DIY: Instrument Gauge Cluster Removal; Screen Replacement
Rating: Thread Rating: 6 votes, 5.00 average.
Old 11-01-2009, 06:07 PM
  #51
Super Moderator
samaritrey's Avatar
THE C350
Originally Posted by sasmith
Thanks for the reply. I've got the old cluster back in and everything works fine. It reads 63xxx miles. I was under the impression that the cluster got it's information from the CAN bus. What are you saying the boo boo is?
Again, thanks.
S.
a member did something just like that and ended up with a millage problem. i have learned to just ignore the problem too much trouble to fix it.
Old 06-13-2010, 05:41 PM
  #52
valexv's Avatar
02 cl203
i just pulled the needles straight up to remove, but be careful while doing so you don't want to screw up the alignment of the needle and have to get it re-calibrated
Old 07-14-2010, 03:31 PM
  #53
fookoo303's Avatar
2003 c240
I got a question. I am about to swap out my lcd off a used cluster i bought but i am going to change the led's also. But i want to test it out on the used cluster i bought first, and my question is if i plug in the used cluster to test the lights and then re install my original cluster, will it give me any problems with the mileage? Will plugging in a different cluster reset something in my ECU causing problems when i want to re install my original?
Old 05-22-2011, 04:59 PM
  #54
pdbuker's Avatar
2002 C240
Does anyone know where to buy just the led screen?
Old 05-28-2011, 11:51 PM
  #55
ernestluz's Avatar
03.5 c230
Question where to put the wired tools
on removing the instrument cluster, where did you put the (2) wire tools?
Old 06-01-2011, 12:56 PM
  #56
valexv's Avatar
02 cl203
there are holes on each side of the cluster where you insert the keys to pull out the cluster
Old 06-05-2011, 04:40 PM
  #57
ernestluz's Avatar
03.5 c230
removal
I tried using wire hangers and can not get a grip on the latches; howfar do you go to get the latches to unlock? do you have to wiggle the tools left and right, one at a time or do you just pull towards you at the same time?
Old 06-05-2011, 09:03 PM
  #58
outnabout's Avatar
2002 C320 Wagon
Put them in so that the open ends of the hanger is facing to the left on the left side and right on the right side. Rotate the left one to the right and the right one to the left (toward the top of the cluster). You should be able to pull the cluster out by keeping the tension on both hangers. Sometimes it takes a few tries with wire hangers if they are not bent just right. The hanger fits into a slot and you should feel it catch when you rotate it.
Old 06-07-2011, 09:07 PM
  #59
ernestluz's Avatar
03.5 c230
Smile instrument cluster
thanks for the help! I tried it today and trim a little bit of the wire hanger and sure enough it work and I only took less than 10 min. to take off and do my mod and put it back.
Old 07-13-2011, 08:14 AM
  #60
WaveyKat's Avatar
Something Slow
Does anyone know how to Re-Sync the Cluster Speedo Needles? :-(
Old 01-31-2012, 06:52 AM
  #61
tebis's Avatar
c230 coupe 2002
Hi!! Where you buy the LCD Display?? please!! I need one piece.
Thanks!
Old 02-17-2012, 12:47 PM
  #62
nilknarf's Avatar
2008 ML320 CDI
Thanks!
Try here:
http://www.minitools.it/display-lcd-mercedes-w203-w209
I think the last price I saw was 80 euros, plus 30 euros shipping to US. They also have a listing on eBay at 90 euros, plus shipping. Seller: MTEC-ELECTRONICS Title: Display LCD per quadri strumenti Mercedes W203/W209
Old 03-04-2012, 09:13 AM
  #63
macaueric's Avatar
W203 c320 Sport Coupe
Valvxe:
I tried fiddled with the latches using “coat hanger” with an “L” at the tip, from ¼” to deeper than 2.5”, felt something springy inside, I pushed, turned but nothing happened. Please tell how is the latching mechanism works. Would the cluster pop out after unlatching or it has to be pulled out (hard)? Also please tell from what angle your picture of the latching device was taken (which side is the top of the cluster?)
Eric
Old 03-04-2012, 11:23 AM
  #64
tommy's Avatar
2004 Civic Si. FWD for the Win!
Eric, it's not the ejector seat in the Batmobile, so it's not going to jump 50 feet in the air or anything.
It'll just pop outward a little when it's been released. If you're having trouble, you can do each side separately - gently pull that side of the cluster while you're trying to release the latch. You can then coax it out a little. If you're still having problems, then your problem is that your coat hangers are not catching, and also that you're too cheap to get the correct prongs from MB. At that point, it would be in your best interests to by them - it will be a hell of a lot easier.
Old 03-04-2012, 01:36 PM
  #65
macaueric's Avatar
Note there is no bulb in the cluster, they are all LED
Old 03-14-2012, 10:35 PM
  #66
drb930's Avatar
2005 C230 Sport Coupe
Sadly, I need one too!!!
Old 07-04-2012, 12:58 PM
  #67
alsadler's Avatar
C230 Kompressor
Great info, has anyone had to do this on a 2004 and up model? I'm hoping the removal of the cluster is the same way. But when it comes to changing the actual screen itself I'm wondering if it is different?
Old 08-01-2012, 02:24 AM
  #68
C240Gosford's Avatar
C240
Battery drain due to instrument cluster??
The battery of my 2001 C240 drained within two days. I did an Ampmeter test and figured that fuse 42 (Airbag warning lamps, instrument cluster) is the problem. (The current dropped from 0.8A to 0.1A after pulling fuse 42) My cluster also shows degradation on top and bottom. I am wondering how I can check if the cluster or Airbag warning lamp is the problem. Any advice is greatly appreciated!
Old 08-01-2012, 04:53 AM
  #69
Blackbradpitt's Avatar
2002 C320
WOW! I can't wait to do this. Especially after I just saw an ad on craigslist and the guy wanted $250 to fix it.
Old 08-14-2012, 03:48 PM
  #70
jazamm42's Avatar
2002 C230K
Did this also take care of the not sleeping problem? Thanks, Jeff
Old 10-27-2012, 06:33 PM
  #71
alsadler's Avatar
C230 Kompressor
Ok finally got my new LCD screen and did the swap using Valexv DIY on page 1. Worked great! Thanx for this post Valexv. I did have to improvise after a little while as I was doing this on my 2005 MB, but couldn't have done it with out this post. Now, sadly once I got everything back together the speedometer wouldn't work (everything else, including the new screen did though). I took it all apart again, even the small needle controller on the back of the main board. Everything seemed to be in working order, so I put it all back together and still nothing. Anybody have any suggestions? Can I buy just the small white needle controller that drives the speedometer needle?
Old 05-04-2013, 06:51 PM
  #72
C230meng's Avatar
C230 k
Could this work on a W202 even thought this Its for a w203 someone please reply
Old 05-08-2013, 10:46 AM
  #73
jevsays's Avatar
2016 C450 AMG, 2005 C230 Kompressor
Good stuff! I may have to use this because I noticed there's a dead bug under my digital display. Thanks!
Old 11-18-2013, 05:28 PM
  #74
hphan's Avatar
Hi, stupid question here, but I don't do much work on my car and I'm going to attempt this replacement soon. Do I need to disconnect the battery before doing this? I'm assuming yes, but just wanted to double check.
Thanks!
Old 11-22-2013, 07:58 PM
  #75
hphan's Avatar
i pulled the battery just to be safe. excellent instructions, took me about 20 mins total including cutting the wire hanger into tools.
You have already rated this thread Rating: Thread Rating: 6 votes, 5.00 average.
Quick Reply: DIY: Instrument Gauge Cluster Removal; Screen Replacement
