Go Back   MBWorld.org Forums > Mercedes-Benz Sedans > C-Class (W203)
Sign in using an external account
Register Forgot Password?
Register Photos FAQ Members Insurance Search Today's Posts Mark Forums Read CarsGarageVendors
Welcome to MBWorld.org Forums
Sponsored by : My Mercedes Parts
Click Here
LinkBack Thread Tools Search this Thread Rate Thread Display Modes
Old 04-15-2012, 05:14 PM   #1
Drives: 2001 C320 Automatic
DIY Tailight Removal and VHT Nightshades w203
I have a 2001 c320 just got my VHT nightshade bottles in. Any tips on removal? also do i have to buy duplicolor? if so where? is sand paper needed ?if anyone has a clear picture by picture DIY that would be great thank u
To remove this ad, register today or login if you already are registered!
Ivanrad is offline   Reply With Quote
Old 04-15-2012, 06:52 PM   #2
TheXenochrist's Avatar
Drives: c240
TheXenochrist
Removing the tail lights is pretty simple:
Photo DIY: Removing W203 Tail Lights
The third brake light it a little tricky though.
You dont need to sand down your lights, just give them a rinse with some water and wipe them down. I didnt put any clear coat on my lights either. Everything seems to be fine.
__________________
PureMB.com
TheXenochrist is offline   Reply With Quote
Old 04-15-2012, 07:11 PM   #3
maverik259's Avatar
Drives: 05 C230K SS (sold), 06 C55, 08 Yamaha R1
Damian Roudebush
if you want like a mirror finish to them you should wet sand in between clear coats with like 2k grit...let dry and next coat, then final coat wet sand till they're hazy but smooth to the touch, then apply polish and buff them out and they will look great...
__________________
05 C230k:
check thread
06 C55:
OEM Maple l BRABUS illuminated gear shift l 5.5AMG badge l SLK55 6/4 calipers l C63 paddles l 2nd cat/res del l 55k airbox l kevlar intakes l K&N l Eibach rear sway l silver cluster l Dig HVAC l iTronic l EC tune l flat badge l remote start l folding mirrors l LED door sills l VCS l W204 side view mirrors l CLK55 grille
coming soon:
headers l MHP 180deg thermostat l DTM steering wheel w/ shifters l Euroteck front lip l OEM kompressor
maverik259 is online now   Reply With Quote
Old 04-15-2012, 07:12 PM   #4
maverik259's Avatar
Damian Roudebush
although i vinyled mine with a heat gun so i didnt have to do all of that lol...not absolutely perfect and required stretching in areas but they look great from every angle...
__________________
05 C230k:
check thread
06 C55:
coming soon:
Old 04-15-2012, 07:17 PM   #5
Okay just bought a pry tool. Do i really need to wait 48 hours for everything to dry
Tags
brake, c300, clear, finish, light, mbworld, mercedes, mirror, nightshade, nightshades, niteshades, removal, remove, vht, w203
Search this Thread:
Advanced Search
Display Modes Rate This Thread
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
Copyright © 2001-2012 InternetBrands, Inc. / MBWorld.org. All Rights Reserved.
Everyone's Personal Details
SEO by vBSEO 3.5.2
