Sign in using an external account
| C-Class (W203) 2001-2007, C160, C180, C200, C220, C230, C240, C270, C280, C300, C320, C230K, C350, Coupe
Sponsored by : My Mercedes Parts ![]() |
LinkBack | Thread Tools | Search this Thread | Rate Thread | Display Modes |
#1 |
Depo headlight question
#2 |
Drives: Correction, Drove An '05 C230 Kompressor SS
__________________
Jeff ![]() Mercedes Benz Owner's Gun Club, Member # 92 **Outkasted's C230 SS Project in the Making** ..... Traded In For a '13 VW GTI 11/09/2012. She Will Be Missed My W203 Part Out Thread http://mbworld.org/forums/c-class-w2...ers-oh-my.html |
#3 |
Gotta bake it in the oven dude! I know it sounds f**** up but you have to heat up the seal for it to come apart.
__________________
![]() -Petar- Mods: 18x8.5, 18x9.5 Brabus VI Reps, CF Front lip, Eurocharged ECU Tune, Black CL Grille & Flat Hood Badge, clear sidemarkers w/PIAA Xtreme White bulbs, PIAA Xtreme White running lights, AZN Optics interior/trunk/license plate LED lighting package, black DEPOs Mulac's c230 Project: http://www.mbworld.org/forums/c-clas...ml#post4646905 |
#4 |
Super Moderator
Yeah just don't touch a burner like I did
__________________
Trey's Car History 87 Suzuki Samurai Gone :( 99 KIA Sportage 2Door Sold July 20 2009 97 J30 given when 16 Has been passed down to sibling 01 C320 Got at 16 as of 2-22-13 has 189,000 miles with Eurocharged Tune, AMG Style Trunk Spoiler, BIX, NAV 2.0, Tein Springs with Renntech Shocks Next car G55 or SLK55 All About Trey and Cars Thread
#5 |
Drives: 2004.5 c230k
I used a heat gun on my headlights. had the lens off in 5 min. just gotta keep the heat gun continuously moving and never have it in one spot for too long. then after that peel of the lens from the body
#6 |
Never heard of this method but it sounds like it would be much better than baking the whole headlight in the oven!
__________________
#7 |
Im going to try that method first...
#8 |
Drives: 06 C230 SS 6spd
I use the heat gun method a well. Then just make sure you heat it as you reapply it together so its sealed nice and tight
#9 |
I can get a good hair dryer lol. I dont have a heat gun..
#10 |
Super Moderator
doubt a hair dryer will get hot enough
__________________
#11 |
I used it to get to do the carbon 3m vinyl wrap on my C55 and Mulacs 230. It may not work for this application though. So after I get it apart I can use the same adhesives again?
#12 |
i have the same problem!! Also, what paint are you using? Mine are completely baked and the lens cracked.
__________________
[/quote]
#13 |
heat guns are very inexpensive. I think I bought mine for like $20 at lowes.
#14 |
I havent chosen paint yet. Its obviously going to be some heat resistant. How did you paint your grill black? Are those heat guns decent quality? I may go check them out today.
#15 |
Blk Benz I have the same "baked" thing going on with mine. I pretty much just said f*** it and will just save up some money for a higher quality set of OEM Xenons, given that I can find them for a decent price!
__________________
#16 |
Hair dryers won't get hot enough to get the job done in a clean and timely manor.
Heat Guns can be a great tool but you must not leave it on a spot longer then 5 seconds. they get too hot and will bubble lenses and discolor painted surfaces. The Oven method is the best of the best. just about everyone that lives in a house has one, So no added equipment that has to be purchased. There won't be any hot spots to damage plastic or burn the sealant. All sealant will be evenly heated, there for the lenses will practically pull apart without a battle. As far as paint, I suggest VHT high heat. http://www.vhtpaint.com/products/engineenamel/ it goes on even like Krylon, and will not discolor after time like most other brands out there. Your headlight housings get battered by both the Sun and heat from the bulbs day in and day out, sometimes reaching temps over 200 degrees. Also, a trick to renew your clear headlight lenses once taken off the housings (using the oven method ), sand them down with 400grit sand paper evenly, both inside the Len's and out as needed to remove all yellowing, then re-sand the same areas with 1000grit evenly, I recommend a DA Air Sander for faster work.clean the whole surface of the lens with water and a lint free rag, then spray the housings with Body Shop quality Automotive Clearcoat (not rattle can spray), let it dry at least 24 hours and bam, Brand spankin new looking!!
__________________
#17 |
Luckily I had a spare set of halogen headlights, now my question is.. Can I use the lens from the halogen headlights and use them on my depo headlights? Im planning on VHT high temperature paint because my HIDs
__________________
[/quote]
#18 |
Well I want black housing and I am deff not painting the inside on a $800 oem xenon headlamp.. How long does it need in the oven?
#19 |
Why not repaint it? Im not trying to order another set of DEPOs, although I do want the chrome oem DEPOs.
__________________
[/quote]
#20 |
If I buy an oem xenon im going to most likely kep it how it is and not risk destroying it..
| Tags |
| black, c230, c240, cclass, coupe, depo, depot, headlight, headlights, lenses, mercedes, oven, paint, pulling, rattle |
| Currently Active Users Viewing This Thread: 1 (0 members and 1 guests) | |
| Display Modes | Rate This Thread |
