Urgent! m271 Cam adjuster question! Video inside!
Old 02-19-2014, 11:03 AM
Skelterize's Avatar
W124 E230 90 (M102) & W203 C180K 03 (M271)
Exclamation Urgent! m271 Cam adjuster question! Video inside!
Hi
I have a w203 C180 Kompressor that has a few issues.
So I've had a rattle during Idle and bought a Timing Chain kit from Febi to replace it and remove the rattle.
Now that I've started my quest for less(no) engine rattle I noticed that the camshafts alignment was off by almost 10 degree (crank at TDC mark). Rotated the crank another time then it made a klicking noise, now both cams where rather precise at the TDC mark. Kept Rotating the crank a few times and got a pattern.
10 degree off TDC
next almost spot on TDC
then 10 degree off
(note that every time the alignment changed the adjuster was klicking)
Is it broken or just messed up by the timing chain???
Camshaft adjuster noise (keep an eye on the camshaft)
Then the rattle during Idle (note that the rattle is going away when given a little gass)
Please help! would be a shame get rid of it.. How much would a camshaft adjuster cost and where to buy?
Old 06-12-2014, 12:56 PM
raveboy1820's Avatar
C200k W204
HI Skelterize.
i have the same issue as you with the rattling below 2000rpm and disappears when reved above. What did you do to resolve this? I have Chain and sprockets replaced etc etc. and have crankcase pipes done.
Pleeeeze.
Old 06-12-2014, 11:08 PM
Oldcardriver's Avatar
2000 C200 Kompressor
I just had a similar rattle on my M111 C200K, which also went away at high revs. The noise appeared to be coming from the timing chain/guides/tensioner/cams, but ended up being a very badly failed water pump bearing. The sound was resonating with the front and top cam/chain covers.
After taking the cam cover off and finding nothing wrong, a tube in the ear suggested the rattle coming from the water pump, then removing the belt confirmed the diagnosis. It was then a quick fix.
Graham.
Old 06-13-2014, 01:42 AM
C200k W204
thanx a lot. will definitely check that out.
Old 03-01-2015, 03:17 AM
Kevmister's Avatar
c180 kompressor 2006 w203 271
m271 exhaust cam adjuster making a noise.
Hello,
I have had exactly the same happen to me on my c180 kompressor 2006. I have stripped my motor several times and I could not find the problem. I finally decided to go the extra mile and remove the cam shaft and take the exhaust cam adjuster off to see if that was the problem.
And yes, it was.
2 of the 4 flanges inside the cam adjuster have broken off and it will have to be replaced.
When I can I will post a pic of it.
I hope this helps.
Attached Thumbnails Urgent! m271 Cam adjuster question! Video inside!-dsc_0122-360x640-.jpg
Old 03-01-2015, 07:38 PM
wvadam's Avatar
C230 COUPE 2003 M271
Originally Posted by Kevmister
Hello,
And yes, it was.
I hope this helps.
wow , I would like to see that
Old 03-02-2015, 03:14 AM
Kevmister's Avatar
Old 03-02-2015, 08:05 AM
C200k W204
M271 Cam Gear issues...
Hey Kevmister,
That is exactly how mine ended up as well!!
The darn E-cam gear lost its circlip that hold the spring that pushes the metal key that locks the gear into position. Caused the camshaft and gear to have a enormous play and the knocking actually cased it to break those 2 of the 4 arms.
The mystery is what actually caused it to lose that circlip in the first place?
Also before the engine fully died, it picked up this irritating "Whining sound" above 3000rpm...EVEN with me removing the serpentine belt it remained. Meaning that the sound is not water pump, alternator, supercharger or any other belt driven parts.
This is my biggest mystery and i have not repaired the vehicle as yet!
Any ideas? anyone?
Old 06-22-2018, 11:38 PM
DanBud's Avatar
W211 / 2004
Camshaft
[QUOTE=Skelterize;5947570]Hi
10 degree off TDC
then 10 degree off
Hy. I have the same problem like you... w211 camshaft adjuster... pls help me ... just say to me the way to fix this problem. Pls help!!! my name is Bud Dan from Romania on Facebook...or 0040767400510
Old 06-22-2018, 11:41 PM
DanBud's Avatar
W211 / 2004
Originally Posted by raveboy1820
Hey Kevmister,
Any ideas? anyone?
Old 06-23-2018, 01:13 PM
DanBud's Avatar
W211 / 2004
Camshaft problem
Hy. I have a big problem with... w211 camshaft adjuster... pls help me ... I changed 3 times ... and everytime the same problem... the bolt come aut...just say to me the way to fix this problem. Pls help!!! my name is Bud Dan from Romania on Facebook... 0040767400510
Quick Reply: Urgent! m271 Cam adjuster question! Video inside!
