C230 Kompressor Exhaust Diagram
Look online at the MB EPC under the category EXHAUST or on the MB Maintenance DVD Manual
I believe there is just the one integrated with the exhaust manifold. The other device is the resonator if I am correct.
Super Moderator
10 A 203 490 75 19 EXHAUST PIPE
FRONT [008], [009], [697]
001 R
10 A 203 490 89 19 EXHAUST PIPE
FRONT [010], [011], [005], [012], [697]
001 R
10 A 209 490 43 19 EXHAUST PIPE
FRONT [007], [013]
001 R
65 A 203 490 49 21 EXHAUST PIPE
REAR 001
65 A 203 490 62 21 EXHAUST PIPE
REAR [014], [015], [016]
Code: 949
001
Code: 950
001
65 A 203 490 77 21 EXHAUST PIPE
REAR [017], [018], [019]
Code: 949
001
Code: 950
001
Code: P84
001
Code: P85
001
REAR Code: 949+U88
001 R
REAR Code: 950+U88
001 R
REAR Code: P84+U88
001 R
REAR Code: P85+U88
001 R
REAR Code: 498+949
001
REAR Code: 835+949
001
REAR Code: 498+950
001
REAR Code: 835+950
001
REAR Code: 498+P84
001
REAR Code: 835+P84
001
REAR Code: 498+P85
001
REAR Code: 835+P85
001
68 A 209 492 02 14 .TAILPIPE TRIM Code: 949
001
68 A 209 492 02 14 .TAILPIPE TRIM Code: 950
001
68 A 209 492 02 14 .TAILPIPE TRIM Code: P84
001
68 A 209 492 02 14 .TAILPIPE TRIM Code: P85
001
80 A 170 990 00 10 SCREW
CATALYST TO EXHAUST MANIFOLD
M8X55
Replaced_By: A 129 990 04 10 002
80 A 129 990 04 10 SCREW
M8X58 002
90 A 210 492 74 41 HOLDER
FRONT EXHAUST PIPE TO TRANSMISSION Code: -424
001
FRONT EXHAUST PIPE TO TRANSMISSION Code: 411
001
FRONT EXHAUST PIPE TO TRANSMISSION Code: 422
001
90 A 210 492 62 41 HOLDER
FRONT EXHAUST PIPE TO TRANSMISSION Code: 423
001
95 N 910143 3008003 SCREW
BRACKET TO TRANSMISSION
M8X30 Code: -424
002
100 A 203 492 34 41 HOLDER
FRONT EXHAUST PIPE TO TRANSMISSION Code: 424
001
105 A 203 490 03 40 HOLDER
BRACKET TO FRONT EXHAUST PIPE Code: 424
001
110 A 202 492 07 18 RUBBER PAD
001
115 A 202 492 00 18 BASE PLATE
001
120 N 910105 5008019 SCREW
BRACKET TO BRACKET
M8 X 50 Code: 424
001
125 A 203 492 01 71 SCREW
M8X30 Code: 424
001
130 A 129 490 00 44 PLATE
FRONT EXHAUST PIPE TO BRACKET 001
140 A 120 142 00 72 NUT
BRACKET TO BRACKET
M8 Code: -424
002
190 A 202 492 01 81 SEALING RING
FRONT EXHAUST PIPE TO REAR EXHAUST PIPE 001
200 A 170 990 00 10 SCREW
M8X55 003
210 A 000 990 32 50 NUT
FRONT EXHAUST PIPE TO REAR EXHAUST PIPE 003
230 A 203 492 37 41 HOLDER
SUSPENSION REAR MUFFLER,LEFT 001
240 A 203 492 01 44 SUSPENSION RING
250 N 914007 7008044 COMBINATION BOLT
M8X25 001
260 A 000 490 00 27 MOUNTING MATERIAL
END PIECE FASTENING 001
270 A 111 990 22 04 .SCREW
END PIECE FASTENING
M6X12 001
320 A 203 490 00 40 HOLDER
SUSPENSION REAR MUFFLER,RIGHT 001
330 A 203 492 01 44 SUSPENSION RING
340 N 914007 7008044 COMBINATION BOLT
M8X25 001
360 A 203 490 01 40 HOLDER
EXHAUST PIPE SUSPENSION TO REAR AXLE 001
370 A 203 492 01 44 SUSPENSION RING
380 N 914007 7008044 COMBINATION BOLT
M8X25 001
Super Moderator
Sorry - forgot to post the manifold & Cat itself.
60 A 271 140 20 09 EXHAUST MANIFOLD
WITH CATALYST 001 L
60 A 271 140 22 09 EXHAUST MANIFOLD
UPSTREAM CATALYTIC CONVERTER Code: 494
001 L
60 A 271 140 21 09 EXHAUST MANIFOLD
WITH CATALYST
Replaced_By: A 271 140 27 09 Code: 926
001 L
60 A 271 140 27 09 EXHAUST MANIFOLD
WITH CATALYST
Replaced_By: A 271 140 30 09 Code: 926
001 L
60 A 271 140 30 09 EXHAUST MANIFOLD
WITH CATALYST Code: 926
001 L
65 A 271 140 03 09 EXHAUST MANIFOLD
TO THREE-WAY CATALYTIC CONVERTER
Replaced_By: A 271 140 31 09 001 R
65 A 271 140 31 09 EXHAUST MANIFOLD
TO THREE-WAY CATALYTIC CONVERTER 001 R
70 A 271 142 03 80 GASKET
EXHAUST MANIFOLD TO CYLINDER HEAD 001
75 A 271 142 00 72 NUT
EXHAUST MANIFOLD TO CYLINDER HEAD 008
80 A 004 994 14 45 SPRING NUT
SCREENING PLATE TO EXHAUST MANIFOLD 003 L
85 A 111 990 22 04 SCREW
M6X12 003 L
90 A 271 142 01 21 SCREENING PLATE
TO EXHAUST MANIFOLD 001 L
100 A 271 140 00 40 HOLDER
110 N 000000 0003161 SCREW
AT BRACKET
M8X25
Replaced_By: N 000000 0004425 001 L
110 N 000000 0004425 SCREW
AT BRACKET 001 L
130 A 002 540 18 17 OXYGEN SENSOR
UPSTREAM CATALYTIC CONVERTER 001
140 A 002 540 06 17 OXYGEN SENSOR
DOWNSTREAM CATALYTIC CONVERTER 001
160 N 000000 0002914 SCREW
ENGINE-TRANS. CONNECTION W. BRACKET FOR EXHAUST MANIFOLD
M10X50 002 L
WITH CATALYST 001 L
001 L
WITH CATALYST
001 L
WITH CATALYST
001 L
001 L
M6X12 003 L
AT BRACKET
M8X25
AT BRACKET 001 L
M10X50 002 L
Quick question... is the thing after the Headers/Cat combo a secondary CAT? or is it a resonator?
I have a clog somewhere downstream from my Headers, and replaced my CAT adjacent to headers with no luck... so I'm thinking it may be in the second segment, but I'm not sure what it is. If it is a resonator, then I'll just remove it and go straight pipe, but if it is a secondary CAT then i'll replace with OEM.
Glyn you are too nice! EPC accounts are free!
You can give a man a fish...well you know the story...
better to teach 'em to fish.
001 R
001 R
FRONT [007], [013]
001 R
REAR 001
Code: 949
001
Code: 950
001
Code: 949
001
Code: 950
001
Code: P84
001
Code: P85
001
REAR Code: 949+U88
001 R
REAR Code: 950+U88
001 R
REAR Code: P84+U88
001 R
REAR Code: P85+U88
001 R
REAR Code: 498+949
001
REAR Code: 835+949
001
REAR Code: 498+950
001
REAR Code: 835+950
001
REAR Code: 498+P84
001
REAR Code: 835+P84
001
REAR Code: 498+P85
001
REAR Code: 835+P85
001
001
001
001
001
M8X55
M8X58 002
001
001
001
001
M8X30 Code: -424
002
001
001
001
001
BRACKET TO BRACKET
M8 X 50 Code: 424
001
M8X30 Code: 424
001
BRACKET TO BRACKET
M8 Code: -424
002
M8X55 003
M8X25 001
END PIECE FASTENING
M6X12 001
M8X25 001
M8X25 001
001 R
001 R
FRONT [007], [013]
001 R
REAR 001
Code: 949
001
Code: 950
001
Code: 949
001
Code: 950
001
Code: P84
001
Code: P85
001
REAR Code: 949+U88
001 R
REAR Code: 950+U88
001 R
REAR Code: P84+U88
001 R
REAR Code: P85+U88
001 R
REAR Code: 498+949
001
REAR Code: 835+949
001
REAR Code: 498+950
001
REAR Code: 835+950
001
REAR Code: 498+P84
001
REAR Code: 835+P84
001
REAR Code: 498+P85
001
REAR Code: 835+P85
001
001
001
001
001
M8X55
M8X58 002
001
001
001
001
M8X30 Code: -424
002
001
001
001
001
BRACKET TO BRACKET
M8 X 50 Code: 424
001
M8X30 Code: 424
001
BRACKET TO BRACKET
M8 Code: -424
002
M8X55 003
M8X25 001
END PIECE FASTENING
M6X12 001
M8X25 001
M8X25 001
Hey c230 sportscoupe & Glyn,
I made an account on EPC (thanks for the suggestion).
Entered in the VIN for my 2003 c230 coupe, and a different exhaust diagram came up. (see attached).
Is this one correct? or does EPC have an error?
There seems to be an extra element (circled in blue) on the lower exhaust (resonator?). Can you confirm:
Blue circled = resonator ?
Red circled = 2nd CAT ?
The manifold/cat integration isn't down in the picture i posted (glyn posted it separately - post 7). I'm only curious about the exhaust piece AFTER this because there are two in question, and both look like they have a CAT, but one also an additional piece that looks like a resonator. Which one is m271 (coupe/sedan/other)?
I'm just trying to figure out which one is the m271 and which is m111 (or other).
Super Moderator
Midnight. All diagrams here are M271. You had better climb under your car to establish which set up you have. Blue box is definitely a resonator. I thought the previous box was also a resonator but maybe it is a secondary polishing Cat. I have personally never been involved with I4 exhausts. Only V6 exhausts.
2019 C300 Wagon; '75 Triumph TR6; previous: 2004 C230 6spd sold after 17 years of driving
Of all the M271 engines that I've worked one, none that I've encountered had an exhaust system looking like the picture posted. The manifold is one piece unit with the cat (VERY expensive) and the junction between that and the exhaust pipe is not even shown here. I think there is an labeling error for this diagram. Perhaps this is for the M111 or a diesel motor?
Super Moderator
Note that Midnight's diagram is either or. The second unit shown might be for areas with more strict emissions. The diagram I pulled was USA.
Super Moderator
Midnight. All diagrams here are M271. You had better climb under your car to establish which set up you have. Blue box is definitely a resonator. I thought the previous box was also a resonator but maybe it is a secodary polishing Cat. I have personally never been involved with I4 exhausts. Only V6 exhausts.
Basically.. I wanted to confirm because there is a clog somewhere after my primary headers/cat, and wasn't sure what else lied between this and my muffler since there were two m271 exhaust diagrams floating around.
One interesting point i noticed at the dealership: there are only O2 sensors pre and post the primary cat, so the second one must be a "secondary polshing CAT" like glyn suggested. Fortunately, there are no sensors pre/post the secondary CAT, so I'm going to just replace everything downstream of my primary CAT with straight pipe for a cheap fix (~$150) that should avoid any CEL's. Because replacing that secondary CAT would involve purchasing a exhaust section with a lot of unnecessary tubing (I was quoted $1015! from the dealer).
Thanks everyone for all the input. I just never new that there were two different OEM exaust set-ups for the m271.
Super Moderator
OK - interesting. So your car is set up like my M112 C240 was 2 primary Cats & 2 secondary cats. It's obvious that not all cars are like this however.
Super Moderator
