Star DAS menu paths for mods (pre-facelift W203)
Earlier it was mentioned to follow these steps
1/ enable tyre warning in the EIS
2/ menu now appears in the ESP.
3/ enable the warning in ESP
4/ now you must remove key from ignition totally
5/ put key back in
6/ reset cluster in actuations or code something again.
7/ drive 60 miles or 100km
8/ enable warning in cluster menu behind odometer
However, I don't know how to do step one. I have the instructions for step two and above, but not step one. Can anyone help me out please?
5/ put key back in
This is a simple one when you know the trick.
5/ put key back in
Yeah this one is undocumented and only works 2002 and later.
5/ put key back in
#33
Super Moderator
Well then That idea is out i thought you had a early w203 as they can't have the setting turned on.
Ok
try this
Control Units
Chassis
ESP
Control Unit Adaptations
Tire pressure loss warner
Ok
try this
Control Units
Chassis
ESP
#37
In an earlier post someone said they experienced the same issue, and then someone mentioned that turning it on in the EIS was the first step so that it can appear in the ESP menu. Their are so many menus in the EIS that I don't know where to begin. I am looking for the procedure to turn it on in the EIS so that then I can activate it in the ESP.
#38
Super Moderator
I had the same issue so I know that just trying to remember where the setting is go try the Instrument Cluster that seems to stick out in my mind. If not just go through the Control Unit Adaptations lists on both the EIS and ESP and also in the Instrument Cluster and you will find it unless for some reason your pars are an older model such as with my 01
#39
#42
3) enable directional fogs when turning
I'm wondering if someone with experience with the Mercedes Star Diagnostic computer can shed some light on this. There are other threads floating around online but these menus seem to change depending on the year and definitely the platform.
In particular I am looking for these paths for a pre-facelift (2001-2004) W203 C-class.
1) remove speed limiter
2) show litres remaining in fuel tank
Any other mods people can recommend?
I've been unable to reach Sunman or Karo, who seem to be the most knowledgeable members here based on my attempts to search. Thanks in advance.
ADD ALSO THE PADDLES THE TPMS AND THE NEW INSTRUMENT CLUSTER OF CLC 2008 LOOK
#44
Ok, so if someone is still struggling with tire pressure warner.
I have a 2005, and I didn't see Tire pressure warner in the ESP menu.
This is what I did:
Body -> EZS -> Control unit adaptations ->
Read coding and change if necessary ->
All codes ->
Scroll down to 2nd screen and enable 'Tire pressure loss warner'
Then carry out the coding
I then removed and inserted the key.
After this the TPLW menu item appeared under ESP
Now, I haven't driven 60 miles yet, but I intend to test it somehow after that...
This is what I did:
All codes ->
#45
QUOTE=VVF;6265517]Ok, so if someone is still struggling with tire pressure warner.
This is what I did:
All codes ->
Now, I haven't driven 60 miles yet, but I intend to test it somehow after that...[/QUOTE]
can this be enabled on any 2005 c230 or it has to have certain factory features to enable this option?
This is what I did:
All codes ->
#46
Any idea where we can enable the convenience feature on a facelifted 203? I want to activate the radio to scan through memory as opposed to scanning through frequency as it is right now. I know the 2006 and 2007 have this feature enabled. Anyone know how to enable it?
#47
The best option if you wanted to do this would be to get in touch with Mackhack and see what he can do through his contacts at MB. The AGW software can't be updated via DAS normally (I tried) so perhaps Mackhack can get some CD or another way to update it like the NAVs.
#48
Thanks!
#49
I forgot how I did mine, but these posts for w204 might point you in the right direction: https://mbworld.org/forums/c-class-w...n-feature.html
#50
Its in the Front SAM. If you can't find it I can fire up my DAS and step through it again.
