check engine light after hard acceleration
2006 Mercedes C280
It starts to misfire a little and i get P0012, something to do with the timing.
The light goes off after a few driving cycles(that only include easy acceleration).
Camshaft position sensor. I recall reading something about the front sensors or magnets going bad and leaking oil or something of the sort. I'm sure someone else will chime in with more details, but at least now you know what the code relates to! Good luck
https://mbworld.org/forums/c-class-w...ank-1-a-7.html
That's the thread in case you want to read up on it.
2002 c230 kompressor coupe, 2005 c230 kompressor
Same thing happen to me check those sensors and wipe the oil off if there is any, it made my engine light turn off, I'm going to dealer tomorrow to see if they'll fix it cause that was supposed to be a recall
2006 Mercedes C280
can you please update us what happens? also can you tell me more about that recall?
2006 Mercedes C280
I heard that the wires are part of some service campaign and not a recall. did they charge you anything?
i will post an update tomorrow once i inspect the camshaft sensor
