Help Please. 05 C230 Armrest Issues. It popped off.
Rating: Thread Rating: 4 votes, 5.00 average.
Old 04-05-2012, 02:23 AM
silvermamba's Avatar
2005 C230
I pressed the two side buttons on the armrest and the whole thing popped off. Before I would just press one button and one side opens up at time. I accidentally pressed both sides and now it popped off.
I managed to put it back with the pins and everything but when i press one button it pops open but it doesn't close up like it used to. Nothing looks broken though.. Maybe the pin mechanism is broken?
After spending a good amount of time on google search. this is a common problem with our interior.
Questions:
1) is it broken?
2) am i doing something wrong?
3) do you guys normally use it or just do you guys just leave it alone to prevent it from breaking?
4) When i press the two side buttons the pin doesn't really move inside i would have to press it down hard for it to kinda move in a bit. Is this normal or is it broken?
Old 04-05-2012, 02:30 AM
Peydidy's Avatar
C63 AMG
Thats so weird because the same exact thing happened to me. The first week I bought my car the same exact thing happened to me, I was still under warranty though so I took it in and they replaced my arm rest and CD changer because the magazine wouldn't come out. Good luck getting it fixed, sucks having problems right when you get a new car but this is pretty minor, I had to replace my EIS which cost me close to $1,500 and 2 weeks in the shop the first week I bought my coupe which REALLY sucked
Old 04-05-2012, 02:34 AM
2005 C230
yeah it annoying the hell out of me now lol.
Old 04-05-2012, 02:35 AM
2005 C230
somebody said here that there's a locking mechanism, but i cant seem to find it. is there even one?
http://www.benzworld.org/forums/w203...-arm-rest.html
Old 04-05-2012, 05:10 AM
C230 Sport Coup's Avatar
C230 Sport Coup + 2006 W164 ML350 + 99 Ford Escort (What the heck, it gets 38 mpg!)
Ha, I had loaners with those damn things, and they always come off.
Don't worry it's not broke, but there's a trick to doing it, like holding all the releases at once, play with it.
When you get it, it will hold all the points open so you can just put into place and let go.
You have to hold....uh...something...
I just figured it out.
Old 04-05-2012, 05:27 AM
Push in on the sides, and hold the front one, it'll lock the side ones...or
vs. versa.
Old 04-05-2012, 09:41 AM
LILBENZ230's Avatar
2019 G70 6MT & 2022 Ford Maverick XL
Accidentally pressed both sides...
Don't worry, you're not the first to do this. A friend of mine tried doing this to my car once for no apparent reason and I yelled at him before he could do it.
Old 04-05-2012, 09:50 AM
MBfinatic's Avatar
e36 318i, 2004 sti
This happened to me to! I messed around with it and hasnt done it since!
Old 04-05-2012, 10:14 AM
ND2020's Avatar
2004 C320 Sport
Clips in the back are not over the catch if I remeber correctly. Have to hold the clip up and lower the lid to get it over it. If that makes any sense lol
Old 04-05-2012, 12:03 PM
2005 C230
yeah I guess by pressing one of the two buttons on the side holds the clip. Mine doesn't really hold the clip steady any more. I tried a few times and it would hold it once out of six tries.
Now that I have the lid on top attached. When I do open the main armrest compartment, the main part gets stuck. because the locking and unlocking mechanism doesn't close up all the way so it get doesn't open up unless i move it back and fourth gently.
Old 04-05-2012, 12:08 PM
2005 C230
Also my cup holder doesn't popped up like the other c230's that i was looking at before buying mines.
Old 04-05-2012, 12:09 PM
LILBENZ230's Avatar
The get slow/sticky with age (the cupholders). You'll have to replace it or just deal with it, pull up on it.
Old 04-05-2012, 12:18 PM
2005 C230
i am now trying to replace it because of the combinations of problems with it =[. I wished I saw the problem before purchasing the car and make a note with the Belmont mercedes people.
Old 04-05-2012, 12:44 PM
2005 C230
Looks like the 2007 Armrest doesn't have the two side buttons:
Old 04-05-2012, 12:58 PM
LILBENZ230's Avatar
You're correct. The 2007s had several things missing that the earlier W203s had. No anti-tow alarm, light switch surround in black regardless of interior color, no leather inserts (varies), no rear door side airbags, etc.
Ovanluenen (12-27-2019)
Old 04-05-2012, 03:05 PM
Take the cupholder out, and soak it in some soapy water to get all the sticky
yucky stuff out.
I replaced mine with new, and then found that's all it needed, worked perfect after, and sold the old one to a forum member for $30!
Old 04-05-2012, 03:07 PM
Thankfully.
That side button thing drove me nuts, and that was just with loaners!
Never had an issue with the 2002, except being careful not to crush stuff.
Old 04-05-2012, 03:42 PM
2005 C230
I got it to settle and now it opens and closes. I just wont be pressing the side buttons ever again lol.
Old 04-05-2012, 03:47 PM
LILBENZ230's Avatar
It's fine to press one or the other. Just don't have a "wonder what this does" moment and press both.
Old 07-10-2014, 12:11 AM
bradbieze's Avatar
2005 C230 Kompressor
Center Arm Rest
The left-side pins on my center arm rest broke for my 2005 C230 Krompressor. Basically they seem stuck and when I press the buttons the pins do not move. I have looked around on eBay, but no luck. Mercedes told me that it would cost $500 to replace it -just the top part, not the entire console. Does anyone have any suggestions on how to fix it, or know anyone willing to sell one?
Thanks,
Brad
Old 07-18-2014, 03:03 PM
professort4u's Avatar
C230 Sport
Not as hard as you may think
Its quite easy actually! Take off the armrest completely. On the underside you will see the 4 pins that goes into the housing to form the hinges, towards the back the curved clips that assists in the pivoting and towards the front, the tongue used to release the locking device for either the upper tray or the lower compartment. There is a sequence to follow. First push down on the front tongue. While down squeeze in the side buttons. Hold it hard. The 4 pins will retract slightly. One at a time push down on the back curved arm all the way back. This movement will cause the assembly to lock in place for install and the 4 pins will retract all the way in. Gently place the armrest cover in place and then when aligned correctly, press down hard on the back and the front. The pins will come out and fasten inside the housing and the curved arms will lock into place too. Operate as usual. i will try to attach some pictures. Hope that helps somebody.
Attached Thumbnails Help Please. 05 C230 Armrest Issues. It popped off.-sam_6399.jpg   Help Please. 05 C230 Armrest Issues. It popped off.-sam_6397.jpg   Help Please. 05 C230 Armrest Issues. It popped off.-sam_6390.jpg   Help Please. 05 C230 Armrest Issues. It popped off.-sam_6395.jpg   Help Please. 05 C230 Armrest Issues. It popped off.-sam_6402.jpg
Old 08-10-2014, 08:24 PM
delphiki's Avatar
Thank you very much! Couldn't figure out how to fix this for the life of me.
Old 08-11-2014, 07:18 AM
C230 Sport
delphiki, you are very welcome.
Old 09-02-2014, 04:35 PM
boringchap's Avatar
C200K SE Elegance Auto
Brilliant solution!
Thanks very much indeed, clear instructions, straightforward fix as soon as I read your post. Btw, my car is a 54 plate c200 komp est. That's the 3rd time I've found a solution to a real head scratcher of a problem. Live this site!
Old 09-02-2014, 07:38 PM
clkcadet's Avatar
S550
Mine actually does not open when you hit the side button. Does anyone know how to release it (assuming the CLK has a similar design to the W203)
You have already rated this thread Rating: Thread Rating: 4 votes, 5.00 average.
Quick Reply: Help Please. 05 C230 Armrest Issues. It popped off.
