thread! I just did both of these jobs on Saturday and couldn't have done it if it weren't for these guys and the other contributors to their threads, so again, many thanks!!!
__________________
BOAT FOR SALE! LINK |
#42 |
Super Moderator
They are both, indeed, a huge asset to the forum
__________________
#43 |
Glad you could make sense of all the jumbled info.
And glad you got it right. We get people around here once in a while posting that they drained the tranny and then poured 8 quarts of tranny fluid into the sump, bloew up the motor, because they didn't do the reading in advance. Excellent! Another benzo saved from the wrecking ball.
__________________
#44 | |
Quote:
Like I said, I was able to save the day, by heating the hose slightly over the stove, stuffing it over a the handle of a 1/2" ratchet to stretch it, and then it was the right size.
__________________
#45 | |
Drives: 2001 C320
Quote:
__________________
#46 |
Hmmmm....mine had a magnet....
__________________
#47 |
Super Moderator
Indeed strange
__________________
#48 | |
Sorry, my mistake. I meant 7/16", not 7/8".
Quote:
#49 |
Not sure why I didn't think of this at the time, but for those of you replacing a radiator before your flush, you can unscrew the old transmission cooler line adapter from the old radiator and use that as a flush hose adapter. It screws right off and then you clamp a hose on it and reconnect it to the transmission cooler line. It allows you a little more room to clamp and it looks like a 3/8" hose would fit nicely over the threads.
For anyone that doesn't have an old radiator, you can PM me and I'll send you one of mine (adapter, not a radiator). All I ask is that you do the same and send it to the next person from the forum that asks.
#50 | |
Quote:
I won't be needing this for a little while, but I'd be happy to take one off your hands. ![]() Well, actually I think I'll be fine, i saved the hose etc. from the 1st time. Next time around I may just flush without messing with the pan at all 40K miles after the 1st time, then drop the pan the next time around...but it's running great now, so not messing with it. Interesting how all your numbers are lower in your oil report, but the, lead, manganese, potassium, sodium, calcium, magnesium (mine was 0, yours was 2) and zinc are higher....wierd. I'm sure Glyn will tell us what it means......
__________________
| Tags |
| 2002, 2005, 230, bad, c230, change, converter, gasket, leak, mb, oil, pan, service, torque, trans, transmission |
| Currently Active Users Viewing This Thread: 1 (0 members and 1 guests) | |
| Display Modes | Rate This Thread |
