Front end rubber cruching noise over bumps
Old 05-18-2008, 02:21 PM
mbhackie's Avatar
02 C240 Black
As the title states I've been getting this "rubber cruching" noise while driving slowly over bumpy or uneven road surfaces. I raised my car on a lift and everything feels tight. I have zero play in all the balljoints. My thrust arm bushings are dry (no fluid leaking out of them or tears). So I am thinking it might be the strut mounts or struts any ideas?
Old 05-18-2008, 05:46 PM
saetneta's Avatar
2002 C230K
I know you checked --- but sounds like bushings to me.
Old 05-18-2008, 05:56 PM
JLD2k3's Avatar
2002 C320
That's what I thought, too. Get a set of metric sockets/wrenches and make sure the endlinks are supertight.
Old 05-18-2008, 09:11 PM
JE8
JE8's Avatar
C240
C240 front end noise
My C240 has a squeak in front end when going over bumps.....some days its worse than others....is it bushings?? How much $ to repair?
Thx
Old 05-18-2008, 09:29 PM
JLD2k3's Avatar
2002 C320
Thx
Front sway bar bushings are around $80/side. If you can do it yourself, $30. Takes 10 minutes once you get the car up/side.
Check to make sure they're tight first before you take it to the dealer.
Old 05-18-2008, 09:49 PM
JE8
JE8's Avatar
C240
Are they visible from under car on floor jack? What should I be looking for? Sorry for the dumb questions
Old 05-18-2008, 10:10 PM
JLD2k3's Avatar
2002 C320
Not dumb questions, 2 months ago I didn't know any of this stuff either. I'm no expert, but this forum can help you save a lot of trouble and money at the shop.
Check out InstallUniversity.com for the front sway bar install step by step. The endlinks are where the sway bar meets the tie rod, and there is a bushing that pads that link. If that nut/bolt is loose you will get a clunking sound going over bumps and especially when you shift the weight from one side to the other.
Also, don't get under the car with just a floor jack. Use ramps or jack stands. This is for your safety. It will be easier to deal with the sway bars using ramps.
Old 05-18-2008, 10:13 PM
JE8
JE8's Avatar
C240
THANK YOU !!!!!
Old 05-18-2008, 10:44 PM
JLD2k3's Avatar
2002 C320
THANK YOU !!!!!
Post your findings after you check it out. Also, grab a hold of the tie rod and shake the ***** out of it. Do that before and after you tighten (if you need to tighten). If it moves around and feels like popping a knuckle, try to tighten the nut, if after tightening it still does it, you need a new bushing.
If it was loose and tightening it fixes it, get some Loctite Blue threadlock ($3 at Lowe's) and put that on there. Tighten the ***** out of it and let the threadlock sit for a half hour or so. The MB spec is 18 footpounds, but I learned it's better to crank it.
Sorry for the multiple posts, I just figured if you're anything like me you'll prefer to knock it out in one shot if possible.
Old 05-18-2008, 10:54 PM
JE8
JE8's Avatar
C240
excellent info
just read this....
http://www.installuniversity.com/mb/...frontsway.html
I 'll give it a try tomorrow
Thx again
Old 05-20-2008, 05:55 PM
mbhackie's Avatar
02 C240 Black
Thanks for all the replies guys.
Question... when you say...
Are you suggesting the sway bar bushings that everyone is talking about or my thrust arm hydro bushings?
Old 05-20-2008, 06:31 PM
JE8
JE8's Avatar
C240
front end squeak
I just greased the sway bar bushings today...helped alot ...although not 100% fixed.....I guess next step is to replace them????
Rookie question......What the heck is a Thrust Arm Hydro Bushing????
Old 05-20-2008, 07:07 PM
Mu9enx's Avatar
01' C32o
man i need some sways.. car is starting to sound like jordan's musical brakes, lol.
Old 05-20-2008, 09:45 PM
mbhackie's Avatar
02 C240 Black
The thrust/control arms use fluid filled pressed in bushings. Check this out...
https://mbworld.org/forums/showthrea...grease+bushing
Old 03-08-2009, 01:18 PM
pointman's Avatar
a car that can't do the throttle reset.
Hey guys, old thread but the topic I am curious about. Does the failure of the bushings sound like a rubbing... almost like when you rub a wheel on the fender?
And is this an issue that can create further problems? Thanks.
Old 03-08-2009, 04:27 PM
Super Moderator
Glyn M Ruck's Avatar
Read this & check sway bushes & links
https://mbworld.org/forums/attachmen...h-bulletin.pdf
https://mbworld.org/forums/c-class-w...need-help.html
Old 03-09-2009, 02:15 PM
pointman's Avatar
Nice. Thanks for the good info. Gonna check it out. I hope you are right. The noise has me worried.
Old 03-27-2009, 09:52 PM
danev6972's Avatar
2003 C240
Call me ignorant but as I was shopping online for bushings I saw
"rear outer control arm bushing, Lower control arm bushing" and that got me confused!
http://www.car-stuff.com/store/?N=11...668+11921+9198
How many do I need to replace all front & rear?
Is this correct....?
FRONT : 1 left Low arm & 1 right Low arm =2
REAR: 1 left Low arm & 1 right Low arm =2
Total of 4 LC arm bushing
OR
FRONT: 2 left / 2 right = 4
REAR: 1 outer arm Left side & 1 outer arm right
Total of 2 Out arm bushing
DOes the FRONT have an outer arm bushing too?
Does the REAR have a lower arm bushing?
I am so ignorant about suspension...SORRY.
Old 08-22-2009, 02:54 AM
swiftbmx's Avatar
2003 C320 4matic sport
sorry to drag up an old thread but after reading through old topics for an hour, I think i confused myself more.
I'm having the same issues as the OP, am i suppose to e getting sway bar bushings, thrust arm bushings, control arms bushings, or something else? What about for the rear? How much am I looking at?
Old 08-22-2009, 03:54 AM
Super Moderator
OK - suspect number one is the castor bushes (also known as thrust arm bushes or control arm bushes). They crack & leak & I have posted the factory bulletin multiple times.
Suspect number two are sway bushes and links. All are cheap. Castor bushes are under $20 each.
See pic - no 18 is castor bush. sway bushes & links are obvious.
Old 09-22-2009, 10:03 PM
holycaoAMG's Avatar
A Car
Quick Question
I read the posts above but cant seem to fine a solid answer.
I have this knocking and clunk sound in the front end suspension. On normal, uneven roads, theres a knocking sound that feels like my front end is lose and going over speed bumps, theres a clunk sound.
Already had my strut bushings replaced, so no more squeking sound, and had the sway bar bearing lubricated, all noise was gone, but after 10k miles later, the clunk/knocking is now audiable. Im thinking its the sway bar bushings, but my mechanic guesses its the sway bar links.
Can someone tell me exactly what needs to be replaced?
Both sway bar bushings/links all together?
Thanks,
Old 09-23-2009, 12:39 AM
LILBENZ230's Avatar
2019 G70 6MT & 2022 Ford Maverick XL
Old 09-23-2009, 08:40 AM
Super Moderator
Yep!
Old 09-23-2009, 09:48 AM
Super Moderator
johnand's Avatar
2007 C230SS; 2014 ML350 BT
Thanks,
Sounds like swaybar endlinks. Try those 1st.
Old 09-23-2009, 08:16 PM
holycaoAMG's Avatar
A Car
Thing is my mechanic wants to charge me $70 just to diagnose the problem, i said no, as i know the problem is either links or bushings. I want to get the entire problem fix the first time and not have to keep bringing it back cause he will keep charging me everytime i come see him. Im doing some major maintainence on the car right now, and every penny i can save is worth everything right now.
Thats why i want to nail down exactly what the problem is.
I might as well do both links and bushings, but i wanted to clearify if i only need links.
Quick Reply: Front end rubber cruching noise over bumps
