W203 BAS and ESP fault
Mercedes E klasse & C klasse
Hi everyone
I would like to ask for help
I have w203 with illuminate 2 fault code on instrument panel
BAS and ESP fault
I scanned it with STAR and here are the codes
C1050 ( component N65/3 brake booster vacuum pump faulty or lead open circuit)
C1185 ( A7/7b1 BAS diaphragm travel sensor electrical fault )
So far, i changed BAS diaphragm travel sensor, and then check all fuse were OK. but both fault code still remain.
I tested it with STAR diagnostic to see the status relevant value of BAS diaphragm sensor it come out 0.000 value (but brake work normal)
Anyone can help me, please ?
Thank you
BAS and ESP fault
Thank you
LOOK AT THE FOLLOWING THREAD
https://mbworld.org/forums/c-class-w...-assist-visit-
workshop-bas-2.html.
I fixed the BAS warning by clean the brake switch attached to the brake pedal
2003 C32, 2002 S55, 1999 SL500, 2004 S430
