Sign in using an external account
| C-Class (W203) 2001-2007, C160, C180, C200, C220, C230, C240, C270, C280, C300, C320, C230K, C350, Coupe
Sponsored by : My Mercedes Parts ![]() |
LinkBack | Thread Tools | Search this Thread | Rate Thread | Display Modes |
#1 | ||
Drives: 2003 C230K Sedan
Questions about 2003 C230K
#2 |
Drives: Here's Johnny!
2003 1.8L engine has a defective head design.
If it hasn't been replaced with the updated version, I'd dump it. Tons of threads on this.
__________________
2002 C230 Sport Coup ASP Pulley-Supersprint Header-Remus Muffler- TEIN SS Coilovers AMG; Wheels, 22mm AMG Front sway bar, HR 19mm rear bar, C32 Brakes Tinted Windows- 2005 Tails, Grill & Blinkers-Clear Sides Bi-Xenon Headlights! Clear Fogs w/Philips Crystal Vision bulbs Audio 10 Renntech style Spoiler Supercharger Muffler Deleted! "Aero Turbine" AR20 Rasp Eliminator (Resonator)
#3 |
Drives: '03 C230 Sport Sedan
The biggest two items that I've seen to affect these cars are:
1) Valeo Radiators - failure of a radiator seal allows coolant to enter the transmission, causing major damage if not found early enough. There is no way to check if a failure is looming, so best practice is to replace the radiator (only if Valeo - Behr radiators don't have this design/defect). 2) Leaking cam sensors - oil leaks from the cam sensors, fouling the sensor plug if you're lucky, fouling the entire engine wiring harness, ECU, and O2 sensors if you're not. If yours haven't leaked yet, invest in the 'pig-tail' connector devised by MB to avoid this problem. With the pigtails installed, the cam sensors may leak, but they'll leak down the front of the engine rather than into the wiring harness. If you're considering keeping the car long-term (I've got 111k on mine, and I'm keeping it for a good bit longer), then I would make certain that the above items were addressed. Other than that, both the W203 and the M271 appear to be pretty solid pieces.
__________________
2003 C230 Sport Sedan |
#4 |
Drives: '03 C230k ss
Don't forget the $12 hose issue - which I believe was mistakenly diagnosed as a head problem sometimes and/or contributed to the head problem. I'm only at ~65K and planning on keeing it for quite a while longer.
#5 |
Drives: 2002 C230 Kompressor
Re cam sensor issue. About 18 mo ago I took car in to dlr get 02 sensor replaced (under extended warr--then). MB said oil leak had fouled many other components and replaced them all to the tune of about $3500 (I had $100 deductible).
About 3 mo ago I replaced my alternator, noticed oil on underside road sheild, tried to follow trail up the engine without definitive source IDed. No noticeable oil loss in dipstick checks just oil on sheild. Ever since alt. repair, car has been sending P0243 and P0401 codes (wastegate sol and supercharger issues). I am wondering if these are fouled by oil leak? Car shows no slip in MPG, there is a slight hesitation on accel, but no issues other than that. No longer under warranty. Is there a PN you can cite to see if MB did install the pigtail harness last yr? If not, any risk in my letting current situation continue unabated? Thanks for your insight. Andy in Tampa |
| Tags |
| c230k, high, m271, mileage, p0243, p0401 |
| Currently Active Users Viewing This Thread: 1 (0 members and 1 guests) | |
| Display Modes | Rate This Thread |
