Check Engine Light Code P0442
Old 07-27-2009, 01:52 PM
gaogi's Avatar
2013 E350 Bluetec, 2008 Audi S4 Avant, 2011 VW Golf TDI, 2015 Audi S3, 2020 GLB250
Originally Posted by LILBENZ230
Mine turned out to be leaking fuel filter neck. I'm not sure what this costs to repair, though, since mine was done under warranty.
This just happened to my '05 C230. I have extended warranty, but apparently, the fuel filler neck is not covered, and the cost of parts and labor is $850.00 from Fletcher Jones. On a side note, MBZ extended warranty has been pretty useless so far...0 for 2 so far on warranty claims.
Old 08-06-2009, 07:54 PM
drb930's Avatar
2005 C230 Sport Coupe
For you Coupe guys-
I pulled out my Fuel Filler and leaked checked it in a bucket of water with a small amount of pressurized air.
No leaks found, more searching!
Here is what the Fuel Filler looks like-
F= Front as you would be looking at it after removing the Right Rear Wheel.
R=Rear as would be the back side of the Fuel Filler that is against the body.
Attached Thumbnails Check Engine Light Code P0442-ff-f.jpg   Check Engine Light Code P0442-ff-r.jpg
C3Duece (08-15-2020)
Old 08-06-2009, 08:30 PM
Super Moderator
nlpamg's Avatar
2019 GT3 RS, 2017 M3 30 Jahre
Originally Posted by drb930
For you Coupe guys-
wow, thanks for showing us the pics. how difficult was it to remove and replace it?
Old 08-06-2009, 10:12 PM
drb930's Avatar
Not bad, pull the wheel, pull the inner fender apron, remove about 4 bolts. You need to cut the crimped hose clamps. Have to kind of wrestle it out. Make sure you remove the fuel cap.
C3Duece (08-16-2020)
Old 08-07-2009, 12:44 AM
gaogi's Avatar
damn...i paid the dealer 450.00 in labor for that??
Old 08-07-2009, 08:26 PM
drb930's Avatar
You guys are going to love this-
As I stated in my earlier post that there was no leaks found in the Fuel Filler Assembly and more diagnosis was needed.
I pulled the Charcoal Canister as it would not hold a vacuum.
Got it on the bench and could hear hissing when trying to pull a vacuum from around the bottom of the Charcoal Canister Shutoff Valve.
Removed the Shutoff Valve and a picture is worth a 1000 words- Deteriorated O-Ring!
Called up the dealer and ordered a new O-Ring, $3.25.
Will be here on Tuesday.
Attached Thumbnails Check Engine Light Code P0442-charcoal-canister.jpg   Check Engine Light Code P0442-bad-o-ring.jpg
Old 08-08-2009, 06:09 AM
  #32
Super Moderator
Glyn M Ruck's Avatar
Very interesting - Bet the dealer would have replaced the charcoal canister.
Old 08-08-2009, 11:14 AM
  #33
mleskovar's Avatar
'17 Jaguar XF
...and the fuel filler neck assembly, purge valve, and gas tank (after they boogered it up).
Old 08-08-2009, 12:34 PM
  #34
drb930's Avatar
Glyn,
That's what i'm thinking.
When i get the new O-Ring on Tuesday from the dealer, I will post the part number.
It's so easy to change the O-Ring, 1 hour tops.
Actually I think you could change the O-Ring with the Charcoal Canister still installed in the car.
Old 08-08-2009, 01:25 PM
  #35
mleskovar's Avatar
'17 Jaguar XF
...When i get the new O-Ring on Tuesday from the dealer, I will post the part number....It's so easy to change the O-Ring, 1 hour tops.....Actually I think you could change the O-Ring with the Charcoal Canister still installed in the car.
Pictures please!! I know you already have it out but could you take a little extra time and see if you really could replace the O-ring without removing the canister? TIA
Old 08-08-2009, 01:36 PM
  #36
drb930's Avatar
I can take some pictures as I put it back together, no problem.
Old 08-08-2009, 05:57 PM
  #37
Super Moderator
Excellent!
Old 08-08-2009, 06:00 PM
  #38
Super Moderator
nlpamg's Avatar
I'm sure my charcoal canister didn't need to be replaced. pieces of ****!
drb930, thanks!
Old 08-08-2009, 06:18 PM
  #39
Super Moderator
Yup!
Old 08-13-2009, 12:15 AM
  #40
drb930's Avatar
Ok for you Coupe Guys,
Here's a picture of the package that the O-Ring came in with the Part Number.
Picture of the "Tab" Lock that locks the Canister Shutoff Valve into the Charcoal Canister, it's like an Electrical Connector to remove.
Also pictures of the Mounting Bracket for the Charcoal Canister and the Back Side of the Charcoal Canister.
The Charcoal Canister has a tab that you pull with your finger, no tools needed, and then you just lift the Charcoal Canister up and out to remove it from it's bracket.
I'm not going to recommend to replace the O-Ring with the Charcoal Canister in the car, although it can be done.
It's much easier to remove the hose from the Top of the Charcoal Canister, just need Pliers, its a constant tension clamp.
Then remove the Electrical Plug Connection at the Canister Shutoff Valve, then pull the little Tab towards you and just lift up and out to remove the Charcoal Canister.
You do not need to remove or disconnect the Small Purge Line at the Bottom of the Charcoal Canister.
Change your Cracked O-Ring with this Updated Part Number O-ring, my cost $2.60 that still cracks and you are done.
Reinstall the Inner Fender Apron and Passenger Side Rear Wheel.
Hope this helps,
Dave
Attached Thumbnails Check Engine Light Code P0442-img_0404.jpg   Check Engine Light Code P0442-img_0407.jpg   Check Engine Light Code P0442-img_0406.jpg   Check Engine Light Code P0442-img_0405.jpg
The following 2 users liked this post by drb930:
C3Duece (08-16-2020), GoofyNY (02-13-2022)
Old 09-15-2009, 01:47 AM
  #41
kyriacosmetal's Avatar
C-class
Hi,
I have a question regarding the connection of the EVAP system that puzzles me.
Why is the fuel filter connected to the canister? What's the use
Old 09-15-2009, 07:17 AM
  #42
Super Moderator
Because the fuel filter contains the fuel system pressure regulator valve on V6 models
Old 09-15-2009, 10:46 AM
  #43
C-class
It's not just the V6.
All the petrols use a fuel filter with 4 connectors marked as:
PUMP: Inlet from pump
MOT: Outlet to motor
TANK: Return line to tank (From the build in pressure regulator valve)
CAN: Connects to carbon canister
Ny question is, what does the CAN connection do?
Old 09-15-2009, 12:00 PM
  #44
mleskovar's Avatar
'17 Jaguar XF
Originally Posted by kyriacosmetal
..Ny question is, what does the CAN connection do?
The return line from the motor goes to the charcoal canister (CAN) and from the canister to the filter then back into the tank. The charcoal canister reduces any fuel vapors back to liquid.
Old 09-15-2009, 12:04 PM
  #45
Super Moderator
+ 1
Old 09-15-2009, 01:17 PM
  #46
C-class
I don't think you are right mleskovar.
I have cut opened a fuel filter and actually the CAN connector goes to nowhere.
It is sepparated by the rest of the filter using a rubber membrane.
When pressure from the pump builds into the filter, the spring is pushed back, opening the pressure regulating valve and excess fuel goes back to the tank.
When the valve opens, it pushes the membrane up a bit and this creates a positive pressure inside the CAN line.
I do not know why this is
Old 10-02-2009, 11:39 AM
  #47
hecktorbfs's Avatar
05 c230 k
Hope this helps,
Dave
so...
this took care of your checkengine ligth ???
i got the same code , i already replaced the gas cap , but the code came back...
Old 10-02-2009, 11:54 AM
  #48
drb930's Avatar
Over 1000 miles now and no light.
When you look at the picture of the o-ring, you can see that was definitely the problem.
Thanks,
Dave
Old 10-02-2009, 11:55 AM
  #49
hecktorbfs's Avatar
05 c230 k
ok, cool.
i guess i need to take mine apart and find the problem.
thanks
Old 10-18-2009, 06:14 PM
  #50
c240classic's Avatar
2007 cls63 AMG
I took apart the canister valve and checked the o-ring. It looks like brand new and is in good shape. Replaced everything, check engine light is still on.
How do you check the purge valve to see if it is working right?
Quick Reply: Check Engine Light Code P0442
