Sign in using an external account
| C-Class (W203) 2001-2007, C160, C180, C200, C220, C230, C240, C270, C280, C300, C320, C230K, C350, Coupe
Sponsored by : My Mercedes Parts ![]() |
LinkBack | Thread Tools | Search this Thread | Rate Thread | Display Modes |
#1 | ||
Drives: 2002 C230 Coupe Kompressor 6mt
A/C Problem or Not?
#2 |
My AC is all messed up too. Mine just doesn't blow cold though. Trying to figure it out too, good luck
__________________
![]() Peydidys CLK500 Coupe Thread: http://mbworld.org/forums/clk-class-...ml#post5407677 Peydidys Pewter C230 Sedan Thread: http://mbworld.org/forums/c-class-w2...ml#post5099624 Peydidys C230 Coupe Thread: http://mbworld.org/forums/c-class-w2...230-coupe.html PARTS FOR SALE: http://mbworld.org/forums/parting-ou...arts-sale.html |
#3 |
Drives: 2011 C300
Is it as simple as needing a recharge? I don't know the German car joke.. All my Hondas had sucky A/C systems but my W203's is frigid and works fine.
Now the BMW is another story. |
#4 | |
Quote:
my jettas ac has never been ice cold since it was new. Posted from Mbworld.org App for Android |
#5 | |
Drives: 2005 C230K, 2006 C230
Quote:
The dealers kept getting complaints but the A/Cs checked out fine. They kicked it up to the next level and they couldn't find any problems either. Finally they got so many complaints they went to the factory and when they'd heard enough, they sent to engineers to find out what was going on. They picked them up in Dallas in the August - in a 5 series with broken/disabled rear electric windows. When the engineers asked the driver to turn up the A/C - and it was going full blast - they realized they really did have a problem! I would hope they are better now!
__________________
Mercedes Benz World Owner's Gun Club, Member #91 2005 C230K (Diamond Black Metallic) 2006 C230 (Iridium Silver) 1974 Lotus Europa (White) |
#6 |
Drives: 2011 C300
It is adequate, barely, in the black/black 1-series. The Mercedes is better. The Lexus might be the worst one, though.
#7 |
Super Moderator
Drives: late 2009 CLK 350 Coupe Elegance, '65 Jaguar S Type wires
The Benz should achieve 6 to 8 degrees celcius at the vents idling. Any colder than that & it will freeze the evapourator & you will loose airflow.
__________________
![]() Llandudno, Cape Town, South Africa |
#8 |
So, tonight on my way home from work, it was 90 degrees and the ride home was not comfortable at all. Turns out I was misreading my home/auto pressure gauge. It turns out it was a bit low. I put a 12oz in and it was running at 40 degrees at 90 ambient temp with high humidity. Hopefully the leak is very small and it will last the summer.
| Tags |
| 2002, ac, air, c230, codes, conditioner, good, jetta, kompressor, mb, problem, problems, town, w203, work |
| Currently Active Users Viewing This Thread: 1 (0 members and 1 guests) | |
| Display Modes | Rate This Thread |
