'01 C320 can't get into my trunk - anyone have this problem?
Old 12-16-2011, 02:27 PM
ViciousZ's Avatar
C-Class & ML55 AMG
Hi, i have a 2001 c320 and for some reason i can't get into my trunk, its been about a week now and with no luck, has anyone else had this problem? I've tried my button on the door to release, i've tried the remote and i just found the key hole on the trunk lid. I figured that the key was a sure thing, well no luck, all i was able to do was turn it so its parallel to the trunk and i'm not able to turn it back! Also, when i hit the remote and the door button, i hear nothing, so i'm not sure what when bad or wrong. Does anyone have any ideas?
Tony
Old 12-16-2011, 03:45 PM
golfster's Avatar
Titleist
I can't get into my trunk, anyone else had this problem?
[quote=ViciousZ;4964249]Hi, i have a 2001 c320 and for some reason i can't get into my trunk, its been about a week now and with no luck, has anyone else had this problem?
I can get into mine OK, but I find it uncomfortable for long periods of time. A few minutes is OK, then it feels dark and cold.
Old 12-16-2011, 04:41 PM
ViciousZ's Avatar
C-Class & ML55 AMG
I'm sooo jealous...nothing more would i love to be able to get into my trunk, even in the fetal position for that mater!
Is there a way to release the rear seats to put them down without opening the trunk? Is there possibly a fuse that went bad and if so where is it?
Old 12-16-2011, 07:44 PM
Super Moderator
samaritrey's Avatar
THE C350
I would check to see what position the handle is in if it is stuck in the open position it might not unlock and cause this issue. it is a known issue on w203's that the handle gets old and sticks. Mine does this so I have to make sure to put it back into position after i open it.
Old 12-16-2011, 07:52 PM
contact148's Avatar
2003 c240 4matic wagon
should have got the wagon...just reach over the back seat.......
Old 12-16-2011, 09:16 PM
zanga254's Avatar
Mercedes Benz C240 '02, BMW 325xi '02
One time i had a golf bag handle that was stuck in the trunk latch and i couldn't open the truck for a while until my friend and i pulled straight up in the small time frame the truck was actually unlocked. Maybe there's something caught in the latch?
Old 12-16-2011, 10:16 PM
Moviela's Avatar
I come home and all the best jokes have already been used for this topic.....
Old 12-16-2011, 10:33 PM
MbzShah's Avatar
C230 '05
I was just about to say that hahahah
Old 12-17-2011, 05:16 PM
ViciousZ's Avatar
C-Class & ML55 AMG
Still no luck, i've tried pushing down on the truck while hitting the latch and the remote, still no go. Also i hear nothing from the trunk when either pushing the button on the dorr or using the remote. Do you think it could be a fuse? everything looks good by the drivers door fuse panel.
Is there another way to get in through the back seats? I'm just about at my limit with it and going to break that little window that is behind the rear center armrest.
Old 12-17-2011, 05:43 PM
Super Moderator
samaritrey's Avatar
THE C350
That little window will do you no good unless you have rear folding seats it has metal there.
Old 12-17-2011, 05:45 PM
ViciousZ's Avatar
C-Class & ML55 AMG
I do have the rear folding seats...but the only way i know of to fold them down is the release levers in the trunk which i can't seem to get into.
Old 12-17-2011, 06:06 PM
phister's Avatar
06 C230 SS 6spd
Do you have the pass thru in the middle console? If so you can try and reach through there.
Old 12-17-2011, 07:01 PM
ViciousZ's Avatar
C-Class & ML55 AMG
yes i have that little door that is behind the rear center armrest...but that little door opens from inside the trunk right? I'm thinking that i might try to gently pop it open to access the trunk and release the fold down seats to get to my trunk, but was holding out as a last ditch effort.
Really would love to figure out why my trunk isn't opening tho
Old 12-17-2011, 08:02 PM
contact148's Avatar
is it frozen???
Old 12-17-2011, 09:25 PM
KalC240's Avatar
c240
Have you actually used the real metal key to open the trunk? Also, I seem to remember that the remote may not work if the actual lock position has been changed by the metal key. Read the manual...
Old 12-18-2011, 01:32 AM
jcnash's Avatar
2002 Mercedes Benz C230 Coupe
I used to have the same problem...then I joined a gym
Old 12-19-2011, 09:49 AM
LILBENZ230's Avatar
2019 G70 6MT & 2022 Ford Maverick XL
My metal key won't open my trunk, either, for the record.
Old 12-19-2011, 12:54 PM
Signmaker's Avatar
2001 C320
I have the same year C320 and recently had the same issue. As it turned out my key fob needed new batteries but the trunk was still a PIA to open even with the actual key. I just kept turning the key both ways while pulling the release and eventually got it to open. Then I cleaned and lubed the latch with lithium grease while moving the parts......mo more issues.
Old 12-19-2011, 01:17 PM
LILBENZ230's Avatar
Oh so you have to turn the key in the hole then pull the release.. well that explains it. I was trying just to turn the key and have the trunk pop open.
Old 09-12-2012, 05:27 AM
edgar63's Avatar
2001 c320
[QUOTE=ViciousZ;4965562]Still no luck, i've tried pushing down on the truck while hitting the latch and the remote, still no go. Also i hear nothing from the trunk when either pushing the button on the dorr or using the remote. Do you think it could be a fuse? everything looks good by the drivers door fuse panel.
Is there another way to get in through the back seats? I'm just about at my limit with it and going to break that little window that is behind the rear center armrest.[/
Old 09-12-2012, 05:33 AM
edgar63's Avatar
2001 c320
TAKE KEY OFF THE REMOTE STICK KEY IN THE TRUNK UNLOCK (THATS TURN KEY TO THE LEFT) AND PRESS THE TRUNK LEVER @ THE SAME TIME IT WORK FOR ME HOPE IT DOES THE SAME FOR YOU.... GOOD LUCK...... AND DONT WORRY ABOUT THE JOKES ITS A M/B THING KIND OF A WELLCOME ROOKIE..LOL
Old 09-12-2012, 06:49 AM
benzmodz's Avatar
W203 slightly modified
+1
If that fails you can break the left rear stop lamp and then work your way up to the trim and break the trim and pull the cable.
Sometimes that is what they do in Australia. But the above advise should work perfectly.
Old 01-22-2015, 01:48 PM
jj15's Avatar
2001 E 55 Amg
YES! Can't open my trunk.
I have been locked out of my trunk for months and badly need in. I have a 2001 E 55 amg. Please let me know if anyone can solve this problem.
QUOTE=ViciousZ;4964249]Hi, i have a 2001 c320 and for some reason i can't get into my trunk, its been about a week now and with no luck, has anyone else had this problem? I've tried my button on the door to release, i've tried the remote and i just found the key hole on the trunk lid. I figured that the key was a sure thing, well no luck, all i was able to do was turn it so its parallel to the trunk and i'm not able to turn it back! Also, when i hit the remote and the door button, i hear nothing, so i'm not sure what when bad or wrong. Does anyone have any ideas?
Tony[/QUOTE]
Quick Reply: '01 C320 can't get into my trunk - anyone have this problem?
