transmission drain/fill, rear differential flush, fuel filter replacement STRATEGY?
Old 08-26-2014, 02:21 PM
scottonfire's Avatar
2013 c250
So I'm planning to do these three, and since all three require the cars up I may tackle these together, BUT I'm not sure in which order. Any tips/suggestions for doing these all together? Seems the transmission drain/fill (dropping the pan) has a chance of danger b/c the fluid level must be pretty much on point, so should this be done separately from the rear diff and fluid filter?
Old 08-26-2014, 05:07 PM
VVF
VVF's Avatar
2005 C230K(sold), Mk7 Jetta
The diff should drain fast.
I'm thinking:
- Undo the filler bolt in the diff, then undo the drain bolt, let drain.
- While the diff is draining, undo the tranny pan drain bolt, let drain - takes some time.
- While tranny is draining, refill the diff.
- Probably the tranny is still draining, so mess with the fuel filter.
- Finish up with the transmission...
Old 08-27-2014, 11:50 AM
2013 c250
Thx VVF,
You're like the only one who seems to participate! Everyone else is hoarding their knowledge. I guess what I'm looking for is that this is okay to do all together. My concern is if some error codes are thrown I won't know which went wrong. Saving time's good too though! Also, b/c changing the transmission fluid will change the viscosity and possibly loosen debris, I'm wondering if adding new rear differential has any effect on that. Yeah, that's it. I'm wondering about how one will effect the other, if any. Will a new fuel filter in any way affect the transmission vs. the rear differential, etc.
Old 08-27-2014, 12:05 PM
Quadcammer's Avatar
96 and 08 911 turbos
fuel filter has no impact.
rear fluid and tranny fluid will also not impact each other.
Realistically, with the exception of transmission fluid, the jobs you're talking about are very straight forward.
Hopefully you have the correct tools to properly refill the transmission.
Old 08-27-2014, 02:22 PM
VVF
VVF's Avatar
Also the diff is purely mechanical AFAIK, so it cannot affect any codes.
The fuel filter - if aftermarket - might be garbage and cause the car to not start. Use genuine filter there.
Old 08-28-2014, 12:40 AM
Super Moderator
samaritrey's Avatar
THE C350
+1 For OEM fuel filter
Nothing you listed should affect each other. Just make a parts/supplies list and double and triple check it and try to buy OEM/OES parts and approved fluids.
Old 08-28-2014, 01:46 AM
2013 c250
I think I'm gonna start from easiest to hardest, so fuel filter first cuz it seems the most straight forward, then the rear differential, then the transm. drain and refill. I'm not trying to save time as much as I want to just do everything right.
Old 08-28-2014, 01:00 PM
C230 Sport Coup's Avatar
C230 Sport Coup + 2006 W164 ML350 + 99 Ford Escort (What the heck, it gets 38 mpg!)
OEM filter is Knecht and can be purchased I think from like Rock Auto. Dealer will charge you 150 for a $40 filter.
I've used Bosch...I mean they invented fuel injection....
Mann is OK too though they've started making a lot of stuff in China and their
oil filter suck now. So maybe not.
Genuine Mercedes trans filter and seal, Shell ATF134 fluid.
Old 08-28-2014, 02:53 PM
VVF
VVF's Avatar
Which fluid for the diff? Mobil1 75W90 or OEM?
Old 08-28-2014, 05:55 PM
neurodave's Avatar
2001 C320 w/ Sprt Pkg
I'm using 75W90 Mobil1 with no issues (knock on wood) but OEM is 80W if I remember correctly. Someone correct me if I'm wrong.
Old 08-28-2014, 10:30 PM
2013 c250
https://mbworld.org/forums/c-class-w...ind-where.html
http://www.autohausaz.com/search/pro...ber=0005830904
Old 08-29-2014, 12:11 AM
VVF
VVF's Avatar
Yep, not worth saving 30-40 bucks over a 100k mile drain interval.
Old 08-29-2014, 06:13 PM
Former Vendor of MBWorld
AutohausAZ-Mike's Avatar
Thank you for mentioning us Scottonfire!
Looks like everybody else already did a good job answering your questions.
If you guys ever have any questions regarding certain parts, please feel free to send me a pm or give us a call.
Quick Reply: transmission drain/fill, rear differential flush, fuel filter replacement STRATEGY?
