Sign in using an external account
| C-Class (W203) 2001-2007, C160, C180, C200, C220, C230, C240, C270, C280, C300, C320, C230K, C350, Coupe
Sponsored by : My Mercedes Parts ![]() |
LinkBack | Thread Tools | Search this Thread | Rate Thread | Display Modes |
#1 | ||
Drives: w203 03 c240
waterpump replace now no heat
#2 |
Drives: '02 C230 Coupe (Me) '03 SLK320 6MT (Wife)
I am thinking that I remember reading somewhere that if you don't bleed all the air out of it, an air-bubble can get trapped and keep you from getting heat. Maybe someone else can chime in and tell you how to make sure this doesn't happen?? Or...I could be completely wrong. Just a fuzzy memory that sort of makes sense.
#3 |
Drives: not a merc
I assume you mean no Heaters?
yes try bleeding the system, airlocks will cause an issue |
#4 |
Thanks guys how do i do that
#5 |
Super Moderator
Drives: late 2009 CLK 350 Coupe Elegance, '65 Jaguar S Type wires
Bleed & check that the auxilliary pump is working - mounted near the surge tank.
__________________
![]() Llandudno, Cape Town, South Africa |
| Tags |
| 2007, 350, benz, c230, c240, change, clk, heat, mbworld, mercedes, org, pump, replaced, replacement, w203, water, waterpump |
| Currently Active Users Viewing This Thread: 1 (0 members and 1 guests) | |
| Display Modes | Rate This Thread |
