W203/CL203 STANCE/SUSPENSION/FITMENT THREAD
#127
W203 c230k
Hi All!
I just joined...from South Africa.
I need some advice please. I have a c230 coupe. Currently have FK coilovers in with 17 inch 8j et35 wheels. Tyres are 225 45 17.
The car is Lower than stock but I want to turn it all the way down in front but cannot due to clearance of coilover against wheel. Looked at a few options:
1. Hubcentric spaces to clear coilover more in front, however eibach and another manufacturing company told me that due to the thickness of the front hub if I put anything thicker than 5mm spaces I will be riding on the wheel bolts which is not ideal. I currently have 5mm spaces on.
2. Change the wheels to perhaps 18inch with lower offset. Et20-30? Not really keen on this idea as I like the current wheel.
3. Change tyre size from 225 45 17 to 205 40 17 or 205 45 17. I think the 205 45 17 would be ideal as I only have about another 10mm max to turn down in front, I'm worried that if I put the 40 profile on that I will still have the wheel gap in front.
Any advice please? Thanks and Regards - Bhavesh Coilovers as it is now
Limited clearance
Limited clearance
#128
in my opinion, the car needs 18.
Not just for the look, but if you go to 205 45 or 215 40 17" and lower all the way down you will not be able to drive the car, because it will hit the ground every time.
Bhavesh (11-04-2016)
#129
Bhavesh (11-16-2016)
#133
C200K with stock rims (for now...) and Sport Eibach springs. Everything else is stock:
Coming (really) soon:
Borbet "A" 17x7 ET38 for the front/ 17x8.5 ET32 for the rear.
#136
So many different setups listed. I am buying coilovers (brand not sure yet but looking and h/r or BC strongly, or bilstein), also buying 18s and have picked these.. Cosmis Racing R1's 18x8.5+35mm and 18x9.5+35mm, shop also recommending 225/40/18 front and 255/35/18 rear.
https://www.cosmisusa.com/product/r1/
They did not mention any rolling of fenders, or need of camber kits, or spacers, bolt extensions, etc
Seems like all these setups have all of that..
Do I need any of this or will the wheel/tire setup work fine with the coilovers and look good enough?. Car is my tuned up DD that I am working on improving, it is not my weekend toy however.
gonna purchase all within a week so any help is appreciated. thx
#137
W204 C300 4Matic Sport Sedan
How did you mod your H&R Coilovers, I have H&R Street Performance coilovers. i want to go lower in the front and maybe the rear a little bit. thanks
#138
Love all the different looks on the W203's! I had a question, I currently have the option to pick up some 2012 S550 Amg Rims.
wheels are:
front: 19x8.5, et43
rear: 19x9.5, et43
anyone see a problem running these on stock suspension until I can afford a good set of coilovers. and tire size would help a ton.
I know the size and width will work but have no idea how to calculate the proper offset.
Thanks in advance.
wheels are:
front: 19x8.5, et43
rear: 19x9.5, et43
Thanks in advance.
#139
2001 W203 c220 & 1996 w202 c250
#140
#141
YEAR - 2005
MODEL - C230
SUSPENSION - CEIKA Performance Coilovers 1M Type
WHEELS - ///AMG C63 wheels 18x8.5 +32 (35mm spacer -3) 18x9.5 +35 (25mm spacer +10)
TIRES - Nankang NSII 205/40/18 square set-up
LUG STUD CONVERSION - Longer studs to support oversized spacers
BRAKE SETUP - AMG sport package 4/2 set up
WHAT REAR PAD # - none
camber- approx. 1.3 degrees neg or so maybe more in rear can't find spec paper.
Fenders were stretched out as wide as they could go ( OEM Fenders n Quarters) and also rolled.
Attachment 377740
Attachment 377741
Attachment 377742
Attachment 377743
Attachment 377744
MODEL - C230
Attachment 377740
Attachment 377741
Attachment 377742
Attachment 377743
Attachment 377744
Also how much have you lowered it by ?
#144
06 c230 sport
hi guys. Just need some insight on wheel fitment. Curretly I’m running all stock 17’s. 7.5 front and 8.5 rear. Im trying to purchase this wheel: 18x9.5 rear and 18x8.5 front with
225/40r18 rear and 215/40r18 front. Both et 35. Will this wheels fit without any issues? Spacers? Thank you in advance.
#145
#146
2006 C230 Sport
2006 C230 wheels question
I'm currently looking through the thread, but haven't seen anything that really answers the question of the problem I'm running into. I'm looking to get a new set of wheels when I get back home, it'll be the first modification I'm doing to the car. She's otherwise stock. The wheels I really want, I've only been able to find in 18x8.5 ET42 and 18x9.5 ET45 and I'm wanting to run that setup staggered as such (235/40/18 and 255/35/18 respectively as front and rear). What modification would be necessary to make them fit? From what I've seen, max positive offset was +38mm for factory dimensions and I'd really hate to have to settle with a different set if I can help it.
