Stuck in 1st gear until restart
#51
I have mercedes c230 compessor . Just j=replaced motor about a month ago and after about three weeks trouble code p2203 y3/6n3 ( speed sensor3) faulty is comming up . can someone help me with this.thank's.
#52
Super Moderator
Sounds like you need a new conductor plate
http://www.pelicanparts.com/catalog/...pg4.htm#item19
I would shop around that is just the first place I looked.
You will also need to do a filter and fluid change. shell 134 atf is approved for the 722.6 transmission and is usually the cheapest by a ton at least in the USA.
Also check the TCU connector on the outside of the transmission for oil they tend to leak and can cause issues.
