Sign in using an external account
| C-Class (W203) 2001-2007, C160, C180, C200, C220, C230, C240, C270, C280, C300, C320, C230K, C350, Coupe
Sponsored by : My Mercedes Parts ![]() |
LinkBack | Thread Tools | Search this Thread | Rate Thread | Display Modes |
#1 | ||
Drives: 07' ML350
water dripping from muffler tips
__________________
BruNo 10 Bmw 740Li (F02) 11 Mini John Cooper Works 12 Range Rover Evoque Dynamic Si4 |
#2 |
dont worry, its fairly normal, unless were talking gallons, which im sure were not.
#3 |
normal, dont worry
#4 |
All my car do it, especially the Ford E250.
__________________
2011 BMW X5 2000 MB S500 |
#5 | |
Drives: 2002 C230 K
Re: water dripping from muffler tips
Quote:
#6 |
Drives: 07' ML350
i think ive got some little water mixed onto d gas ived pumped in a few months back. gonna drain the fuel tank this weekend.
well its pretty humid here....hot and humid.
__________________
#7 | |
Drives: 2010 C300 4matic
Quote:
__________________
2010 C300 4matic Steel Grey/Black 15% tint X-pipe |
#8 |
Water is a normal byproduct of combustion. When a hydrocarbon such as gasoline is burned with air, the main byproducts are water vapor and carbon dioxide. Carbon dioxide remains a gas, but the water vapor cools and condenses as it exits the tailpipe, especially on a cold morning when the air is cool.
When the engine is shut off, much of the water vapor thats moving through the exhaust system condenses within the pipes and muffler. The further aft from the engine the muffler is located, the greater the amount of condensation. This water lays in the muffler until the next time the engine is started. Sometimes water will be blown out the tailpipe by the force of the exhaust. Other times, it may remain trapped in the low spots of the exhaust system until the system gets hot enough to boil it away. All this water is what causes your muffler and pipes to eventually rust through from the inside out. There's no way to get rid of it, so many new vehicles have exhaust systems made of stainless steel. Aluminized pipes and galvanized mufflers are increase the corrosion resistance of the exhaust system. Even so, most original equipment exhaust systems wont last more than five or six years, and most aftermarket replacement systems only two to three years. In addition, I have found that lower octane fuels tend to produce more water (condensation) out of that tailpipe. I always run 93 in my 85 toy 22re. A friend always ran 87 (same truck). His car always had more water dripping.
__________________
"As you make a living, don't forget to live" '03 c230K Sedan |
| Tags |
| black, car, condensation, dripping, engine, exhaust, form, gas, it, low, muffler, normal, pipe, start, stuttering, tips, water |
| Currently Active Users Viewing This Thread: 1 (0 members and 1 guests) | |
| Display Modes | Rate This Thread |
