Sign in using an external account
| C-Class (W203) 2001-2007, C160, C180, C200, C220, C230, C240, C270, C280, C300, C320, C230K, C350, Coupe
Sponsored by : My Mercedes Parts ![]() |
LinkBack | Thread Tools | Search this Thread | Rate Thread | Display Modes |
#1 | ||
Drives: 2005 mercedes benz c230
rear brake wear harness missing
#2 |
Drives: 06 C230 SS 6spd
Usually only one side has the sensor. You can order one from rmeuropen.
#3 |
I have the rear brake sensor. The problem is the harness to connect the rear brake sensor is missing. I know it was there before and out from nowhere its gone.
#4 |
Drives: 2005 C230K, 2006 C230
My understanding is that on the C230s, there is only one brake wear sensor - the passenger side front. I'll know for sure when I go to change my rear pads this weekend.
__________________
Mercedes Benz World Owner's Gun Club, Member #91 2005 C230K (Diamond Black Metallic) 2006 C230 (Iridium Silver) 1974 Lotus Europa (White) |
#5 |
#6 |
Like I said you can call up rmeuropean.com and they probably have it.
#7 |
Drives: 2010 SLK350
So then you must have a "brake pad wear see workshop" light on in your cluster?
#8 |
Yup I get the error message. When they tried to install the sensor the connector was missing
#9 |
Super Moderator
Drives: late 2009 CLK 350 Coupe Elegance, '65 Jaguar S Type wires
During 2005 the rear sensor was removed from cars to the US to save cost. Cars vary from 4 sensors on earlier & SA built cars to one on LHS front only on US cars.
__________________
![]() Llandudno, Cape Town, South Africa |
#10 |
Finally fixed it. I will never take my car outside the dealership. They installed my old brake sensors.
#11 |
Drives: 2011 C300
Then you'll always pay thrice as much as you should. Glad you got it fixed. My 05 does not have a rear brake sensor.
| Tags |
| 06, 2006, 2007, 2010, benz, brake, c230, c300, harness, location, mercedes, missing, passenger, rear, sensor, side, w203, wear |
| Currently Active Users Viewing This Thread: 1 (0 members and 1 guests) | |
| Display Modes | Rate This Thread |
