Sign in using an external account
| C-Class (W203) 2001-2007, C160, C180, C200, C220, C230, C240, C270, C280, C300, C320, C230K, C350, Coupe
Sponsored by : My Mercedes Parts ![]() |
LinkBack | Thread Tools | Search this Thread | Rate Thread | Display Modes |
#1 | ||
Drives: 2002 C240
#2 |
Drives: 2002 C240
Anyone????
#3 |
Drives: 2002 C240
Bueller??...........Bueller????
#4 |
Super Moderator
Drives: late 2009 CLK 350 Coupe Elegance, '65 Jaguar S Type wires
Check all pipework you disturbed when changing pump - This is most likely source of the problem.
Check tank breather pipe from both tanks to filler neck to ensure that you did not kink or block it. Check pipework to charcoal canister for kinks or blockage. Finally check that you don't have a stuck purge valve up front in the engine compartment.
__________________
![]() Llandudno, Cape Town, South Africa Last edited by Glyn M Ruck; 10-29-2009 at 07:20 PM. |
#5 |
Super Moderator
See this thread running concurrently for diagrams & insight.
http://www.mbworld.org/forums/c-clas...fuel-tank.html
__________________
![]() Llandudno, Cape Town, South Africa |
| Tags |
| c240, code, control, emission, evap, fuel, high, input, jaguar, location, mercedes, p0453, pres, pressure, pressuresensor, sensor, system, tank |
| Currently Active Users Viewing This Thread: 1 (0 members and 1 guests) | |
| Display Modes | Rate This Thread |
