Better pics of oil leak c230 kompressor coupe - MBWorld.org Forums
LinkBack Thread Tools Search this Thread Rate Thread
Old 12-24-2010, 03:16 PM   #1
Drives: 2002 c230 Mercedes Coupe kompressor
here are sum better pics I just took again tryn to get feed back on where the leak may be coming from just had A service done and funny this is the second time I have had issue with leak after service done by dealer! last time it was aftr doing transmission fluid and filter now oil!!!!!!!!!!![ATTACH][ATTACH]Better pics of oil leak c230 kompressor coupe-img_6969.jpg[/ATTACH][/ATTACH]
Better pics of oil leak c230 kompressor coupe-img_6968.jpg   Better pics of oil leak c230 kompressor coupe-img_6960.jpg
mercedescoupe77 is offline   Reply With Quote
Old 12-24-2010, 03:22 PM   #2
saer1one's Avatar
Drives: 2002 c32 AMG 2012 c250 Coupe
Quote:
Originally Posted by mercedescoupe77 View Post
here are sum better pics I just took again tryn to get feed back on where the leak may be coming from just had A service done and funny this is the second time I have had issue with leak after service done by dealer! last time it was aftr doing transmission fluid and filter now oil!!!!!!!!!!![ATTACH][ATTACH]Attachment 198869[/ATTACH][/ATTACH]
Might be a little more helpful if you remove the undercover for all to see.. If your a DIY kind of guy then first thing you should try to do is see if the oil drain plug is the one leaking, then you can go from there..
saer1one is offline   Reply With Quote
Old 12-24-2010, 03:29 PM   #3
I wish I could remove the pan myself lol
Well I am a female not a male, I cant remove the pan sadly for all to see at this poINT i have to wait till monday aftr holiday to have stealer look at the leak Just wanted some feed back from you all so I wont walk in blindly and get screwed
Old 12-24-2010, 04:09 PM   #4
Super Moderator
Glyn M Ruck's Avatar
Drives: late 2009 CLK 350 Coupe Elegance, '65 Jaguar S Type wires
Oh dear again - The dealer has either spilt oil on the undertray while filling or you have a leak.
A - Service is really just oil & filter change & general inspection. This dealer seems a real jerk after the transmission issue.
So - likely causes:
- Spilt oil on filling
- O ring incorrectly inserted & a leak at the oil filter
- I'm sure they would have sucked the oil out but in the unlikely event that they drained from the bottom then they have not fitted a new drain plug. Mercedes drain plugs are microencapsulated with sealant. Benz recommend their replacement at every use (We DIY'ers give them a coating of suitable Loctite.
Good luck - bad timing - Is your husband still abroad?
Those are the 3 likely causes unless they disturbed something else which is unlikely or you have a crankshaft seal leak.
Glyn M Ruck is offline   Reply With Quote
Old 12-24-2010, 04:25 PM   #5
was not leaking before i took it in
The problem is that it was not leaking before I took it in and I would of noticed it on the pavement I always look! I have a feeln they didnt tighten something correctly or like you said glyn the sealant is not there on plug or the filter has an issue. If they try their crap again they are going to pay for this leak just like they finally paid for the other one they sent me home with and I am going to get a loaner again and upgraded like last time this is bull. I just thought I would take it to them again since they already know the car but apparently I dont know what the deal is with wat ever techinicians they have workn on my car each time
Old 12-24-2010, 04:30 PM   #6
Super Moderator
samaritrey's Avatar
Drives: THE E320 Bluetec
what you can do is open the hood and take a quick look for oil. but i would take it back Monday morning. but check oil level before driving car don't want a simple oil leak to escalate into new car or do what i did have the dealer come pickup it up with a tow truck. My dealer did not screw the oil cap back on so oil went everywhere. They were over an hour away so i called and had them pickup up my car redo everything and clean up the mess and then drive it back to me with a full tank of gas.
samaritrey is offline   Reply With Quote
Old 12-24-2010, 04:35 PM   #7
Super Moderator
Trey - That is a good & obvious point. MC77 - please check that they put the oil cap back on.
Don't take ANY nonesense from that dealer. They were a disaster last time - looks like they have messed up again.
Old 12-24-2010, 04:38 PM   #8
contact148's Avatar
Drives: 2003 c240 4matic wagon
the engine covers under these cars can hold alot of fluid before they start dripping
if your able remove the cover clean it drive for a bit with it off and look for drips
hopefully it was just a spill
contact148 is offline   Reply With Quote
Old 12-24-2010, 04:49 PM   #9
Super Moderator
PM's replied to.
Related Topics
Thread Thread Starter Forum Replies Last Post
M271 New engine do i need new instrument cluster? zesarz4 C-Class (W203) 5 06-22-2016 11:44 AM
2008 CLK63 AMG Black Series, rare Arctic White. 1 of 35 made Euro Mercedes Vehicles 23 12-08-2015 05:09 PM
Coolant hose/nipple on expansion tank appears to be cracked. Is this normal? jtwillia2 C-Class (W203) 7 09-11-2015 09:30 PM
c230 2003 coupe panoramic sunroof question zesarz4 C-Class (W203) 2 09-03-2015 11:47 PM
Radiator replacement opinion TMans C-Class (W203) 3 09-02-2015 12:25 PM
Tags
02, 04, 05, 230, atf, automatic, benz, c230, c240, diy, engine, kompressor, leak, mercedes, oil, transmission
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
Copyright 2001-2012 InternetBrands, Inc. / MBWorld.org. All Rights Reserved.
