Go Back   MBWorld.org Forums > Mercedes-Benz Sedans > C-Class (W203)
Sign in using an external account
Register Forgot Password?
Register Photos FAQ Members Insurance Search Today's Posts Mark Forums Read CarsGarageVendors
Welcome to MBWorld.org Forums
Sponsored by : My Mercedes Parts
Click Here
LinkBack Thread Tools Search this Thread Rate Thread Display Modes
Old 03-07-2011, 08:49 AM   #1
Drives: 2005 C200 CDI
Weird problem - C200 CDI w203
Again guys, your expertise are needed badly.
It's been few days that randomly, while I start the car, it stalls and throws a message "ESP faulty visit workshop". If I takes the key out of the socket and then restart the car it will run OK with no errors or performance issues.
As I said this is happening randomly for the past few days.
My mechanic connected the car to the star computer and reset the error codes so the malfunctions would pop up. Nothing popped ... no freaking problems ... I went home ashamed after not being able to convince him that the car isn't in great shape.
Today, while on the freeway the car went into limp mode. I'm pulled to the shoulder of the road and after a minute or so it reverted back to normal state. I had 3 (!!!) malfunctions: ESP, Coolant and Display (faulty visit workshop). Again, I've taken the key out and restarted the car ... again the miracle happened and I went going as if there was no problems before.
Needless to say ... ESP is working perfectly, No problem with the coolant and of course no display problem.
I'm puzzled, how about you ?
To remove this ad, register today or login if you already are registered!
WhirlPool is offline   Reply With Quote
Old 03-07-2011, 11:58 AM   #2
owww, so many views and no insights.
Did I beat the machine?
Old 03-07-2011, 12:12 PM   #3
Drives: 2007 Mercedes-Benz C230
mskembo
Send a message via MSN to mskembo
I would suggest that many of us who read this thread were just waiting for the reigning abettors of insight to ride in on their white horses and solve this issue. Because, I have no earthly idea what this is all about! Well I do know that it sounds like an electric gremlin, but nothing beyond what you already probably knew.
__________________
Mike
"The answer is 42, I've thought about it quite thoroughly."
MBworld Gun Owners' Club Member #87
2007 Mercedes Benz C230
1998 BMW 528i (RIP)
2006 Honda Odyssey EX-L
1985 BMW 325e
1965 Chevrolet Corvair
http://www.mbworld.org/forums/c-clas...03-thread.html
mskembo is offline   Reply With Quote
Old 03-07-2011, 12:29 PM   #4
Drives: '11 E350
Invest in an OBDII scanner (125 shekels?) so you can read/clear the codes yourself. Random throwing of different codes could mean anything but are often a symptom of one thing happening in the ECU diagnostic string but showing up as a downstream failure. In the meantime check your battery connections and battery health....take a reading with a DVM...12.7V= full charge, 12.0V is near dead.
mleskovar is offline   Reply With Quote
Old 03-07-2011, 01:23 PM   #5
LOL, point me to the gremlin so I can shoot him down.
It's driving me nuts.
Tomorrow I'm at the garage.
Already told my mechanic that I don't care if he takes the whole damn car apart and build it from scratch. Can't have it go limp on my ... and certainly not on the freeway doing 90 ...
Click the image to open in full size. Click the image to open in full size. Click the image to open in full size.
Old 03-07-2011, 01:26 PM   #6
ODBII scanner something I'm planning to buy ... looking for a good deal or ebay opportunity.
About the battery ... will check tomorrow, hoping it's something as simple as that.
Cheers!
Old 03-07-2011, 07:39 PM   #7
Drives: C350 Elegance
I'd say it could not hurt to check level and condition of coolant. Maybe some oil in it?
These things can later be usually traced to faulty maintenance of elementary systems.
__________________
To establish a love raport with your car:
DEFENSIVE DRIVING-Never having to say you're sorry.
PREVENTIVE MAINTENANCE-Never will leave you stranded.
JoeVal is offline   Reply With Quote
Old 03-08-2011, 01:13 AM   #8
Update:
Coolant is full and by sticking the finger into the fluid I can confirm that it is also clear with no traces of oil.
Battery is 12.57V and 14.4V while engine is running.
Again this morning (and ironically, after I verified the coolant level) the car threw a "Coolant visit workshop" error. DUH!
The car is meticulously maintained ... I'm only 1/3 way between B's and all fluids and filters are new.
Frustration is building up ...
Old 03-08-2011, 05:51 AM   #9
Super Moderator
Glyn M Ruck's Avatar
Drives: late 2009 CLK 350 Coupe Elegance, '65 Jaguar S Type wires
The ESP message can be triggered by a whole host of things from failing Yaw sensors to wheel sensors to low battery. Listen to mleskovar & get an OBDII/CAN reader. No one with a modern car should be without one.
If the car stalls I would say the dash messages are a red herring unless you have a bad earth on a SAM etc.
Good luck!
__________________
Llandudno, Cape Town, South Africa
Glyn M Ruck is offline   Reply With Quote
Old 03-08-2011, 08:41 AM   #10
Super Moderator
johnand's Avatar
Drives: 2007 C230SS
Good luck!
Exactly. Almost impossible to accurately diagnose issues on these cars w/o a scanner. Hell, even with one they can be difficult at times.
johnand is offline   Reply With Quote
Old 03-08-2011, 09:47 AM   #11
Drives: 2011 C300
Quote:
Might this be the real issue?
LILBENZ230 is online now   Reply With Quote
Old 03-08-2011, 02:58 PM   #12
Super Moderator
__________________
Old 03-09-2011, 06:03 AM   #13
Update:
I've spent several hours with my mechanic today.
This time we saw this:
There is no problem with the EIS ... same as no prob with the ESP, Coolant or Display ... so next logical thing is to suspect the ECU.
ECU needs to be sent for a fix ... bye bye 700$.
Doing such a fix at the dealership would mean I have to part from my MB and pick it up few days later.
Instead, he fixed me up with a substitute ECU, EIS, steering wheel lock and turbo sensor so I'm driving the car until the ECU is back from the doctor.
Will update soon when I'm back on my hardware ...
Old 03-09-2011, 07:38 AM   #14
Super Moderator
ECU faults are extremely rare - good luck!
Why did he change the turbo sensor? Now that gives frequent trouble
__________________
Old 03-09-2011, 08:05 AM   #15
He claims that the replacement ECU wont work with my sensor and as soon as my ECU returns from the refit he will reconnect the old sensor, EIS and Steering lock.
Well ... all I can do is cross my fingers and hope for the best.
Oh and pay ... bahhh.
Old 03-23-2011, 01:18 PM   #16
Woo Hoo
Just got my ECU back!
So fun driving it again ... the replacement ECU allowed me to drive but somehow it wasn't feeling quite as my car.
I was trying to get pictures of all the procedure but I was slowing my mechanic down so I stopped before he kicks me out of the shop ... hehehe
Tags
203, battery, c200, c200cdi, c230, cdi, coolant, esp, failure, mercedes, oil, problem, problemer, visit, w203, workshop
Search this Thread:
Advanced Search
Display Modes Rate This Thread
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
Copyright © 2001-2012 InternetBrands, Inc. / MBWorld.org. All Rights Reserved.
Everyone's Personal Details
SEO by vBSEO 3.5.2
