Sign in using an external account
| C-Class (W203) 2001-2007, C160, C180, C200, C220, C230, C240, C270, C280, C300, C320, C230K, C350, Coupe
Sponsored by : My Mercedes Parts ![]() |
LinkBack | Thread Tools | Search this Thread | Rate Thread | Display Modes |
#1 | ||
Drives: C320 2001
smart key battry lifetime
#2 |
In a 95.. i changed my battery about (2 of them in the key) after 5 years or so. You will notice that it doesnt work as well from far away...
I think it was 5 bux at radio shack... sure its cheaper elsewhere if u hunt for them ~fk |
#3 |
Admin Alumni
Drives: See Garage
My '01 C320 is two years old this weekend, and the SmartKey battery is still going strong. And I even press the lock button twice every time I get out of it, just to be sure.
__________________
C320 - '06 Headlights Desert Silver/Java Clear Markers White Star Flat Badge |
#4 |
Drives: 2001 C240
My smartkey battery was replaced after only a little over 1 year of daily use. At first I didn't know what was going on since the key would fail to work only occasionally. I was afraid there was a problem with the key itself as I remembered reading some post about Smartkey failures. I complained to the dealer about the problem and they simply replaced the battery for me with a $17 charge. Needless to say I felt taken.
__________________
-+-+-+-+-+-+-+-+-+-+-+- 2001 C240 Sport Package 6-spd manual Brilliant Silver AMG Front Apron AMG Monoblock II Euro Comand |
#5 |
CR2025
CR2025 $1.75ea at Fry's Electronics.
You need a pair of batteries per key. I suggest you keep an extra set in the glovebox. |
#6 | |
Drives: Brabus w203
Quote:
definitely taken
#7 |
Guest
Posts: n/a
my batteries died on both keys a month ago (would be a year in sept). now i enter the car using the metal key. before the alarm would come on, i'd put the smartkey into the ignition. no, i'm not cheap, i'm just too lazy to go change the battery.
#8 |
Drives: 2010 C300 4matic
I don't think the alarm will come on in that situation. You aren't arming the alarm if you lock the car with the metal key. At least I think that's right??
__________________
2010 C300 4matic Steel Grey/Black 15% tint X-pipe |
#9 |
Drives: 2002 C230 K
I was at the dealer once and there was this older guy raising Cain because of his SmartKey had failed after they had just replaced the battery. The guys at the counter popped it open and the insides were totally corroded.
They looked at him and said, "Hmmm.... Looks like it went through the washing machine." - BT
#10 | |
Admin Alumni
Drives: See Garage
Quote:
That's some MAJOR LAZY... (Just having some fun, moomeh!)
__________________
#11 | |
Quote:
__________________
#12 | |
Admin Alumni
Drives: See Garage
Quote:
Turns out the batteries were jostled loose in the remote. Once I bent the metal contacts to grip the batteries better, the problem went away.
__________________
#13 |
Ok, that's what I thought, I just didn't want to state it as fact. moomeh said he would put key in ignition before the alarm would go off, but I didn't think it ever would because he obviously would have locked it with the metal key as well, and thus no alarm.
__________________
| Tags |
| 2001, 2002, batteries, battery, c230, c240, c320, cr2025, key, mercedes, pair, smart, smartkey, type, w203 |
| Currently Active Users Viewing This Thread: 1 (0 members and 1 guests) | |
| Display Modes | Rate This Thread |
