Go Back   MBWorld.org Forums > Mercedes-Benz Sedans > C-Class (W203)
Sign in using an external account
Register Forgot Password?
Register Photos FAQ Members Insurance Search Today's Posts Mark Forums Read CarsGarageVendors
Welcome to MBWorld.org Forums
Sponsored by : My Mercedes Parts
Click Here
LinkBack Thread Tools Search this Thread Rate Thread Display Modes
Old 05-06-2012, 09:20 PM   #1
Drives: 2005 c230 kompressor 2003 s500 94 wrangler
wheel hub
i just changed both outer tie rods and good news is that shut up the popping noises when turning..
but now my mechanic said i need the entire wheel hub assembly for 180
he said they need a press to put the wheel hub onto the car..is this right?
cant i just get the bearing?
To remove this ad, register today or login if you already are registered!
sammydragon3 is offline   Reply With Quote
Old 05-07-2012, 02:53 AM   #2
SeaCoupe's Avatar
Drives: 2002 C230K, 85 Bertone X1/9 (Spiagga), 2011 BMW 328 'vert
The press is to press the new bearing into the existing hub. If the hub is bad, he should be able to show you a scored hub once it is off the car. I have over 225k miles on my car and I have no bearing issues.
With the car on jacks, do you have lateral play on the wheel? That's a sign of bad bearings.
__________________
'02 C230 Coupe Mods by preference
* Bi-Xenon Lights *
* AMG Brakes *
* Kleeman Pulley *
* H&R Cup Kit *
* AMG 203 17" Staggered rims *
* Supercharger Ported by Stiegemeier *
Vote VRAA for Austin F1 GTG Chairman.
SeaCoupe is offline   Reply With Quote
Old 05-07-2012, 10:08 PM   #3
should i buy the wheel hub with the bearing or just the bearing?
Old 05-08-2012, 08:16 AM   #4
Super Moderator
Glyn M Ruck's Avatar
Drives: late 2009 CLK 350 Coupe Elegance, '65 Jaguar S Type wires
You should only require the bearing unless the hub is damaged.
__________________
Llandudno, Cape Town, South Africa
Glyn M Ruck is offline   Reply With Quote
Tags
2006, assembly, benz, c230, car, hub, kompressor, lateral, mbworld, mercedes, play, rules, tool, w203, wheel
Search this Thread:
Advanced Search
Display Modes Rate This Thread
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
Copyright © 2001-2012 InternetBrands, Inc. / MBWorld.org. All Rights Reserved.
Everyone's Personal Details
SEO by vBSEO 3.5.2
