MJ50's W203 Mod Fever (OEM Retrofits)
Rating: Thread Rating: 5 votes, 5.00 average.
Old 01-08-2004, 04:06 PM
JimB's Avatar
2000 ML320/'03 C320WZ
i installed this
I did this instead of dual tip from schaetz
¼ view
side view
Old 01-08-2004, 04:11 PM
Speedo's Avatar
2003 C320 Sport Sedan
JimB,
I like that as well. Who makes it? Bolt-on or weld? Any other modifications you had to do to make it fit?
Thanks,
mike
Old 01-08-2004, 04:15 PM
oggle's Avatar
E320
Re: i sinstalled this
A bit crooked from the side. Can you lower the muffler?
Old 01-09-2004, 12:34 PM
JimB's Avatar
Mike
That piece is the OEM tip from '04 sport sedan, You had to cut the OEM twin pipe about an inch to make it fit then have the exhaust shop spot weld it to your satisfation If you don't cut the tip of OEM pipe the exhaust will be restricted.
Oggle, you are correct its a bit pointing down on the side, but that is the max I can do, not to touch the bumper to avoid melting the plastic bumper. I'm happy the way it looks on the back
Old 01-09-2004, 04:21 PM
Super Moderator
MJ50's Avatar
bone stock E55 AMG
Here's the finished pic
Old 01-09-2004, 05:04 PM
JimB's Avatar
Cool Man
Are they OEM. How much?
TY
Jim
Old 01-09-2004, 05:50 PM
  #32
C230 Sport Coup's Avatar
C230 Sport Coup + 2006 W164 ML350 + 99 Ford Escort (What the heck, it gets 38 mpg!)
Oooooo!!! Nice.
So how much did that set you back, door sills and all?
I really like it!
Old 01-09-2004, 06:06 PM
  #33
Super Moderator
MJ50's Avatar
bone stock E55 AMG
pedals are 50 + s/h on ebay
door sill are 150 + install from formymercedes.com.
Old 01-09-2004, 11:36 PM
  #34
Sincity's Avatar
I wish they make a "Dead Pedal" to match the 04.5 pedals. Looks great!
Old 01-10-2004, 12:16 AM
  #35
oggle's Avatar
E320
Do you have to drill a hole into the pre-existing pedals?
Also, are there any functional differences or is it just purely cosmetic?
Old 01-10-2004, 12:20 AM
  #36
Super Moderator
MJ50's Avatar
bone stock E55 AMG
oggle,
yes, u have to drill a hole.
i can't really tell if there are any improvement besides the look... but the dead pedal certainly feels better.
Old 01-11-2004, 03:32 AM
  #37
Blake P's Avatar
'09 A4 S Line
Thanks for recommending that tip Jim. I ended up doing the same.
back
side
Old 01-11-2004, 08:06 PM
  #38
schell's Avatar
C- 230 Kompressor,C2,C7,Black,JL sub,A/D/S/ amps,Alpine hu and changer
I love those, do you know if you can get for a manual shift car, or is it auto only.
Old 01-11-2004, 10:06 PM
  #39
JimB's Avatar
blake
look nice man...yours is look straight than mine but its way closer to the bumper. Isn't it?
Old 01-12-2004, 12:10 AM
  #40
s4iscool's Avatar
looks nice!
they are not real AMG, some chinese knockoffs, but they look damn good I opted for the OEM round rubber pedals and ebrake cover. I hope they produce a deadpedal soon, or i might have to clash and get the generic one.
oem ones slip over perfectly like the oem non al pedals.
Old 01-12-2004, 01:05 AM
  #41
Blake P's Avatar
'09 A4 S Line
Re: blake
Yeah...it even touches the bumper. Hope it doesn't cause problems
Old 01-12-2004, 01:15 AM
  #42
s4iscool's Avatar
When you get those egt's up you will melt your bumper cover and get plastic all over the tips Also remember the tips will expand when heated up so they will move even closer to the bumper cover.
mj50, tips look good, but why in the world do you have an AMG badge on the car?
Old 01-12-2004, 01:30 AM
  #43
jo17jC230's Avatar
2008 C300 Sport
Re: Re: blake
it will cause problems... gonna burn the paint and melt the bumper...
Old 01-12-2004, 02:06 AM
  #44
Blake P's Avatar
'09 A4 S Line
Since it's already welded on, do you guys have any recommendations about what I can do now? I was thinking about maybe sanding a nice small area of the bumper around the tip and adding a bit of touch up paint, since it's not really an "area of focus" on the car so close to the ground and all.
Old 01-12-2004, 02:38 AM
  #45
Pardon me for asking but where exactly do you have to drill any holes?
Also, I'm curious on people's opinions.
C7 stock sport pedals, or these?
I like the deadpedal for sure.
Old 01-12-2004, 03:49 AM
  #46
oggle's Avatar
E320
How much are the stock AMG pedals vs these?
Old 01-12-2004, 05:37 AM
  #47
tommy's Avatar
2004 Civic Si. FWD for the Win!
Looks like the ebrake cover is a slip on (and quite slippery, too - don't like that it doesn't have any rubber on it). As for the others, you can see where the bolts are - you make corresponding holes on the pedals.
Though the price is much more, I'd get the Brabus pedals still - these look fairly cheesy, imho.
Old 01-12-2004, 10:17 AM
  #48
s4iscool's Avatar
Take it to any good exhaust shop, and they can heat the hanger so they can bend it down for you. takes 1 minute to do it.
Old 01-12-2004, 10:44 AM
  #49
JimB's Avatar
It can not be bend down because it is welded to the pipe and muffler,
Blake what you can do is unweld it and reposition the tip, or make the bumper cut out bigger
Old 01-12-2004, 12:42 PM
  #50
Blake P's Avatar
'09 A4 S Line
I'll probably just make the bumper cut out a little bigger.
You have already rated this thread Rating: Thread Rating: 5 votes, 5.00 average.
Quick Reply: MJ50's W203 Mod Fever (OEM Retrofits)
