DIY - Fuel Filter Replacement
Rating: Thread Rating: 6 votes, 5.00 average.
Old 07-23-2010, 02:08 AM
BabyBenz6spd's Avatar
2005 C230 Sedan 6spd
Just changed my fuel filter today, damn these MB clamps are hard to take off~
Yes, replace these clamps with screw driver ones from Autozone~ and make sure you wear latex gloves and safety goggles.
Old 07-23-2010, 02:16 AM
laneshift's Avatar
C240
Will any brand do? Surely, Bosch will last longer, I suppose. Just curious before I make the decision to just give into the dealership's OEM 115 dollar part instead of the 59.99 dollar part at autozone.
Old 07-23-2010, 07:59 AM
Super Moderator
johnand's Avatar
2007 C230SS; 2014 ML350 BT
Lane, the OEM filter is a MAHLE-KNECHT, and is available at RM European for $40. The Bosch from Autozone would work perfectly fine too.
Old 07-23-2010, 08:39 AM
Super Moderator
Glyn M Ruck's Avatar
+1 Filters are not all equal but either Mahle or Bosch would be absolutely fine. Please don't buy junk filters.
Old 07-23-2010, 10:23 AM
maverik259's Avatar
05 C230K SS (sold), 06 C55 (sold), 08 Yamaha R1 (sold), 16 X5M
which bosch fuel filter is it?
Old 07-23-2010, 10:29 AM
maverik259's Avatar
getmercedesparts.com has the filter for 46.25 now...
Originally Posted by ATL_MB
Recently did this on both my and my wife's cars. My understanding is that this procedure is much more important now that ethanol blends are common.
GetMercedesParts.com (M-B of Annapolis) has W203 OEM fuel filters for $86.25 (vs. $115 at my local dealer).
Remove the gas cap (per M-B manual) to relieve fuel system pressure.
I use regular hose clamps and they work fine. Crimping the fuel lines is a pain -- only one line really leaks for more than a second or two -- so just have the new filter handy, and slip the one line that really leaks onto the new filter as soon as it is disconnected from the old filter.
And while I generally think that wearing safety glasses is kind of stupid - do it. Gas in the mouth tastes bad, but gas in the eye hurts like hell (I put my glasses on too late).
Old 07-23-2010, 10:38 AM
  #32
Javvy's Avatar
13 Jeep JKU Sahara w/4" lift Kit & the works,2015 Toyota Sienna XLE,2013 Hyundai Sonata Hybrid
i just ordered a buch of stuff after reading this post as I am due for my 50k service in a couple of days and am planning to DIY it......ordered from www.rmeuropean.com .....also put in "spring10" to get a additional 10% discount......ordered tranny pan gasket, drain plug seal, fuel filter and 12 quarts of tranny fluid all for just $192..got the OEM fliter too and Titan tranny fluid.......good website.......and BTW the fliter comes with the clamps.......
Old 07-23-2010, 11:30 AM
  #33
maverik259's Avatar
says that website doesn't exist...
edit: its rmeuropean.com
plus is there any difference in the 2 brands besides oem etc?
Old 09-30-2010, 12:05 AM
  #34
fookoo303's Avatar
2003 c240
hey guys I am about to change my fuel filter and i am wondering if there is a fuel pressure relief valve on the m112 engine and where it's at or if opening the gas cap will do the job. thanks
Old 09-30-2010, 03:27 AM
  #35
RumbleUK's Avatar
'02 C240
Here's a great write up with pics. I just did it on my car, hardest is to get the clamps off. Infact they kinda pop off, just stick a small flat head screwdriver in the joint hole and lever up.
http://installuniversity.com/mb/w203...el-filter.html
Old 09-30-2010, 06:07 AM
  #36
Super Moderator
Cap is all that's required. No need to depressurise the fuel rail at valve in engine compartment.
File Type: pdf
Old 09-30-2010, 08:47 AM
  #37
fookoo303's Avatar
2003 c240
awesome thanks a lot guys
Old 11-28-2010, 09:41 PM
  #38
drb930's Avatar
2005 C230 Sport Coupe
Anyone had a problem with the engine missing after the Fuel Filter change?
Changed mine the other day, had some missing, CEL, but cleared up after driving it a bit, and cleared the codes with my reader.
Now if I let the car sit overnight the thing misses again, CEL, and does this until the car has run for a few minutes?
Could it take this long to purge the fuel lines?
Glyn, Todd?????
By the way, those clamps are called "Oetiker Clamps", and you can buy the kit with a bunch of different sizes and the pliers for about $50. online.
Thanks,
Dave
Old 11-29-2010, 10:35 AM
  #39
Super Moderator
The filter includes the fuel pressure regulator. Hope you have not got a bad one. Hope you did not disturb dirt that might have got to the pump. Would seem unlikely.
Old 11-29-2010, 04:57 PM
  #40
drb930's Avatar
Thanks Glyn,
I was afraid that the filter had the regulator in it.
Was okay this morning, will give it another day or so before I call SSF to see about them giving me another filter.
Thanks,
Dave
Old 11-29-2010, 05:51 PM
  #41
seagel1000's Avatar
05 C230 Kompressor
Originally Posted by drb930
Thanks Glyn,
Thanks,
Dave
same happened to me after a fuel filter change. Left it idling after the change then left for an errand and started missing. Gave me a bank 1 cylinder code ( iirc correctly). Cleared it and turned on just fine after ward
Old 02-25-2011, 12:43 PM
  #42
nc1wynot's Avatar
2005 C230
Anyone know what size clamp is used on the fuel hoses?
Thanks!
Old 02-25-2011, 05:34 PM
  #43
d1no's Avatar
05 c230k 6spd
Hey guys dont use the Purolator brand fuel filter.. Mine crapped out after 2 months or so and gave me all sorts of problems. New oem filter solved it all.
Old 03-10-2011, 05:39 AM
  #44
sknight's Avatar
c200k
Now I'm looking forward to a fuel filter replacement, but didn't realize they were that expensive, even here in Germany. I'm hoping I can find a good quality, lower price replacement.
Old 03-10-2011, 10:13 AM
  #45
Super Moderator
sk - Be careful - Buy the genuine article. It contains the fuel pressure regulator & we have had trouble with aftermarket units causing low fuel pressure with resultant poor running.
Old 03-10-2011, 11:42 AM
  #46
sknight's Avatar
c200k
Thanks. I'll look for the oem replacement, since the dealers are nuts about pricing. Luckily, for items like this, we can get the Mann replacement...
Or maybe it's just not worth it. They last a long time anyhow...
Old 03-10-2011, 11:49 AM
  #47
M.L.X.'s Avatar
'03 c230k ss
what about Bosch?
I have one I bought while back sitting here that I was planning on using on my replacement(which should be coming up soon)?...
thanks.
Old 03-10-2011, 12:40 PM
  #48
sknight's Avatar
c200k
Bosch stuff is iffy in the US due to licensing their names. You see Bosch, but it might be champion or whatever other company paid to use their name for the filters.
Old 03-10-2011, 01:45 PM
  #49
C230 Sport Coup's Avatar
C230 Sport Coup + 2006 W164 ML350 + 99 Ford Escort (What the heck, it gets 38 mpg!)
Seriously?
I've done mine twice, both times with Bosch.
No problems so far.
I mean they INVENTED EFI.
I can't imagine they can't make a proper fuel filter.
The Knekt one is what the dealer sells.
Old 03-10-2011, 02:18 PM
  #50
sknight's Avatar
c200k
Originally Posted by C230 Sport Coup
Seriously?
No problems so far.
You're not reading my post properly, and I couldn't care less if Bosch invented anything. First thing is they have MASSIVE quality control problems with the stuff they actually make, then in the US, such maintenance items aren't even made by, nor even overseen by them- they license their name to third parties to produce with no involvement by them at all. The last visit I made to the US, I checked out the Bosch filters at Autozone- the regular Champion garbage and very different from what I see here. The Autozone showed me the boxes it came in- source was somehow related to both Purolator and Champion, and the filter was identical to the ubiquitous Champion type, but more expensive.
http://www.bobistheoilguy.com/forums...Number=1476607
What you get from Bosch depends on your local market and you have to go on a case by case basis, as with anything.
PS- it was not invented by Bosch.
You have already rated this thread Rating: Thread Rating: 6 votes, 5.00 average.
Quick Reply: DIY - Fuel Filter Replacement
