Go Back   MBWorld.org Forums > Mercedes-Benz Sedans > C-Class (W203)
Sign in using an external account
Register Forgot Password?
Register Photos FAQ Members Insurance Search Today's Posts Mark Forums Read CarsGarageVendors
Welcome to MBWorld.org Forums
Sponsored by : My Mercedes Parts
Click Here
LinkBack Thread Tools Search this Thread Rate Thread Display Modes
Old 04-07-2012, 09:51 PM   #51
Drives: C230, ML320, BMW 323Ci
LOL. Here is how I delt with it. Chain Replacement.
It's been fun, stressful, learning experience, and nerve wracking.
I'm almost done. Hoping to have it started in the next day or two.
I just hope I don't need a new engine after I'm all done.
To remove this ad, register today or login if you already are registered!
__________________
Quote:
Originally Posted by C230 Sport Coup View Post
The Bubba Watson of Mercedes Repair FTW!!!!
http://mbworld.org/forums/image.php?type=sigpic&userid=205795&dateline=13116  10165
Hogger is offline   Reply With Quote
Old 04-11-2012, 11:22 AM   #52
Drives: C230
I have a 05 C230 that I will need to change the engine, is it true that is a 10 hour job to do an engine swap?
I am planning on changing the engine myself, is there a step by step plan available detailing the engine swap? Also what type of programming will need to take place once the new engine is installed, or any other concerns I should be worried about.
Dune is offline   Reply With Quote
Old 04-11-2012, 01:42 PM   #53
Drives: W203
My indy did the swap in 10 hrs, no programming needed since the engine is the same and the ECU is reused.
The engine can be pulled straight up, you don't even have to remove the hood or radiator. As for step-by-step, if you need that this probably isn't the DIY for you. I'd start with draining all fluids, disconnecting all electrical and vacuum, disconnect intake and exhaust manifolds, disconnect AC and PS, disconnect the trans and it should be free. Then swap over the starter, alternator, ... to the new engine.
amanonfire is offline   Reply With Quote
Old 04-11-2012, 02:33 PM   #54
Drives: C230
Thanks, I have done many engine swaps on Chevy Race cars, I am familiar with the basic to do list, was just curious if there were any secret aspects to changing this engine. It is nice to know no programming is needed, pretty much disconnect the peripheral items, remove/replace and then hook everything back up.
I have the prospects of purchasing a used engine, what would you recommend replacing before I install, ie timing chain, etc?
Old 04-11-2012, 03:18 PM   #55
C230 Sport Coup's Avatar
Drives: Here's Johnny!
OOh, holy crap! Look on the left cam how the chain is bunched up!!!! Damn! And the engine looks clean even!
Click the image to open in full size.
__________________
2002 C230 Sport Coup
ASP Pulley-Supersprint Header-Remus Muffler-
TEIN SS Coilovers
AMG; Wheels, 22mm AMG Front sway bar, HR 19mm rear bar,
C32 Brakes
Tinted Windows- 2005 Tails, Grill & Blinkers-Clear Sides
Bi-Xenon Headlights!
Clear Fogs w/Philips Crystal Vision bulbs
Audio 10
Renntech style Spoiler
Supercharger Muffler Deleted!
"Aero Turbine" AR20 Rasp Eliminator (Resonator)
C230 Sport Coup is offline   Reply With Quote
Old 04-11-2012, 04:01 PM   #56
Drives: W203
If you've done an engine swap before this car will be easy.
I would recommend having the upper/lower vacuum hoses replaced (aka the infamous $12 hose), the cam isolation wires installed, and the vacuum pump gaskets. That would take care of the majority of little things that could go wrong on the new engine. Depending on the mileage of the engine, timing chain would be a good idea too.
Old 04-11-2012, 04:09 PM   #57
Drives: C230
I am fimiliar with the vacuum hoses and VP gasket, what are cam isolation wires?
For sure I am changing the timing chain since it was the reason my current engine crapped out.
Old 04-11-2012, 04:45 PM   #58
BF_JC230's Avatar
Drives: 1980 German w123 230 "Sport", and 2005 American w203 C230 Sport
I don't see this as anyone's FAULT on this forum (or any m271 owner)...rather I see the fault with Mercedes-Benz. This is not MENTIONED anywhere (Unless the "blanket statement" on Page 72 "At 143,000 miles, Check integrity of engine, mechanical components") also suggests and "means" replace timing chain.
In my opinion...this is poor, lousy and does not live up to the "former" MB tag line..."Engineered like no other car in the world."
Seems likes more like a "Recall / TSB" to me...Lousy...bad valves, poor original head design, leaking sensors, vacuum hoses, now timing chain failures...lousey.
__________________
My 1980 w123 has SOLD...
www.1980mb230.com
BF_JC230 is offline   Reply With Quote
Old 04-11-2012, 05:32 PM   #59
New tagline.
"Mercedes builds the best Italian Cars in the world"
__________________
TEIN SS Coilovers
C32 Brakes
Audio 10
Old 04-11-2012, 05:34 PM   #60
Drives: C230
I just got quoted $850 to swap the engine and $200 to change the timing chain on the used one I am going to purchase? What you guys think? Any concerns?
Old 04-12-2012, 09:33 AM   #61
Drives: 2011 C300
A timing chain should never need to be replaced. That's one of the benefits to this over a belt. So much for that!
LILBENZ230 is offline   Reply With Quote
Old 04-12-2012, 09:49 AM   #62
tommy's Avatar
Drives: 2002 C230
New tagline.
I would think: "Mercedes. They don't make 'em like they used to."
Dune, does that come with a warranty? If it's at least a six-month one, and preferably a one-year one, I'd say that's a good price, assuming you've checked them out and they seem to know what they're doing.
__________________
2002 Ccoupe, smurfalicious: OE chipped, RennTech pullied & rear spoiler, Carlsson lip, 18" OZ ultraleggera rims, RogueEngineering stud conversion, Eibach Pro springs/Koni Sport struts, Eibach swaybars, Supersprint headers, Eisenmann race exhaust, Magnaflow cat, Classic Soft Trim interior w/driver's Recaro Sport seat, clear OEM projector headlights, Sparco Racing shiftknob, Lightning Autosports alcantara shiftboot w/ Simoni gated shift surround
tommy is offline   Reply With Quote
Old 04-12-2012, 09:56 AM   #63
Drives: 2011 C300
I think that $850 was the cost to do the labor to swap it. The engine sold separately.
Old 04-12-2012, 10:35 AM   #64
tommy's Avatar
Drives: 2002 C230
Quote:
Yes, that's what I was referring to. The shop should warranty its work on the swap.
__________________
Old 04-12-2012, 10:46 AM   #65
Drives: C230
The engine, and labor have a 90 day warranty, considering I was going to do the swap myself and have no warranty on my work, $850 sounds good to me because of the 90 day warranty and I do not have to do the work.
I agree a timing chain should last longer, but to say it sould never be replaced is being a bit short sited.
Old 04-12-2012, 12:22 PM   #66
Drives: 2011 C300
I don't think you ever answered how many miles your car had?
Old 04-12-2012, 12:27 PM   #67
Drives: C230
2005 C230 with 103K miles, I would think a $37K Mecedes Benz, key word Mercedes Benz, should last longer than 103K before a major failure.
Old 04-12-2012, 01:18 PM   #68
Drives: W203
You'd think that, yet you'd be wrong. Rumour has it the W203 was not extensively tested, it was computer simulated thus why the W204 underwent extensive testing.
Old 04-12-2012, 01:33 PM   #69
Drives: 2011 C300
As far as I know that computer simulated testing is no rumor.. It's why the early W203s were so horrific.
Also, sorry, I do recall the mileage thing now. 103k and a new engine.. no excuse for that one.
Old 04-12-2012, 01:51 PM   #70
Drives: C230
So basically, I can expect future problems even with a lower milage engine being installed. Is there any preventative upgrades I can do to the engine before installing to better the life expectancy?
On the computer simulated testing, that is information I could have used in June of 2005.
Old 04-12-2012, 02:28 PM   #71
Drives: 2011 C300
Again I'm not going to even begin to excuse this at 103k miles, but to play devil's advocate just a bit the car was clearly showing warning of something being amiss for 3 months. In any of those three months of cold start noises, did you ever look into it?
It's not your fault either way. But a few of us on here have been trying to raise awareness about this and urge people to listen carefully (with door open) to cold starts in their M271s and look to replace the chain and tensioner as a maintenance item (even though it shouldn't be). Still 103k is too early.
Obviously you've owned the car since new, I assume you've followed the factory maintenance schedule as far as approved oils and change intervals.
Old 04-12-2012, 02:29 PM   #72
Change the timing chain, balance chain, tensioner, and guides. Make sure you have the new "$12 hose". And put in all new gaskets(head, intake, exhaust, and valve cover).
__________________
Old 04-12-2012, 02:35 PM   #73
Drives: C230
I did hear the noises for about 3 months, to be honest I did not get too concerned about it because I have a guy who cared for the car and he never mentioned any concern over the sound.
Old 04-12-2012, 02:59 PM   #74
Drives: W203
Same as I stated before: $12 hose (hoses, upper and lower), vacuum pump gaskets, cam isolation wires.
Plus good fuel and a heavy foot to keep carbon from building up. The head on the M271 is prone to bending valves if carbon builds up and causes a valve to stick. The $12 hose and cam magnet leak cause exacerbate this issue as they cause the engine to run rich.
If you fix these small issues you'll get a lot of life out of these engines. Unfortunately I've recommended several people not to buy these used unless they know the service history. I would not want a "lady driven" (aka carbon built up, poorly maintained) low mileage M271, even though this is what many look for on the used market.
Maybe the timing chain should become a maintenance item like a timing belt since most people aren't going to be knowledgeable enough to discern the rattle at startup as something eventually catastrophic.
I could have used it in Sept of 2002. I bought a Mercedes based off the reputation of the W202s being solid as a rock.
Old 04-12-2012, 06:54 PM   #75
Drives: 2010 SLK350
Dune.
$850 to swap the engine.
What happened to doing this yourself?
RedStripe is offline   Reply With Quote
Tags
2005, c230, chain, check, engine, forum, head, kompressor, m271, messing, part, powered, timing, vbulletin, wow
Search this Thread:
Advanced Search
Display Modes Rate This Thread
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
Copyright © 2001-2012 InternetBrands, Inc. / MBWorld.org. All Rights Reserved.
Everyone's Personal Details
SEO by vBSEO 3.5.2
