reverse LED bulbs
c220 cdi
reverse LED bulbs
hi,
i'm looking for that white-blue effect for the reverse lights. what is the description of the bulbs i need? do they go by any specific name?
if anyone has a link to the bulb i'll be happy to get it.
thanks.
thanks.
W203 C200K (2001)
I think it's a normal p21w bulb, here's some p21w LEDs from ebay:
p21w led | eBay
Pick the best for you, but i suggest one with more LEDs on the sides, not just the top.
They might produce an Error when you install them if they're not loaded, you'll need those if it does so (If you're cheap just wire the old bulbs in parallel and leave them inside the housing)
http://www.ebay.com/itm/2x-50W-6-Ohm-Load-Resistor-LED-Bulb-Turn-Signal-Light-Flash-Fix-3157-7440-1156-/171303800783?pt=Motors_Car_Truck_Parts_Accessories&hash=item27e2808fcf&vxp=mtrif you have the sedan i recommend getting the LED licence plate lights too, totally worth the money, the car immediately looked amazing with those on !
http://www.ebay.com/itm/2x-01-07-Mercedes-Benz-C-Class-W203-Sedan-License-Plate-12v-White-LED-Light-Lamp-/300999151130?pt=Motors_Car_Truck_Parts_Accessories&hash=item4614f28e1a&vxp=mtr
p21w led | eBay
this is the place to go for great error free LED's. He has a benz, so he makes sure they work and they're high quality.
http://aznoptics.com/
2007 C230 SS 6MT
http://www.superbrightleds.com/morei...ed-tower/1326/
This is what I use - BRIGHT as hell & no errors.
