Sign in using an external account
| C-Class (W203) 2001-2007, C160, C180, C200, C220, C230, C240, C270, C280, C300, C320, C230K, C350, Coupe
Sponsored by : My Mercedes Parts ![]() |
LinkBack | Thread Tools | Search this Thread | Rate Thread | Display Modes |
#1 | ||
Drives: C230 2006
Oil that looks like peanut butter...
#2 |
Drives: 2006 C230 SS
Looks like you've got a serious internal coolant leak somewhere....get that checked ASAP.
__________________
![]() 06 C230 Sport 6 Speed , Staggered 18 inch Forgestar F14s, Custom Magnaflow dual exhaust, KW Varient 1 Coilovers, CF rear diffuser, C55 AMG Lip, custom quad projector 6000K DDM Tuning Bi-Xenons, 5000K white LED side markers, 5000K LED license plate bulbs |
#3 |
Drives: CLK63 Black Series
There could be some serious damage depending on how long the car was run like that. Needing a new engine wouldn't be out of the question.
visit workshop!
__________________
2012 VW Golf R 1999 Chevrolet Corvette 1989 BMW 325i 2002 GSX-R 750 2008 Mercedes-Benz CLK63 AMG Black Series (sold) 2004 Mercedes-Benz CLK500 (sold) |
#4 |
Drives: 2003 C230 Sports Coupe, Paprika Metallic Red, Auto, Pano, Leather
If you have engine oil leaking into coolant system, do you also have coolant leaking into engine oil system? Perhaps a leaking (head) gasket that's supposed to keep the engine oil and coolant separate. Is the exhaust coming out of your exhaust pipe a whitish blue colour with a sweet smell?,... indicating there's coolant in your engine oil. How long has this been going on? If its just a head gasket then that'll need to be changed along with an engine flush and coolant flush should also be done. You'll also have to check for internal engine damage depending on how long it was running without proper lubrication.
Are you sure its engine oil as opposed to transmission oil which should be a bit reddish. Some of the earlier W/CL203 had Valeo radiator that tend to leak coolant into transmission via transmission cooler. Even though yours is a 2006 and not likely to have a Valeo radiator, I would assume that a broken transmission cooler could leak transmission oil into your coolant. |
#5 |
Drives: C230 2006
No smoke is coming out of the exhaust pipe. The coolant is like peanut butter but the engine oil still looks good. Does this mean that the engine is still ok and does not need to be replaced? Because we are being told by my mechanic that we need to replace the whole engine, the radiator, and other things related and that it will cost us about $7000+.... Is that true?
#6 |
What do you mean "coolant is like peanut butter". Its peanut butter colour? Or consistency? Smooth peanut butter or crunchy flavor??? Photo would be nice.
First of all you have to figure out where the leak is coming from. How is this engine oil (or transmission oil) getting into your coolant system??? Most likely a leaking head gasket or hose improperly remounted,... maybe a few hundred dollars to fix. Instead of troubleshooting for the leak, it seems that your "mechanic" would rather just replace the entire engine and radiator. Is your mechanic from a Mercedes-Benz Stealership, MB indy or just a regular mechanic. My suggestion, get a real mechanic,... a second opinion,.... an honest opinion,.... before you even think about spending that kind of money. Whats the mileage? |
#7 |
Drives: C230 2006
Peanut butter in both color and consistency. Mileage is 80,000.
#8 |
Drives: c240
#9 |
Drives: 05 crossfire w/SL55 drivetrain installed by Rudy Compart Intake/Needswings best et-11.22 @ 126
cracked head or block,, maybe head gasket but i bet on cracked head, did the car over heat within the last 3 to 4 months? if yep! then get the engine apart and find the leak,, the leak is the oil in getting into the coolant,--means the higher pressure of a combustion chamber is higher than the 16lbs of water pressure,, at night when in traffic, with cars maybe 10 car lengths behind you,,,floor it or just take off hard you will see a big cloud of smoke, that you cannot see in the day time,,,good luck. jim
#10 |
Drives: Here's Johnny!
__________________
2002 C230 Sport Coup ASP Pulley-Supersprint Header-Remus Muffler- TEIN SS Coilovers AMG; Wheels, 22mm AMG Front sway bar, HR 19mm rear bar, C32 Brakes Tinted Windows- 2005 Tails, Grill & Blinkers-Clear Sides Bi-Xenon Headlights! Clear Fogs w/Philips Crystal Vision bulbs Audio 10 Renntech style Spoiler Supercharger Muffler Deleted! "Aero Turbine" AR20 Rasp Eliminator (Resonator)
#11 |
Super Moderator
Drives: late 2009 CLK 350 Coupe Elegance, '65 Jaguar S Type wires
It's emulsified coolant/oil. Likely a head gasket - Unusual on the M272.
Your mechanic is full of crap. You do not know if you have to replace the engine when you don't know what is wrong. It needs proper diagnosis! Take some engine oil & put it on a hot stove plate or in a teaspoon & heat it with a cigarette lighter. If it crackles it has water/coolant in it. If there is no water/coolant in the engine sump & the car runs normally get a test kit to test for combustion by-products in the coolant. If you don't find any you know its not a head gasket. Then you have to contemplate if some idiot has put the wrong stuff in the coolant surge tank in which case a very thorough cooling system flush & coolant replacement is required.
__________________
![]() Llandudno, Cape Town, South Africa Last edited by Glyn M Ruck; 05-11-2012 at 09:35 AM. |
#12 |
Drives: 02 C230 6MT ; 07 C280 4Matic
+1000 to what glyn said..........maybe some idiot put brake fluid in your coolant tank...or some thing like that..........
__________________
#13 |
Drives: 2002 C230
I think you're looking at the glass being half empty. I'd get some bread and jam and enjoy the fruits of my engine's labors.
It does make Sunny's question very important. Crunchy is where it's at.
__________________
2002 Ccoupe, smurfalicious: OE chipped, RennTech pullied & rear spoiler, Carlsson lip, 18" OZ ultraleggera rims, RogueEngineering stud conversion, Eibach Pro springs/Koni Sport struts, Eibach swaybars, Supersprint headers, Eisenmann race exhaust, Magnaflow cat, Classic Soft Trim interior w/driver's Recaro Sport seat, clear OEM projector headlights, Sparco Racing shiftknob, Lightning Autosports alcantara shiftboot w/ Simoni gated shift surround |
| Tags |
| 16, benz, butter, cat, class, color, coolant, cover, engine, interior, lbs, leak, oil, peanut, put, tank |
| Currently Active Users Viewing This Thread: 1 (0 members and 1 guests) | |
| Display Modes | Rate This Thread |
