Go Back   MBWorld.org Forums > Mercedes-Benz Sedans > C-Class (W203)
Sign in using an external account
Register Forgot Password?
Register Photos FAQ Members Insurance Search Today's Posts Mark Forums Read CarsGarageVendors
Welcome to MBWorld.org Forums
Sponsored by : My Mercedes Parts
Click Here
LinkBack Thread Tools Search this Thread Rate Thread Display Modes
Old 04-13-2012, 11:25 PM   #1
MBfinatic's Avatar
Drives: e36 318i, 2004 sti
https://www.facebook.com/tim.hall.980 HK SHIFTY
6MT operating question!
Ok so lately I have been having a problem with my 6MT. Does anyone have any diagrams regarding it? My question is does this transmission have a slave cylinder? I was able to use all data for a minute and couldnt find a slave cylinder. Only a master cylinder located next to the pedal.
Thanks in advance!
To remove this ad, register today or login if you already are registered!
MBfinatic is offline   Reply With Quote
Old 04-14-2012, 10:26 AM   #2
Drives: 2005 C230K, 2006 C230
Recently somebody posted that he was going to change his clutch and posted links to some kits. The kits included a circumferential slave cylinder.
I haven't seen parts lists, schematics, or physical evidence, but I'd bet that's the case. That also means that you'll probably have to drop the tranny to service the slave cylinder.
What sort of issues are you having?
__________________
Mercedes Benz World Owner's Gun Club, Member #91
2005 C230K (Diamond Black Metallic)
2006 C230 (Iridium Silver)
1974 Lotus Europa (White)
ncmudbug is offline   Reply With Quote
Old 04-14-2012, 10:32 AM   #3
MBfinatic's Avatar
Yes I did see that thread. The clutch kit wasnt made for these cars specifically right? My issue, Ever since I got the car the Clutch seemed to engage (different). Now once and awhile when I WOT and shift the clutch pedal doesnt return fast. It will slowly engage gear and than take a second to fully return. I do NOT ride the pedal when I drive. I have a feeling the previous owner did however.. . I only have 30k.. Im worried to drive her now and be stranded like my subaru did to me all the time...
Old 04-14-2012, 10:47 AM   #4
The kit may have been for a C230 which would have peaked my interest but I suspect that they are all similar. I think outside slave cylinders are obsolete now.
Does your clutch drag? It could be the spring in your clutch, but I doubt it. It seems to me more likely that it's one of your cylinders. It could be either one. Unfortunately, I don't know how I would easily test it. If you disconnected the hose from the master to the slave and then pressurized the line, it might tell you if if the master is the problem.
__________________
Old 04-14-2012, 11:36 AM   #5
MBfinatic's Avatar
Ok thanks for the help! I was told to order the master and I did. I will try to test it asap.
Old 04-14-2012, 12:55 PM   #6
If you have a new master cylinder, that makes it a little easier. You change that and bleed it and see if that solves the problem.
I was thinking about my test a little more and there are some things I'm not sure of that may make it an ineffective test. For example, how much pressure should you put on the fluid to the master to see if it retracts? If you do do the test, the situation may become obvious, but if not, you may not learn much. It's a situation I don't think I've seen before.
One thing I forgot to ask is are you losing fluid? If you are and you don't see it near the master, it's probably the slave. Is there a way to see if fluid is collecting from the slave? That might be another check. As I think about it more, I suspect that one or the other or both cylinders is leaking. It's highly unlikely that the spring from the clutch is failing.
One thing to remember is that all things being equal, the clutch hydraulics will not last as long as the brake hydraulics since it's being used a lot more.
__________________
Old 04-14-2012, 02:02 PM   #7
Drives: 2010 SLK350
It's my fault for confusing Tim. I've had him convinced that there was not a slave cylinder, not in the traditional sense at least. I told him that his throwout bearing was operated by a hydraulic line that runs "inside the tranny". My bad for not knowing it's actually called a circumferential slave cylinder.
I think the take home point here either way is that it looks like the master cylinder is the only one that can be ordered separately? where this "CSC" may only be available in a kit with the clutch?
So, he's almost gotta attempt the master cylinder first before needing to drop the tranny
RedStripe is offline   Reply With Quote
Old 04-14-2012, 02:52 PM   #8
Yeah, those new fangled technology things can throw people off!
I first saw those circumferential slaves was for race cars. I didn't realize that they are used in street cars. I'm not sure the reason. It is simpler because there is no linkage, etc., but then if you need to change it it's a bigger deal.
I would assume it can be ordered separately, but it might make sense to replace the whole thing while the tranny is out since it's such a pain to take it out again.
I really think think trying a new master is the way to go. At the worst, you end up with a new m/c and since this stuff wears faster than the brake master, he's that much ahead of the game. If the slave is bad... well, it was bad already and he's only out the cost of the m/c but I think it is a good investment on a couple of different levels.
__________________
Old 04-15-2012, 03:50 PM   #9
MBfinatic's Avatar
SO was driving last night and pedal got stuck all the way depressed
Old 04-15-2012, 04:11 PM   #10
How did you get home? Did you ever notice any fluid leaking?
__________________
Old 04-15-2012, 04:24 PM   #11
Drives: 2006 c230
Quote:
ouch... so whats your plan of attack?
__________________
2006 w203
vdemon311 is offline   Reply With Quote
Old 04-15-2012, 04:39 PM   #12
maverik259's Avatar
Drives: 05 C230K SS (sold), 06 C55, 08 Yamaha R1
Damian Roudebush
dang man...hope you get this figured out soon...
__________________
05 C230k:
check thread
06 C55:
OEM Maple l BRABUS illuminated gear shift l 5.5AMG badge l SLK55 6/4 calipers l C63 paddles l 2nd cat/res del l 55k airbox l kevlar intakes l K&N l Eibach rear sway l silver cluster l Dig HVAC l iTronic l EC tune l flat badge l remote start l folding mirrors l LED door sills l VCS l W204 side view mirrors l CLK55 grille
coming soon:
CLK63 Bumper l Kleeman headers l MHP thermostat l DTM steering wheel l Euroteck lip l kompressor
maverik259 is offline   Reply With Quote
Old 04-15-2012, 04:42 PM   #13
Drives: 2002 ML320 2007 C280 avantgard
so sorry to hear that! so either way on standard or automatic were screw with transmission problems on the w203
kikev is offline   Reply With Quote
Old 04-15-2012, 05:19 PM   #14
MBfinatic's Avatar
I was on the freeway and just pulled it back up. There is no fluid leak that i have found. I just pulled the pedal back up with my hand while on the freeway. It feels like a clutch pedal on a miata... . My first attempt is to fix the master cylinder.
Old 04-15-2012, 06:57 PM   #15
maverik259's Avatar
Damian Roudebush
weird im at 80+k miles and have never had any issues with mine, bought it with 40k on it 4 years ago...only glitch that it has is it doesnt like going into first sometimes on the first shift, i have pump it back and forth 2-3x before it decides to slide into gear...weird
__________________
05 C230k:
check thread
06 C55:
coming soon:
Old 04-15-2012, 07:00 PM   #16
MBfinatic's Avatar
Yeah im assuming that the previous owner (a girl and i have many reasons to believe so!) operated the car with her left foot resting on the clutch pedal..
Old 04-15-2012, 07:22 PM   #17
If she rode the clutch, you may have to replace the throwout bearing and disk pretty soon... Yikes!
__________________
Old 04-15-2012, 07:32 PM   #18
MBfinatic's Avatar
Quote:
Disk as in clutch? Ugh
Old 04-15-2012, 09:03 PM   #19
Yep. Disk as in clutch disk. If she rode the clutch pedal, the disk is going to rub against the pressure plate and the flywheel - like dragging the brakes. Ugh! is right!
__________________
Old 04-15-2012, 09:18 PM   #20
MBfinatic's Avatar
My mechanic friend tested the clutch (idk if this method works) in idle he put it into 6th and it still moved forward indicating the clutch was still strong? Has anyone heard of this method?
Old 04-15-2012, 10:50 PM   #21
That doesn't seem like much of a test to me. The test you want is how well does it hold under high torque. What does it do when you are accelerating from a stop? going uphill? Does the clutch slip or chatter? Of course in your case, the problem is with the actuating mechanism.
If it ends up that you have to change the slave cylinder, I would advise you to change all of it while you are at it. You'll know what you have and you know you won't have to go in your bell housing for a long time.
__________________
Old 04-15-2012, 11:44 PM   #22
glocati's Avatar
Drives: 2004 C240 Wagon
That's actually a pretty good test and is used a as fairly accurate measure of how much friction/bite your clutch disc has.. Theory/thinking being that if the clutch can move the car (which from a stop, in 5th or 6th gear takes a lot of friction without slipping) then the clutch disc itself is in decent shape.
Does your clutch slip if you nail it in 5th or 6th gear?
Finatics problem seems more hydraulic in nature and i think he's on the right track with the cylinder/hydraulics.
glocati is offline   Reply With Quote
Old 04-15-2012, 11:55 PM   #23
I'd never heard that test so this might be another time for me to learn something! Thanks, glocati!
I agree that his problems are likely hydraulic in nature. My concern was that if the PO rode the clutch pedal a lot, the life of his clutch could be a lot less than expected. If the hydraulic problem was the slave cylinder, it might be advisable to replace it all since it is probably a bear to get the tranny out and replace the slave. However, I don't know how bad it really is since I've never done it... It just looks like a bear!
Thinking further, I'd like to modify my previous comments. A lot depends on if the clutch is over designed or under designed for the motor. I have known of some cars where the clutch was somewhat fragile. I haven't heard of any lately (so maybe that is more a thing of the past) and it's probably more likely that MB over designed the clutch rather than under designing it. If the slave needs to be replaced, the other clutch components should be inspected and may not necessarily need to be replace. I might replace the throw out bearing regardless, but then I'm a little paranoid about them. It probably comes from my days with an old '70 VW Beetle!
__________________
Old 04-16-2012, 04:24 PM   #24
MBfinatic's Avatar
The car has made a chatter noise before from a normal start in 2nd at a light?
It has not slip. I was racing when it happen. It holds all the way to red line.
Yes, Now I really need a diagram showing the fluid reservoir. Does it has its own or share with the brake fluid? I was told by my teacher to do a bleed test and see if that works before I replace the master cylinder. I checked all data and could not find a diagram. It also says to remove my pedals but does not give instructions on how to do this task..
Old 04-16-2012, 04:55 PM   #25
Drives: 2011 C300
Jim, just how expensive is this throwout bearing replacement?
LILBENZ230 is offline   Reply With Quote
Tags
1974, 2006, amg, back, c350, clutch, coming, europa, hydraulic, intake, jammed, lotus, manifold, mercedes, pedal, stiff, throttle
Search this Thread:
Advanced Search
Display Modes Rate This Thread
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
Copyright © 2001-2012 InternetBrands, Inc. / MBWorld.org. All Rights Reserved.
Everyone's Personal Details
SEO by vBSEO 3.5.2
