Sign in using an external account
| C-Class (W203) 2001-2007, C160, C180, C200, C220, C230, C240, C270, C280, C300, C320, C230K, C350, Coupe
Sponsored by : My Mercedes Parts ![]() |
LinkBack | Thread Tools | Search this Thread | Rate Thread | Display Modes |
#1 | ||
Drives: 2002 C230 Kompressor SportCoupe (SOLD), 2008 Mini Cooper S
Replacing shock mounts?
__________________
![]() SOLD 18" Brabus Monoblock VI Replicas : C32 Brakes/Akebono Euro Ceramic Pads/Stoptech Stainless Lines : Eibach Pro System Plus : Remus Exhaust ASP Pulley : '05 Taillights : OEM Bi-Xenons : Clear Fogs/Hoen Yellow Endurance : COMAND |
#2 |
anyone know when these typically wear out?
__________________
#3 |
Drives: C230 coupe 2002
I recently replaced my differential, while taking my suspension off, to change it,i did not replace the rear ones , now its making a clanking noise everytime i hit a bump , i'll say if you got the money for them, since you taking everything off, go for it!!
#4 |
that's what I'm thinking...the front mounts are only $54 at autohausaz.com
Linden, how many miles you got on the coupe?
__________________
#5 |
Drives: '08 E92 335i MT
I have a pair of brand new rear spring rubber cups (#2), P/N A 210 325 02 84. PM me if nterested.
__________________
vadim SOLD: '02 C230K Coupe (S/C M111) + HID / Audio 10 CD / Euro side mirrors / ASP steel pulley / AMG sway bars / W211 LED mirror blinkers / Aero wipers / Vogtland springs / StopTech SS brake lines / StopTech slotted rotors / Mintex pads NOW: '08 E92 335i Space Gray / Coral Red / MT / ZSP / ZPP / iPod/USB / Heated seats |
#6 |
Drives: 2011 C300
I bet it takes a beating in NYC, if it is anything like ATL. I hate driving in ATL because I feel like my car ages 5 years every time I go downtown.
#7 |
#8 |
LILBENZ - The only thing that keeps me sane while driving through NYC is the thought that maybe, just maaaaybe these cars are made for these streets/cobblestones in Europe...still though, I try to avoid the city. I'm actually flying down to Sarasota tomorrow, via ATL - I'll wave to ya!
Linden, I just turned 63K on my '02. All in all, I think this comes down to a "why not" situation - If I have all the parts off already, why not, right?
__________________
#9 |
Moderator
Drives: w203 m112
@ OP: I know splinter created a thread about replacing all of the hardware on top of his front struts a while back and he had lots of positive things to say. I imagine at the mileage that you have, that it wouldnt hurt to do. I would do it if I had an opportunity. That being said, I wish I did it when I installed my COs.
@ Linden. I am pretty sure the clunk you have in the rear does NOT involve the spring pad itself. Ive taken apart my rear suspension sooo many times and everytime I have a clunk, its usually because something is not tight enough. The most likely cause is the bolt that holds the damper to the lower control arm that has to be removed to install the springs. 30 mins under the car and you can have the noise gone
__________________
#10 |
Thanks, Tru. I read your install guide, and will be using it to install my setup. Thanks!
__________________
#11 | |
Quote:
#12 |
Dr.Fox: Do you know where i can get the 05+ tails from? besides the stealership?
#13 |
yeah, contact MBenzNL on the forums. Steve has all the good stuff for the coupe
__________________
![]() SOLD 18" Brabus Monoblock VI Replicas : C32 Brakes/Akebono Euro Ceramic Pads/Stoptech Stainless Lines : Eibach Pro System Plus : Remus Exhaust ASP Pulley : '05 Taillights : OEM Bi-Xenons : Clear Fogs/Hoen Yellow Endurance : COMAND Last edited by Dr.Fox; 07-21-2009 at 08:11 PM. |
#14 | |
Drives: 2011 C300
Quote:
![]() It's said if you die, you'll have a connection at Hartsfield-Jackson enroute to Heaven. |
#15 |
| Tags |
| 2002, c210, c230, c230kompressor, front, mount, mountings, mounts, remove, replace, shock, shocks, tailpipe, upper, w203 |
| Currently Active Users Viewing This Thread: 1 (0 members and 1 guests) | |
| Display Modes | Rate This Thread |
