Sign in using an external account
| C-Class (W203) 2001-2007, C160, C180, C200, C220, C230, C240, C270, C280, C300, C320, C230K, C350, Coupe
Sponsored by : My Mercedes Parts ![]() |
LinkBack | Thread Tools | Search this Thread | Rate Thread | Display Modes |
#1 | ||
Drives: 2002 C240 Classic - Orion Blue Beast!!
#2 |
Drives: C230 coupe 6sp
After the car has been running, you have to let it sit a few minutes before checking the oil level. Do it first thing in the morning before you start the car. I get those messages too, but it is because the car is actually low on oil. My car has a drinking problem. Check it with the dipstick if you want to really be sure.
#3 | |
Quote:
I don't get the messages anymore (e.g. "Engine Oil Level - OK") When trying to check the oil all I get is, "Engine Oil Level - Start ignition". I hope it's not an oil problem. It actually sounds like a computer issue. Especially since the malfunctions are disappearing. |
#4 |
Drives: 2003 C230K Sport Coupe, 1986 190E 2.3
The messages disappear because they are not major malfunctions they are more of a warning. The manual states that you must wait five minutes after turning off the vehicle to check your oil level. The vehicle must be on an almost level surfice and the key set to position 2 which is the run position just before start. It must not be started to check. Then it will tell you the proper level. If you have a pre-2003 then check via the dipstick. This is all clearly written in the manual. If the car did not warm up then wait 30 minutes to check it. I check mine around once a week before I start the car and it is always ok, but I do not have a dipstick so who the heck knows how much oil is in there.
__________________
2003 Pewter C230K SC C1, C4, C5, C7, heated seats, CD Changer, and 6 Speed. 1986 190E 2.3 Black, Auto, Mods to come soon..... |
#5 |
mctwin2kman,
Thank you for the reply. I am aware of all the facts you outlined in your post. My owners manual states that the messages must be manually cleared by a person. It does not say anything about the car resetting the indicator. If I am incorrect about this, please accept my apology. I am also familiar with the various severity levels of each message. C1 = the most severe, and cannot be cleared. C2 (my message) = can be cleared by the owner. C3 = very minor. As for the owners manual being clear: NO WAY!!! In some instances, it's anything but clear. And I'm not the only who feels this way. Thanks again. |
#6 |
Admin Alumni
Drives: See Garage
Some messages DO go away when you turn the engine off. For example, If you get a "reserve fuel - visit filling station" it will appear in your list of fault messages (pages lower-right MFD) but if you turn the car off, it will reset and no longer appear immediately on restart. Same with the "Excessive Oil" fault message.
I don't know the answer to your question David, just suggesting that a mechanic is not needed to reset at least some of the messages. Looks like a dealer visit is in your future...
__________________
C320 - '06 Headlights Desert Silver/Java Clear Markers White Star Flat Badge |
#7 | |
Quote:
He told me to stop by after work today. I'll post the outcome of my visit. |
#8 |
Sorry if I offended first off, it was not my intention. Moving on, yes I agree the manual is not the best. I would assume that the errors the owner can clear are cleared by the re-setting of the ignition, but this is not stated in the manual. I have not seen this message as of yet and hope I do not, but the fuel ones I clear by hitting a steering wheel button but they stay in malfunctions page until a re-start or I get gas. On re-start it takes a little bit to get the message back. I actually find it irritating but what can you do, I guess MB thinks we need big bright flashing idiot lights to tell us what is up. The light on the gauge is enough for me. Anyhow, Sorry again...
__________________
#9 |
Had a similar occurrence this morning, except was ESP-Visit Workshop and BAS-Visit Workshop flashing back and forth. Messages went away when I scrolled to another menu and I noticed that they were stored as Faults or Malfunctions, can’t remember which. Anyway, when I went out to lunch, no warnings and nothing was stored, only the continuing F/L turn signal bulb in-op (which I can fix for a few days by removing and re-installing the same bulb!). Seems like a computer glitch of some sort.
#10 |
Drives: 2007 R350
MB-BOB, on my car the reserve fuel comes on immediately after starting the engine, it's actually coming on as soon as I turn on the ignition. Just my $0.02
__________________
'02 C230K, Brilliant Silver, Charcoal, Auto, C2, C7, CD-changer and EuroComand - only flying is better - gone (sniff) - got it back again :) '07 R350, Iridium Silver, PP1, RSE, HS, NAV etc. - still have to say: only flying is better - gone |
#11 |
Update...
When I started the car after work, the two malfunctions were no longer there. So anyway, I stopped by my dealer today after work. He came back to tell me that my car actually had MORE oil than it was supposed to. The dip stick was measuring at 161mm, and it should have been at 158 according to the tech. So they fixed that.
He reiterated that the malfunctions should disappear on restart, and that the malfunctions do not throw codes to the computer (I asked him if they checked for fault codes, this was his explanation why they didn't). Initially he was worried that my car was low on oil. Anyhow, it still doesn't explain why that particular malfunction was ocurring. It must be a glitch with the sensor/computer. I hope it doesn't resurface. I did check the oil via computer twice after, and I recieved an "OK" message. So I can relax for now. mctwin2kman, No apology necessary. I didn't mean to come off pissy to you in my post. I was just annoyed with my car. OC WAGON, Sounds exactly like mine. I guess my advisor is correct. The messages are supposed to disappear on re-start. You'd think by the wording of the message, "Visit Workshop!", that's it's something serious. Instead, MB is making me worry for nothing. These cars give too much information. Have you had a chance to investigate the problem? Is it the actual ESP-BAS, or is it your comp that's messed up? Thanks again to everyone for their assistance. I sincerely appreciate it. David N. |
#12 |
David N,
I agree about the severity of the message, wording makes it seem like a pretty major issue. Didn’t help that it came on during heavy morning traffic in the rain. It was still wet at lunch so I did a panic stop and also tried to break traction on the rear wheels – everything was normal. Not worried about it unless it continues to come on, then it becomes more of an annoyance than anything (just like that turn signal bulb that keeps fixing itself). |
| Tags |
| benz, c3, c320, dealer, engine, flashing, level, malfunction, merceeds, off, oil, sensor, stop, visit, w203, workshop |
| Currently Active Users Viewing This Thread: 1 (0 members and 1 guests) | |
| Display Modes | Rate This Thread |
