how do you replace the antenna amplifier c230 coupe 2002
2002 c230 coupe
Help... remote locking system stoped working after car battery was replaced.. I did the computer reset windows etc... Dealer says the antenna amplifier is bad... Where is it located and can I find a junkyard replacement to put in there.. they want $1,000 to fix it sounds crazy to me...
Super Moderator
you are screwed...
1. dealer is most likely correct that you blew out the aerial or rear sam.
2. you cannot search good luck. (your car is old and not even made anymore don't you think some other idiot blew out the antenna or rear sam as well?)
2012 C300 4Matic
http://lmgtfy.com/?q=site%3Ambworld....orking%22+w203
That should get you on the right path. Take it from there, I'm sure you can find all the info you need.
