Change out transmission fluid after 80K miles?
I can't find the thread, but I remember reading that although mercedes says it's good for life, go ahead and change it out BUT after 80K miles, just leave it b/c when you change the transmission fluid after this mileage something, something, bad. Can't remember. Thoughts about doing a transmission fluid change at 95K miles?
06 C230 SS 6spd
I did all my transmission and differential oil at 100k and was fine. Just be sure to use the correct fluid for the transmission fluid and differential oil. If you're going to do it yourself first be sure you can loosen the fill plug before draining. There's been a few that had a hard time removing the fill plug after they already drained the fluid.
I have read that doing it many miles and years down the line can cause more harm than good because it may loosen up stuff that might have been stuck in there. I'm personally about to do it myself and my cars at 104K miles.
From reading other threads, I think the best course is NOT to do a full flush but instead a 'drain and fill' since it won't be a total shock to the system, only 6 quarts replaced as opposed to 9 or 10 I think.
Super Moderator
I would do a back to back drain and fill if your worried about a flush. Just do a drain and fill run car a few thousand miles then do it again. I did a full flush on my car around 180k but my fluid had been changed two two or three times before then.
I didn't mean a full fluid change, I meant the half (or so) of the fluid the dealership does when servicing the trans!
2003 CL203 C320, 2002 W208 CLK320 cabriolet, 2012 A207 E350 cabriolet, 2011 X204 GLK350 4matic
I haven't heard about any disobedient transmissions after doing a drain and fill after 80k miles. My car is at 78k miles (125k km's), and I changed the fluid and filter at 75k miles. Since then I also sucked out 5L from the system and filled 5L. No problems. Shifts better than ever now.
If you have the suction pump which many members here use for oil changes, you could also use that to suck out some transmission fluid some time after a drain and fill from the pan. Very safe to do so. Just check the level using the MB dip stick, otherwise your tranny will slip for days.
Yomann (07-03-2020)
Super Moderator
Changing the fluid & filter will always be the best thing you can possibly do.
If you work cleanly, failures after a change or flush is an urban myth that has gained legs. If a transmission fails after a fluid change it would have failed anyway.
Change fluid & filter every 39K miles or 60K Km's.
2005 C240
I did a fluid flush and filter change on my C240 with 134000 miles. the transmission acts smoother and more crisp with the shifting.
I am with Glyn on this when he says changing your fluid and filter is 100% good and should be done no matter the age. Here in the US we do have a contingent of people who would not change the fluid on a car with high miles. There are stories of transmissions slipping and not shifting right, but those are never first hand accounts.
Bottom line is I have changed tranny fluid in several cars (10) with high miles (over 100K) and no history with zero issues. In fact almost every time the shifting becomes better.
So you changed your transmission fluid well below the mileage we're talking about and it worked? wow, man. That's really helpful to know. Can you fill us in on any other services you did before the scheduled maintenance period and if it runs fine?
and yes the there is a filter and while you there make sure to change the tcu seals which are known to leak on our cars
Super Moderator
Note that the electrohydraulic bush seals/O rings only apply to the 722.6 5 speed transmission. TCU is built into the 722.9 7 speed.
sorry for the confusion i was referring to the pilot bushing, this link:
http://www.ecstuning.com/Mercedes_Be...ing/ES1728687/
