Sign in using an external account
| C-Class (W203) 2001-2007, C160, C180, C200, C220, C230, C240, C270, C280, C300, C320, C230K, C350, Coupe
Sponsored by : My Mercedes Parts ![]() |
LinkBack | Thread Tools | Search this Thread | Rate Thread | Display Modes |
#1 | ||
Drives: Mercedes C200K Coupe
Weird sound comes when I brake!
#2 |
The sound that you described doesn't mean anything since that sound could also be generated by tires rubbing against the fenders or sway bars.
Have a high-performance or aftermarket brake/suspension shop who is familiar with the W203 inspect it for you... don't take it to a mom-and-pop or your standard shops. Here's a start though... Check the for loose lugnuts, or... If you had work done on your calipers or brake pads, it could be that the caliper bolts are loose, which causes the pads and/or the caliper assembly to jitter, or... If not, then it could be possible your rotors are warped, or... Perhaps if the struts were removed (lowering/suspension work), then the re-assembly was faulty. |
#3 |
the sound comes when the car is at full stop and the steering wheel is to the left, after driving it at normal speeds.
it goes only when I turn the steering wheel to the right and center it. so... does that minimies the options? |
#4 |
by the way... I haven't done any modifications for the car. didn't even change the brake pads yet.
#5 |
that sound comes while I'm waiting in a U turn usually.
#6 | |
Drives: c230k, black, auto, c2 (let the sunshine in), Bose, leather, and CD
Quote:
PM MBtech208, he'll know. Beth |
#7 | |
Quote:
I want to tell the ppl at the garage what u just said to point them out :p also... do u think I should get the car checked or its okay to drive it right now? I'm short in cash... and I don't think I can fix it now :P |
#8 | |
Quote:
Here is a guess, it is only a guess. A CV joint attaches the axle to the wheel I think. The joint goes and you need to replace the axle sometimes. On my GeoStorm, it was about $250 to replace it. If you car is under warrenty, just take it in. If not, I drove on my for a while, but it will get worse. The risk is that the wheel will lock while you are drving. You'll spin off the road if that happens. Scarey stuff. PM Dave. He knows all. Good luck! Beth |
#9 |
Except that Mercedes Benz are not equipped with CV (constant velocity) joints in the front. CV joint problems are more popular on front wheel drive cars.
Does the noise/shake/vibration increase with speed? And is it only when steer left??? What wheels do you have? Look underneath the fronts while your tires are turned and see if anything is rubbing or is showing signs of wear. It's probably something simple as the front setups on the W203's are simple. |
#10 | |
Quote:
#11 | |
Drives: 1997 Toyota Tacoma 4x4
Quote:
__________________
Dave ASE Master Technician |
#12 | |
Quote:
__________________
#13 | |
Quote:
#14 | |
Quote:
__________________
Dave ASE Master Technician Last edited by mbtech208; 04-18-2003 at 10:24 PM. |
#15 | ||
Quote:
Quote:
"Sorry I thought the subject of this discussion was the W203." NOT the W203 4MATIC. Last edited by randall-sd; 04-19-2003 at 12:54 AM. |
#16 | |
Quote:
#17 | |
Quote:
Don't mind me, I'm just being difficult
__________________
#18 | |
Quote:
| Tags |
| brake, brakes, c240, car, cv, fast, full, joint, makes, noise, noises, stop, w203, weird |
| Currently Active Users Viewing This Thread: 1 (0 members and 1 guests) | |
| Display Modes | Rate This Thread |
