Sign in using an external account
| C-Class (W203) 2001-2007, C160, C180, C200, C220, C230, C240, C270, C280, C300, C320, C230K, C350, Coupe
Sponsored by : My Mercedes Parts ![]() |
LinkBack | Thread Tools | Search this Thread | Rate Thread | Display Modes |
#1 | ||
Heater produces oil/gas smell
#2 |
Drives: 2005 c230 kompressor 2003 s500 94 wrangler
did u have the cam magnet recall done?
#3 |
Drives: 2011 C300
Cam magnet recall not for the M111 in the 02 C230, nor will it cause this symptom.
#4 |
Super Moderator
So what happens when ac is on? Is it perfect or have you not tired?
__________________
Trey's Car History 87 Suzuki Samurai Gone :( 99 KIA Sportage 2Door Sold July 20 2009 97 J30 given when 16 Has been passed down to sibling 01 C320 Got at 16 as of 2-22-13 has 189,000 miles with Eurocharged Tune, AMG Style Trunk Spoiler, BIX, NAV 2.0, Tein Springs with Renntech Shocks Next car G55 or SLK55 All About Trey and Cars Thread
#5 |
Drives: 2005 C Wagon (No snickering please!)
Any time you smell fuel, it is time to stop and have a complete look at the fuel system.
It can be vey dangerous if you have a leak. It could turn your ride into a carbecue. |
#6 |
Drives: 2004 C240 Wagon
You may also want to check out your valve cover gasket. They can leak and drip a bit of oil on the exhaust manifold where it burns off, and you can get a whiff of burnt oil in the cab via the HVAC system.
Pretty common issue on both the V6 and Inline 4 motors. My right side VC gasket is just starting to leak a bit at 80K miles. You really need to determine if it is gas or oil smell, because, as Moviela notes, fuel leaks can be dangerous. Good luck on it ! |
#7 |
Super Moderator
Drives: late 2009 CLK 350 Coupe Elegance, '65 Jaguar S Type wires
+1
__________________
![]() Llandudno, Cape Town, South Africa |
#8 |
Drives: Here's Johnny!
In other words, when you turn on the heater, you're pumping in air that comes in directly under the hood.
So, whatever is stinking under the hood, is going to stink up your car. So, that includes any oil that's burning or exhaust leak. For me, I had to replace the manifold gasket a couple times due to exhaust leaks. Sitting at lights I'd choke. Moving, there was enough air circulation, you wouldn't notice it. Be sure to use the mercedes one, not one from the local auto parts store. I have a couple of extra ones, I could sell you one very inexpensively if that's the issue. But before you replace anything just look for leaks, and whats smelling and from where.. Tighten any loose nuts and bolts and see if that fixes it.
__________________
2002 C230 Sport Coup ASP Pulley-Supersprint Header-Remus Muffler- TEIN SS Coilovers AMG; Wheels, 22mm AMG Front sway bar, HR 19mm rear bar, C32 Brakes Tinted Windows- 2005 Tails, Grill & Blinkers-Clear Sides Bi-Xenon Headlights! Clear Fogs w/Philips Crystal Vision bulbs Audio 10 Renntech style Spoiler Supercharger Muffler Deleted! "Aero Turbine" AR20 Rasp Eliminator (Resonator)
| Tags |
| 2012, 240c, benz, c230, c240, class, cover, fuel, gas, gasket, gasoline, mercedes, smell, valve, w203 |
| Currently Active Users Viewing This Thread: 1 (0 members and 1 guests) | |
| Display Modes | Rate This Thread |
