No brake lights?
2002 C230 Coupe
No brake lights?
The other day a guy tapped on my window to tell me my brake light weren't working, sure enough they aren't. All other lights work including tail lights, just no brake lights. Not even third brake lights. What could it be? Stop switch?
Super Moderator
Could be the brake light sensor it is like $15 and takes 10 minutes to install very common issue on early w203's
http://www.rmeuropean.com/Part-Numbe..._6491752E.aspx
Hi, mine has ESP/BAS set on dash and I have no brake lights. I reset the fail and tapped the brake pedal and ESP/BAS set again. Though mine is a W202 I suspect there not much different.
I am having trouble removing the OBD II connector from the "insulation cover". Any tips ? I have already removed the two mounting screws.
2002 C230 Coupe
ESP/BAS Fixed
Tried to find a new switch in town. No luck. Removed switch; sprayed thoroughly with electronic circuit cleaner blew dry with compressed air. Reinstalled: ESP/BAS cleared. Good fix.
Thanks for the info/help.
ok to follow up on this thread, my W203's right brake light is out and I changed the bulb, havent been able to check the fuse. I do have warnings on the dash but the real tricky part is that this only really started when one of my buddies slammed the trunk really hard like a freakin idiot the other day............
Any ideas??
Any ideas??
And its only the right side of the car that is doing this, the left is fine, so would it be the switch if its only one side??
Super Moderator
do any of the ligths work on the right side? Check the connector that goes to the light could have come loose also switch the bulb from the other side to see if the bulb is just bad.
Yes all the the lights work on the right side its just the brake light for some reason I will go and switch out the new bulb on the right to left to see if that does anything, Ill keep you posted
Thanks again, these forums really help!
