Rattle when going over bumps/holes
Old 12-07-2012, 03:43 PM
rhys250's Avatar
2001 Mercedes c220 CDI
Lightbulb Rattle when going over bumps/holes
Folks,
Looking for some advice from you's guys am sure i seen somewhere on here someone had same issue but can't find it again.
Basically when i go over small bump/holes on road there's serious annoying rattle from front of car. I know this shouldn't happen in a Mercedes. I changed the lower suspension arms not that long ago and the upper where sound.. Still getting the same noise
Anyone have any other advice that they could give me to check out?
My car: 2001 Mercedes c220 CDI Automatic W203 model.
Many thanks in advance guys!
Old 12-07-2012, 05:44 PM
TheXenochrist's Avatar
c240
Inner/outer tire rods
Old 12-09-2012, 08:49 AM
TelmoChaparro's Avatar
C 220
I have the same problem with Eibach Springs ( W203 T-Modell )
Old 12-09-2012, 10:28 AM
phister's Avatar
06 C230 SS 6spd
check your endlinks and control arm bushing and also the sway bar bushing. I'd buy some silicone lubricant spray and spray the moving suspension parts liberally and see if the problem goes away. since your car is an 01 the bushing are probably gone since they're made of rubber. if you havent done that then its probably the culprit.
Old 01-06-2013, 08:59 AM
rhys250's Avatar
cheers for the replies folks!
I had to put a new spring on front left then i replaced the to stablizer/drop links i think it was on each side.. But its still making the noise :S
Really doing my head in now! Will get the end links etc as you guys have said! Thanks again! Will keep you posted on how i get on
Old 03-06-2013, 09:59 AM
rhys250's Avatar
Hi folks, just bumping this again to see if anyone has any other ideas/advice.
So basically the car has got the all clear from mechanic.. he cant find why it is make these noises when going over gaps in the road.
Ive been thinking... is there anything about the suspension mount that would be making the banging noise?
He checked all the bushings and arms and we have replaced a few already and everything is all good. Just STILL getting noise when going over the smallest of cracks in the road. i DONT get them when going over the likes of speed ramps or anything just small cracks.
All help will be appreciated! Thanks
Old 03-06-2013, 11:22 AM
phister's Avatar
06 C230 SS 6spd
You can check to make sure the hat is mounted all the way down. Sometimes when doing the struts you have to make sure the locking ring that holds down the hat is fully locked down. If not it will not let the brace that sits on top of the strut go down all the way and will cause a knocking sound going over bumps and dips.
Old 03-06-2013, 03:38 PM
hanknum's Avatar
'02 C320 Wagon, '78 308 GTS, '06 Highlander Hybrid
Have you checked the sway bar bushings (the ones that mount the sway bar to the frame)? Mine were worn to the point the bar rattled inside of them. It would clunk over uneven pavement or when going over a speed bump at an angle (would not do it going straight over).
Old 03-06-2013, 06:21 PM
phister's Avatar
06 C230 SS 6spd
That's why I bought polyurethane bushings for the sway.
Old 03-06-2013, 07:36 PM
fleishman's Avatar
2002 C32 AMG
Yes probably sway bar links or bushings. Check the strut mount bearings also.
Old 03-11-2013, 09:49 AM
rhys250's Avatar
excellent guys thanks a lot! will get these looked at further!
Old 03-11-2013, 09:57 AM
rhys250's Avatar
Actually the more i think about it, i think i replaced the Sway bars recently enough too...
Old 09-21-2014, 02:39 AM
mercfreaks's Avatar
C180 W203
I know this is an old thread and maybe the problem has already been solved, but I too was looking for a remedy for a rattling front brake caliper when going over bumps and found that if I smeared some brake grease/paste on the back of my brake pads the rattle stopped. Maybe this will help someone else who is trying to solve brake rattles. Haynes manual 4780 recommends this when fitting new pads.
Old 11-20-2015, 05:44 PM
mercfreaks's Avatar
C180 W203
Well the above "fix" was only temporary and the rattle returned, but I finally did fix the rattle by cleaning and lubricating (high temp grease) the slide pins of the floating front calipers
Quick Reply: Rattle when going over bumps/holes
