Adjusting rear toe W203
Old 01-03-2011, 04:18 PM
Super Moderator
johnand's Avatar
2007 C230SS; 2014 ML350 BT
Attached is the WIS document for adjusting rear toe that Glyn requested.
I will be posting a complete DIY write-up on chassis alignment in the near future.
File Type: pdf
Old 01-03-2011, 04:27 PM
Super Moderator
johnand's Avatar
Posted the W204 WIS in the W204 forum. Appears it is adjusted with cam bolts as well.
Old 01-03-2011, 04:37 PM
Super Moderator
Glyn M Ruck's Avatar
John - You are a star - thanks
Old 03-13-2011, 08:24 PM
Super Moderator
splinter's Avatar
GMC - Miata - Trek - P-Car
Owing to the adjacent bulkheads, there’s scant little space to fit a torx bit into those eccentric adjustment bolts.
Recently had occasion to verify alignment settings on a friend’s über-sophisticated Hunter machine.
That he owns the local Michelin dealership permitted some judicious tweaks.
Was pleasantly surprised to see that my jerry-rigged DIY techniques had produced results within 1/16th-inch and/or 1/8th-degree from those intended. There’s no denying it rolls a bit more freely after properly adjusting in a 0.00° thrust angle – as evidenced by measurably improved highway fuel consumption figures. Took the liberty of increasing its rear toe from .31° to .63° (total). Preliminary shakedown cruise indicated increased directional stability upon encountering pavement irregularities, during trail braking, and improved aft traction upon corner exit. Will update this thread with tread life and wear pattern findings in due course, and after the next HPDE.
I’m hoping it'll remain in the same zip code as nlpamg’s mighty M5 before our session is flagged.
http://www.smartracingproducts.com/p...e_settings.pdf
Quick Reply: Adjusting rear toe W203
