Threw 2 codes yesterday, can anyone decipher???
Old 10-20-2010, 01:19 PM
maverik259's Avatar
05 C230K SS (sold), 06 C55 (sold), 08 Yamaha R1 (sold), 16 X5M
code 1: P0128 - "coolant Temp below thermostat regulating temp"
WTF does that mean exactly? My engine is operating too cold? Is that possible.
code 2: P0600 - "serial communication link malfunction"
Again WTF, lol
I take it these arent related to all the work and CEL i was throwing for my vacuum leak that took MB 6 days to figure out. I was about to just take it back to them when the CEL tripped thinking it was related. Glad i bought that code reader before i got the call saying its not related and they want 180 for reading the new codes (although if i take to them to fix they'll probably still want to charge me to read it themselves)
Old 10-20-2010, 01:27 PM
pcy
pcy's Avatar
'14 ML350, '13 C220 CDI, '07 C280, '98 ML320
The first code is possibly due to thermostat stuck open. When the thermostat gets stuck in open position, the coolant continues to circulate without allowing the coolant to get hot.
When the thermostat is operating normally, the thermostat stays closed until the coolant temp reaches 87 degrees (or preset temp of the thermostat). Once the coolant reaches the operating temp, thermostat opens and allows the coolant to circulate thru the cooling system.
Old 10-20-2010, 01:35 PM
maverik259's Avatar
ok im guessing the p0128 is simply a bad thermostat (i hope). I hope this is covered under my extended warranty. Although it would be the first thing they've covered lol...
Any ideas as to the p0600 serial malfunction thing?
Old 10-20-2010, 01:36 PM
maverik259's Avatar
haha ya sorry just read the replacemtn diy thread.
Old 10-20-2010, 01:39 PM
Xhale707's Avatar
C320 2002
P0600 indicates a CAN (controller network communications) error;
CAN Serial Communication Link Malfunction to ESP
Old 10-20-2010, 01:45 PM
Xhale707's Avatar
C320 2002
Has your car been tuned?
Old 10-20-2010, 02:48 PM
maverik259's Avatar
nope...i know its an error in the communications but what does that mean? is it my ecu that is failing or something? I mean the car runs fine.
Old 10-20-2010, 03:59 PM
W203E35's Avatar
2006 C350 Sport 6MT
First one is definetly thermostat.
The second one is most likely a temporary error. Try resetting the code and see if it comes back.
If you need instructions on how to change the Thermostat let me know. How many miles do you have? Maybe a good time to do a radiator flush if you haven't done so?
Old 10-20-2010, 04:42 PM
maverik259's Avatar
ya i just hit 68k...i do need a coolant flush but I dont have a mitty vac etc so I may just replace the stat and run up to an auto shop and ask them to do it...
and isn't just unbolt 2 bolts and pull out the hose then bolt in new Tstat and plug back in hose ? its easier for us m271 guys than you guys isnt it?
Old 10-20-2010, 05:02 PM
Xhale707's Avatar
C320 2002
You don't need a mitty vac for a coolant flush.. Im gonna DIY it either today or tomorrow im feelin pretty lazy to do the job right now haha
Quick Reply: Threw 2 codes yesterday, can anyone decipher???
