Sign in using an external account
| C-Class (W203) 2001-2007, C160, C180, C200, C220, C230, C240, C270, C280, C300, C320, C230K, C350, Coupe
Sponsored by : My Mercedes Parts ![]() |
LinkBack | Thread Tools | Search this Thread | Rate Thread | Display Modes |
#1 | ||
Drives: c240
will Audi rims fit w203?
#2 |
Drives: Mercedes CLS500,C220
no sadly Audi not fit. on Mercedes you can put only Honda.
As Mercedes 112.4 and Honda 114.3 so these are main things that you need to look. Also mail hole where rim go on disk. I drove Honda rims was good But not Audo as Audi is holes 100 and BMW 120 and etc. |
#3 |
Drives: c240
sorry Tom, i don't quite understand you. you said honda as 114.3, then how come MB with 112 will fit? also what do you mean by "Also mail hole where rim go on disk"? thank you~
#4 |
you know 112 and 114 not big difference. So main thing if they fit is center big hole of the rim . Please find out and see if sellers and yous the same. But overall Audi not fit definitely as distance from holes for bolts 100 and your 112.4 ! even i wanted to pur rims that from Volvo that are 108 to 112.4 they not fitted to much troubles. Just forget these or try to find something 112 or worst 114 then you be safe otherwise you list them on ebay
for sale section
#5 |
Drives: c240
hi Tom, I have done some research, and found out the following:
http://www.wheelfitment.net/audi http://www.andysautosport.com/custom...all&sort=brand From both this two website, they all say Audi A5 has a PCD of 5x112 which is not as what you said. So i guss it should fit? Anyone else have any ideas? thank you~~~~ |
#6 |
Super Moderator
Drives: MPG+ ROLFCOPTER
There are several posts in regards to this. Not only do you have to be careful about the bolt pattern but also the center bore and offset. Happy searching.
__________________
#7 |
if 112 or 114 they should fit as i have my own experience in these so i know what i say, and what is the main buying not Mercedes Rims.
#8 | |
Drives: c240
Quote:
so Tom, you got any ideas regarding the hub or centre bolt thingy? cheers~~~
#9 |
Drives: c240
According to phister's post as below:
Will these 285/35/18 wheels/tyres from SL from my c240? w203 c240 has a centre hub of 66.6, which is the same as Audi's (see eBay link below)? http://www.ebay.com.au/itm/15mm-HubC...item3a77899bf9 http://www.ebay.com.au/itm/AGT-15mm-...item27c862d906 Can anyone please tell me am I right? thanks so much~~~ |
#10 |
i try to ask my friend he sell rims and i try to search for image of rims on my last Mercedes from 114
#11 |
btw what size of tyres you putting and how wide rims?
#12 |
Drives: c240
hi Tom, thanks for your kindly help, the following is the rim spcs:
Make: Audi Model: A5 Year: 10 Manufacture: Ronal Made in: Czech Republic Part Number: 8TO601025 Size: 18X8.5j Stud Pattern(PCD): 5X112 Offset: ET29 I am looking for to putting on some 225/40/18 tyres on all four rims or 245/40/18 on the back?. Cheers |
#13 |
Drives: c240
According to this two links, it says the centre bore for A5 is 66.6 which is the same as c240?
http://www.audizine.com/forum/showth...4610-S5-wheels http://www.ebay.com/itm/2-3mm-Merced...3a102a&vxp=mtr Trying to solve this puzzle so other people don't have to ask again
#14 |
just returned My friend said Yes rims gonna fit only look To Eta - so you see if rims with tyres not go outside of fender lines.
#15 |
Let me clear this up a little bit. The above posts are providing a bit of misleading information. First off MBs use 5x112 bolt pattern while MOST audis also do use 5x112 also. I am currently using wheels that were originally made for an audi on my sedan right now. All I needed were hub rings to change the wheel hub size from 71.3 too 66.5 which is what MBs are. Now some other audis use a lower hub size, I think its like 57.1 or something similar to that, with those you would need to have a shop shave out the hub to 66.5, which can be done, I have friends who have done it. Now the whole argument of the only kind of wheel that will fit a mercedes earlier is extremely miss leading and incorrect. You can not directly take 5x114 wheels and put it on a car requiring 5x112; you would need wobble bolts and a lot more, people do not do it very often because of safety issues and just complications that come with it. Also 5x114 is used on many different kinds of cars not just honda.
__________________
![]() Peydidys CLK500 Coupe Thread: http://mbworld.org/forums/clk-class-...ml#post5407677 Peydidys Pewter C230 Sedan Thread: http://mbworld.org/forums/c-class-w2...ml#post5099624 Peydidys C230 Coupe Thread: http://mbworld.org/forums/c-class-w2...230-coupe.html PARTS FOR SALE: http://mbworld.org/forums/parting-ou...arts-sale.html |
#16 |
Drives: c240
Hi pedidys, thx for ur reply. I just asked the seller re the hub size, just waiting for him to reply. The same seller is also selling the same set of rims which is made in Germany and has a ET of 24. Will ET24 be Ok for my car ir is it too much?
Also r rims made in Germany better quality than rims made in Czech Repblic? thx~~~~~ |
#17 |
Drives: 06 C230 SS 6spd
OEM MB wheels are German made so are BBS and OZ racing wheels, which are top notch and are used in many racing programs.
#18 |
Drives: c240
hi phister, thanks for your advice, i went through one of your previous post, and learned that you have ET20 at the front (ET30 with 10mm spacer) and ET25 at the back (ET30 with 5mm spacer). Can you please advice is ET24 for both front and back would be push it to hard? I intend to put some 225/40/18 on the front and 245/40/18 at the back or 224/40/18 for all four depends on the clearance to the fender. thanks in advance~~~
#19 |
What is the width of the wheels with the +24? Depending on the width, it can or cannot fit. If the wheels are all the same size I would get the same tire size all around that way you can rotate them to all corners.
#20 |
Drives: c240
hi phister, the width is 8.5j, will that be ok? thx~~~
#21 |
With 8.5 you should be ok with +24 in the rear. As for tires if you want a slight stretch get the 225/40, if you want more tire and comfort get 235/40
#22 |
i agreed totally to last post!
| Tags |
| 08, 11, 112, 203, 571, audi, b5, bore, c350, cclass, et20, fit, forums, hub, mercedes, rims, w203, wheels |
| Currently Active Users Viewing This Thread: 1 (0 members and 1 guests) | |
| Display Modes | Rate This Thread |
